Home » Archived » Visual Editor (VE) » widget properties problem
widget properties problem [message #115934] Thu, 26 January 2006 10:52 Go to next message
Originally posted by: alexandre.gzsistemas.com.br
I've been using ve since yesterday. So, there are a lot to learn ! Sorry
if it's so beginners question.
Sometimes, when I select a widget the only property that appear at
properties tab is the one called "name". Nothing more.
Why ? Is there any solution for that or it's a bug.
I updated ve yesterday too.
Thanks.
Re: widget properties problem [message #115976 is a reply to message #115934] Thu, 26 January 2006 13:57 Go to previous messageGo to next message
It sounds like you may have a bad cache.
First make sure you the right versions installed. For Eclipse 3.1.1 you need
EMF 2.1
GEF 3.1.1
VE 1.1.0.1
If you have those installed then clear the cache:
1) Bring up a VE and then close it and all other VE's. But leave
workspace up.
2) Select Project->Clean...->Clean All. Hit OK and wait for build to finish.
3) Bring up a VE. See if it now works.
Alexandre Boaventura wrote:
> Thanks.
Rich Kulp
Re: widget properties problem [message #115989 is a reply to message #115976] Thu, 26 January 2006 15:14 Go to previous message
Rich Kulp escreveu:
> need
> EMF 2.1
> GEF 3.1.1
> VE 1.1.0.1
> workspace up.
> finish.
>> Hi,
>> Sorry if it's so beginners question.
>> Thanks.
Sorry Rich.
I know what happened. If the Shell widget is completely empty then it
will not have access to properties. It's solved.
Thanks for your help.
Re: widget properties problem [message #611867 is a reply to message #115934] Thu, 26 January 2006 13:57 Go to previous message
EMF 2.1
GEF 3.1.1
VE 1.1.0.1
workspace up.
> Thanks.
Rich Kulp
Re: widget properties problem [message #611871 is a reply to message #115976] Thu, 26 January 2006 15:14 Go to previous message
Rich Kulp escreveu:
> need
> EMF 2.1
> GEF 3.1.1
> VE 1.1.0.1
> workspace up.
> finish.
>> Hi,
>> Thanks.
Sorry Rich.
Previous Topic:How to instal VE in Eclipse 3.1
Next Topic:Exporting JAR file - "resource is out of sync with file system"
Current Time: Fri Jul 18 06:22:34 EDT 2025
Powered by FUDForum. Page generated in 0.24864 seconds
