Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Compilations errors when Acceleo is deployed throuh update site
[Acceleo] Compilations errors when Acceleo is deployed throuh update site [message #1083194] Fri, 09 August 2013 12:04 Go to next message
Hello all,
I am using Eclipse 3.6.2, EMF 2.6.1 and Acceleo 3.4.0.201306101458.
I have a bunch of Acceleo plugins which successfully generate code when executed from my workspace in a nested Eclipse.
But, if I produce an update site plugin and use it to install my application in an vanilla Eclipse installation, code generation is incomplete and "Unresolved compilation error in generation module." warnings appear in the Error logs.
I have checked that all produced jars contain emtl files and I use XMI serialization.
I also tried to install a deployable feature produced with PDE Export as explained here . In that case, I get no error but Acceleo does not produce any files.
Help is welcomed !
Michaël
Re: [Acceleo] Compilations errors when Acceleo is deployed throuh update site [message #1108014 is a reply to message #1083194] Fri, 13 September 2013 03:52 Go to previous messageGo to next message
Up !
Re: [Acceleo] Compilations errors when Acceleo is deployed throuh update site [message #1132780 is a reply to message #1108014] Fri, 11 October 2013 07:39 Go to previous messageGo to next message
Up !
Re: [Acceleo] Compilations errors when Acceleo is deployed throuh update site [message #1159074 is a reply to message #1132780] Mon, 28 October 2013 05:21 Go to previous message
In order to build your generator, use Tycho as detailled here. We had issues while plugging Acceleo to the PDE build system in the past which is why we moved to Tycho.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
Previous Topic:ACCELEO chain compilation error
Next Topic:Debugging Acceleo Project
Current Time: Wed Jul 23 08:13:34 EDT 2025
Powered by FUDForum. Page generated in 0.05276 seconds
