Duplicate checkout using SVN and multiconfiguration project [message #1039628] |
Fri, 12 April 2013 07:31  |
I have a multiconfiguration project and configured SVN as SCM provider.
My configuration contains a node setup as an axis, when running the job I get in the workspace two checkouts.
One is the checkout into the workspace itself and one is the checkout of the axis.
Log of the job on the master:
Started by user anonymous
Building on master
Checking out a fresh workspace because there's no workspace at /var/lib/hudson/jobs/K4_Init/workspace
Cleaning workspace /var/lib/hudson/jobs/K4_Init/workspace
Checking out http://codeserver/svn/code/trunk revision: Apr 12, 2013 2:22:52 PM depth:infinity ignoreExternals: true
A tests
AU tools/obcp/getParameterID.sh
At revision 3188
no change for http://codeserver/svn-dlr/code/trunk since the previous build
Triggering master
Log of the job on the master as slave:
Started by upstream job "K4_Init" build number 48
Building on master
Checking out a fresh workspace because there's no workspace at /var/lib/hudson/jobs/K4_Init/workspace/slave/master
Cleaning workspace /var/lib/hudson/jobs/K4_Init/workspace/slave/master
A build
In my opinion it is wrong, but what do you think?
[Updated on: Thu, 24 October 2013 12:10] by Moderator
FUDForum. Page generated in 0.05387 seconds
