NullPointerException from DecorationScheduler [message #1161069] |
Tue, 29 October 2013 11:01  |
we use RAP 2.1.1 and are getting the following error pretty often:
org.eclipse.rap.ui.workbench - An internal error occurred during:
"Dekoration berechnen".
at org.eclipse.rap.rwt.RWT.getLocale(RWT.java:594)
at org.eclipse.rap.rwt.RWT$NLS.getISO8859_1Encoded(RWT.java:120)
at
org.eclipse.ui.internal.WorkbenchMessages.get(WorkbenchMessages.java:1143)
at
org.eclipse.ui.internal.decorators.DecorationScheduler$4.doRun(DecorationScheduler.java:352)
at
org.eclipse.ui.internal.decorators.DecorationScheduler$4$1.run(DecorationScheduler.java:321)
at
org.eclipse.rap.rwt.internal.lifecycle.ContextUtil.runNonUIThreadWithFakeContext(ContextUtil.java:67)
at
org.eclipse.rap.rwt.internal.service.UISessionImpl.exec(UISessionImpl.java:221)
at
org.eclipse.ui.internal.decorators.DecorationScheduler$4.run(DecorationScheduler.java:319)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Any ideas, or is this a bug?
Re: NullPointerException from DecorationScheduler [message #1161318 is a reply to message #1161089] |
Tue, 29 October 2013 14:32  |
Hi Ivan,
this did not help. I created a bug with an application to reproduce the
exception quite often.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=420657
Markus
Am 29.10.2013 16:20, schrieb Ivan Furnadjiev:
> Hi Markus,
> it's probably a bug. Could you try to change DecorationScheduler line
> 352 from:
> WorkbenchMessages.get().DecorationScheduler_CalculatingTask,
> to:
> WorkbenchMessages.get( display ).DecorationScheduler_CalculatingTask,
> Please open a bugzilla with simple snippet to reproduce the issue.
> Ivan
> On 10/29/2013 5:01 PM, Markus Krüger wrote:
>> Hi,
>> java.lang.NullPointerException
>> at
>> at
>> at
>> at
>> at
>> at
FUDForum. Page generated in 0.50614 seconds
