Home » Eclipse Projects » Eclipse Platform » MutliPageEditorPart
MutliPageEditorPart [message #115991] Mon, 25 August 2003 10:00 Go to next message
Originally posted by: jayanth_18.hotmail.com
I have created a multipage editor of four pages and an extra page as
'general'. When i click on any of the tabs, a new page becomes active.
This new page contains nothing. I want a file to be opened whenever i cick
on any tab. So how am i to pass the filepath to the method to open the
corresponding file. The code for creating a page is as given below. I use
the same method for creating all the other pages.
void createPage2()
Composite composite = new Composite(getContainer(), SWT.NONE);
FillLayout layout = new FillLayout();
composite.setLayout(layout);
int index = addPage(composite);
setPageText(index, "Preview");
Thanks in advance.....
With Regards,
Jayanth
Project Trainee,
IBM Software Lab, Bangalore,
India.
Ph:080-5094190
Re: MutliPageEditorPart [message #116174 is a reply to message #115991] Mon, 25 August 2003 11:26 Go to previous messageGo to next message
I don't really understand what your problem is.
Have you tried the PDE Wizard to create a sample MultiPageEditor and
see what code it generates? Perhaps there is enough information for you
there to answer your questions?
Chris
"Jayanth" <jayanth_18@hotmail.com> wrote in message
news:bid4pe$ojs$1@eclipse.org...
> void createPage2()
> With Regards,
> Jayanth
> Project Trainee,
> India.
> Ph:080-5094190
Re: MutliPageEditorPart [message #116496 is a reply to message #116174] Tue, 26 August 2003 02:35 Go to previous messageGo to next message
Thanks Chris for replying.....
Actually I want to display files as pages in the multipage editor. So how
am I to give the filepath to the method 'addPage'? The syntax for addPage
is
addPage(IEditorPart editor, IEditorInput input)
Here I can give 'editor' as a TexTEditor. But I dont know how to give the
'input' as the filepath to be opened. Could someone help me out?
Thanks and Regards,
Jayanth.
> Chris
> > void createPage2()
> > With Regards,
> > Jayanth
> > Project Trainee,
> > India.
> > Ph:080-5094190
Re: MutliPageEditorPart [message #116669 is a reply to message #116496] Tue, 26 August 2003 13:52 Go to previous messageGo to next message
You mean passing in an instance of org.eclipse.ui.part.FileEditorInput?
Chris
news:biev2k$chp$1@eclipse.org...
> is
> Thanks and Regards,
> Jayanth.
> > Chris
cick
use
> > > void createPage2()
> > > With Regards,
> > > Jayanth
> > > Project Trainee,
> > > India.
> > > Ph:080-5094190
Re: MutliPageEditorPart [message #117145 is a reply to message #116669] Wed, 27 August 2003 04:47 Go to previous messageGo to next message
Yeah exactly passing an instance of org.eclipse.ui.part.FileEditorInput
Can you help me out?
With Regards,
Jayanth.
> Chris
> > is
> > Thanks and Regards,
> > Jayanth.
> > > Chris
> cick
> use
> > > > void createPage2()
> > > > With Regards,
> > > > Jayanth
> > > > Project Trainee,
> > > > India.
> > > > Ph:080-5094190
Re: MutliPageEditorPart [message #117674 is a reply to message #117145] Wed, 27 August 2003 18:03 Go to previous messageGo to next message
How about
new FileEditorInput(Ifile file)
news:bihr64$g3$1@eclipse.org...
> With Regards,
> Jayanth.
> > Chris
how
addPage
> > > is
the
> > > Thanks and Regards,
> > > Jayanth.
you
> > > > Chris
as
active.
whenever i
> > cick
the
below. I
> > use
> > > > > void createPage2()
> > > > > With Regards,
> > > > > Jayanth
> > > > > Project Trainee,
> > > > > India.
> > > > > Ph:080-5094190
Re: MutliPageEditorPart [message #117789 is a reply to message #117674] Thu, 28 August 2003 01:34 Go to previous message
Thanks chris for your kind help..... its finally working for me
Here is the code for the same...
editor = new TextEditor();
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
IPath p = new Path(FILE_PATH + "runmqtst.cfg"); //FILE_PATH stores the
path of the file to opened.
IFile newLogo = root.getFile(p);
FileEditorInput fileEditor = new FileEditorInput( newLogo );
int index = addPage(editor, fileEditor);
Thanks and Regards,
Jayanth.
Chris Laffra wrote:
> How about
> > With Regards,
> > Jayanth.
> > > Chris
> how
> addPage
> > > > is
> the
> > > > Thanks and Regards,
> > > > Jayanth.
> you
> > > > > Chris
> as
> active.
> whenever i
> > > cick
> the
> below. I
> > > use
> > > > > > void createPage2()
> > > > > > With Regards,
> > > > > > Jayanth
> > > > > > Project Trainee,
> > > > > > India.
> > > > > > Ph:080-5094190
Previous Topic:Adding a JAR to a plugin's classpath dynamically
Next Topic:A multiple selection in tableViewer with mouse
Current Time: Tue Jul 22 13:48:08 EDT 2025
Powered by FUDForum. Page generated in 0.05639 seconds
