Home » Modeling » TMF (Xtext) » Interpreter for xtext
Interpreter for xtext [message #1149067] Mon, 21 October 2013 19:09 Go to next message
Hi everybody! I'm using xtext to implement a language, now I have my grammar, but I also want to execute the programs wrote with this, in a few words I need an xtext interpreter, but I can't understand if it's possible to do it using xtext!
Can someone help me? Sad
Thank you! Smile
Re: Interpreter for xtext [message #1149500 is a reply to message #1149067] Tue, 22 October 2013 02:02 Go to previous messageGo to next message
Interpreting is traversing the ast and doing something. If you
generate code the something is producing text.
Where to exactly start depends on how to call the interpreter. Maybe
(if you want to call it from context menu have a look at
http://christiandietrich.wordpress.com/2011/10/15/xtext-calling-the-gen
erator-from-a-context-menu/)
You may have a look at the arithmetics example too
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Interpreter for xtext [message #1149501 is a reply to message #1149067] Tue, 22 October 2013 02:03 Go to previous messageGo to next message
It's for sure possible.
It depends on the kind of language you have but if it's something
expression like, i.e. something that computes values, the simplest
approach is to traverse the expression tree and passing along the
variable scope.
Typically this would involve a dispatch over the different expression
kinds where you return the results. Example (using Xtend):
def dispatch BigDecimal invoke(Multiplication it, Map<String,Object>
scope) {
invoke(left) * invoke(right)
def dispatch BigDecimal invoke(Addition it, Map<String,Object> scope) {
invoke(left) + invoke(right)
def dispatch BigDecimal invoke(NumberLiteral it, Map<String,Object> scope) {
value
def dispatch BigDecimal invoke(VariableReference it, Map<String,Object>
scope) {
scope.get(it.variableName)
Xbase comes with an interpreter. So in case you want to have a look at
something real :
http://grepcode.com/file/repo1.maven.org$maven2@xxxxxxxxe.xtend$org.eclipse.xtend.standalone@2.4.2@org$eclipse$xtext$xbase$interpreter$impl$XbaseInterpreter.java
Here the _doEvaluate method corresponds to the invoke method from
above's example.
hth,
Sven
Am 10/22/13 1:09 AM, schrieb Caroline Smith:
> Can someone help me? :(
> Thank you! :)
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: Interpreter for xtext [message #1159147 is a reply to message #1149501] Mon, 28 October 2013 06:23 Go to previous messageGo to next message
I have a java like grammar wrote with xtext, if I remould it in xbase can I use the xabse interpreter to directly evaluate a program wrote with this grammar and have a result without passing to a java code?
Re: Interpreter for xtext [message #1159173 is a reply to message #1159147] Mon, 28 October 2013 06:41 Go to previous messageGo to next message
Yes
Re: Interpreter for xtext [message #1159320 is a reply to message #1159173] Mon, 28 October 2013 08:51 Go to previous messageGo to next message
have you some example of this?
Re: Interpreter for xtext [message #1159339 is a reply to message #1159320] Mon, 28 October 2013 09:10 Go to previous message
some year ago i did https://github.com/cdietrich/mql
~Christian
Previous Topic:Resolving type parameters in the Jvm types
Next Topic:Xcore as metamodel for Xtext Grammar
Current Time: Thu Jul 17 13:50:53 EDT 2025
Powered by FUDForum. Page generated in 0.51221 seconds
