Home » Modeling » TMF (Xtext) » Iterating through Xtext model and making decisions for Code Gen
Iterating through Xtext model and making decisions for Code Gen [message #1154233] Fri, 25 October 2013 00:31 Go to next message
OK, in just 4 short weeks I've gone from knowing nothing at all about Xtext or Xtend to actually being able to generate some code! Happy days.
My Xtext grammar is being used to parse some DSP assembly code and then translate that into an equivalent Java representation for further manipulation.
Here's my grammar:
grammar com.holycityaudio.spincad.SpinCAD with org.eclipse.xtext.common.Terminals
generate spinCAD "http://www.holycityaudio.com/spincad/SpinCAD"
Program:
	(elements += Element)+
Element:
	Equate | Mem | Comment | Instruction | Label
Equate:
	'equ' ename = ID value = SPINDOUBLE
Mem:
	'mem' buffer = ID length = INT
Comment:
	cname = SC_COMMENT
Label:
	name = DR_LABEL
Instruction:
	Inst_B15_S1_9 |
	Inst_B6_S1_14 |
	Inst_S1_14_S1_10 |
	Inst_B6 |
	Inst_B24  |
	Inst |
	Skip |
	Jam |
	LoadSinLFO |
	LoadRampLFO |
	ChorusReadDelay |
	ChorusReadDelayPointer |
	ChorusScaleOffset |
	Log |
	ReadDelayPointer
Inst_B6_S1_14:
	ReadRegister |
	WriteRegister |
	ReadRegisterFilter |
	Maxx |
	WriteRegisterHighPass |
	WriteRegisterLowPass
Inst_B15_S1_9:
	ReadDelay |
	WriteDelay |
	WriteAllPass
Inst_B6:
	Mulx |
	Ldax
Inst_B24:
	And |
	Or |
	Xor
Inst:
	Clr | Not | Absa
Inst_S1_14_S1_10:
	Exp | ScaleOffset
ReadRegister: 'rdax' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE;
WriteRegisterLowPass: 'wrlx' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE;
WriteRegisterHighPass: 'wrhx' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE ;
WriteRegister: 'wrax' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE ;
Maxx: 'maxx' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE ;
ReadRegisterFilter: 'rdfx' arg1 = SPINREGISTER ',' arg2 = SPINDOUBLE ;
Mulx: 'mulx' arg1 = ID ;
Ldax: 'ldax' arg1 = ID ;
Exp: 'exp' arg1 = SPINDOUBLE ',' arg2 = SPINDOUBLE ;
Log: 'log' arg1 = SPINDOUBLE ',' arg2 = SPINDOUBLE ;
ScaleOffset: 'sof' arg1 = SPINDOUBLE ',' arg2 = SPINDOUBLE ;
WriteDelay: 'wra' arg1 = ID ('^' | '#' | ('+' arg3 = SPINREGISTER))? ',' arg2 = SPINDOUBLE;
WriteAllPass: 'wrap' arg1 = ID ('^' | '#' | ('+' arg3 = SPINREGISTER))?  ',' arg2 = SPINDOUBLE;
ReadDelay: 'rda' arg1 = ID ('^' | '#' | ('+' arg3 = SPINREGISTER))? ',' arg2 = SPINDOUBLE;
LoadSinLFO: 'wlds' arg1 = SPINREGISTER ',' arg2 = INT ',' arg3 = INT;
LoadRampLFO: 'wldr' arg1 = SPINREGISTER ',' arg2 = INT ',' arg3 = INT;
// Chorus instructions
ChorusReadDelay: 'cho rda' ',' arg1 = SPINREGISTER ',' arg2 = SPINCHOREGFLAGS ',' arg3 = SPINMEM;
ChorusReadDelayPointer: 'cho rdal' ',' arg1 = SPINREGISTER;
ChorusScaleOffset: 'cho sof' ','  arg1 = ID ',' arg2 = SPINCHOREGFLAGS ',' arg3 = SPINDOUBLE;
ReadDelayPointer: 'rmpa' arg1 = SPINDOUBLE;
// single argument instructions
And: 'and' arg1 = SPINREGISTER;
Or: 'or' arg1 = SPINREGISTER;
Xor: 'xor' arg1 = SPINREGISTER;
Jam: 'jam' arg1=ID;
// zero argument instructions
Clr: 'clr';
Not: 'not';
Absa: 'absa';
Skip: 'skp' arg1 = ID ',' arg2 = SPINREGISTER;
terminal SC_COMMENT 	: ';' !('\n'|'\r')* ('\r'? '\n');
// data type rules
SPINDOUBLE: '-'? (ID | (INT ( '.' INT)?));
SPINREGISTER: '%'?(ID | INT);
SPINCHOREGFLAGS: (INT | (ID ('|' ID)*)?);
SPINMEM: ID ('^' | '#' | ('+' arg4 = SPINREGISTER))?;
DR_LABEL: (ID ":");
And my Xtend code generator:
 * generated by Xtext
package com.holycityaudio.spincad.generator
import org.eclipse.emf.ecore.resource.Resource
import org.eclipse.xtext.generator.IGenerator
import org.eclipse.xtext.generator.IFileSystemAccess
import com.holycityaudio.spincad.spinCAD.Element
import com.holycityaudio.spincad.spinCAD.Program
import com.holycityaudio.spincad.spinCAD.Instruction
import org.eclipse.xtext.naming.IQualifiedNameProvider
import com.google.inject.Inject
class SpinCADGenerator implements IGenerator {
  @Inject extension IQualifiedNameProvider
	override void doGenerate(Resource resource, IFileSystemAccess fsa) {
		fsa.generateFile(resource.className+"CADBlock"+".java", toCADBlockCode(resource.contents.head as Program))
		fsa.generateFile(resource.className+"ControlPanel"+".java", toControlPanelCode(resource.contents.head as Program))
	def className(Resource res) {
		var name = res.URI.lastSegment
		return name.substring(0, name.indexOf('.'))
	def toCADBlockCode(Program pr) '''
		package com.holycityaudio.SpinCAD.CADBlocks;
		import com.holycityaudio.SpinCAD.SpinCADPin;
		import com.holycityaudio.SpinCAD.fxblocks.basic.SpinFXBlock;
		public class «pr.eResource.className+"CADBlock"» extends SpinCADBlock {
			public «pr.eResource.className+"CADBlock"»(int x, int y) {
				super(x, y);
				setName("«pr.eResource.className+"CADBlock"»");
			public void editBlock(){
				new «pr.eResource.className+"ControlPanel"»(this);
			public void generateCode(SpinFXBlock sfxb) {
			«FOR c : pr.elements»
				«c.declareElement»
			«ENDFOR»
	def toControlPanelCode(Program pr) '''
		public class «pr.eResource.className+"ControlPanel"» {
			private JFrame frame;
		private «pr.eResource.className+"CADBlock"» spbCB;
		public «pr.eResource.className+"ControlPanel"»(«pr.eResource.className+"CADBlock"» genericCADBlock) {
		spbCB = genericEQCADBlock;
		SwingUtilities.invokeLater(new Runnable() {
			public void run() {
				frame = new JFrame();
				frame.setLayout(new BoxLayout(frame.getContentPane(), BoxLayout.Y_AXIS));
				«pr.eResource.className»SliderListener bEQSL = new BassmanEQSliderListener();
				frame.setVisible(true);
				frame.pack();
				frame.setResizable(false);
				frame.setLocation(spbCB.getX() + 100, spbCB.getY() + 100);
	class «pr.eResource.className»SliderListener implements ChangeListener {
		public void stateChanged(ChangeEvent ce) {
	def declareElement(Element element) '''
		// «element»
Some of this is obviously just a place holder for future functionality. Let's just zoom in on the important parts.
My model (Program) is composed of Elements, each of which could be an Equate, Mem, Instruction, Comment, or Label:
Program:
Element:
In the Xtend I'm using this to iterate through all the elements:
				«c.declareElement»
			«ENDFOR»
and all I'm doing right now is creating a Java comment with the element printed out:
		// «element»
Here's what I want to do:
1) Iterate through all Elements. Ignore Comments.
2) Depending on whether it's an Equate, Mem, or Label, do some substitution and arrangement of the arguments (which currently don't all have the same names)
3) If it's an Instruction, I further want to figure out which one it is and then access the correct translation per Instruction. Notice that I have a few subgroups of instructions which are there because the arguments follow certain patterns in those groups and I wanted to write a single validator per group. Some instructions are unique and don't fall into a group.
All I've figured out is how to do #1, but I have no idea how to do #2 or #3.
Any hints?
Thanks again!!! Very Happy
GW
[Updated on: Fri, 25 October 2013 00:48] by Moderator
Re: Iterating through Xtext model and making decisions for Code Gen [message #1154249 is a reply to message #1154233] Fri, 25 October 2013 00:48 Go to previous messageGo to next message
Did you do the Xtext tutorials? Did you do some reading on Xtend.
A very convenient way of doing this is to use Xtends dispatch methods
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Iterating through Xtext model and making decisions for Code Gen [message #1154285 is a reply to message #1154249] Fri, 25 October 2013 01:19 Go to previous messageGo to next message
Hi Gary,
you can iterate through all your elements and use a switch as a typequard to handle the different types.
If you don't want comments to be processed, just leave them out of the switch cases.
An example from my Generator which keeps the sequence intact:
«FOR Module modul : sm.modules»
«switch modul {
Module1:{genCodeModule1(modul)}
Module2:{genCodeModule2(modul)}
Trigger:{genTriggerCode(modul)}
EntitySupport:{genEntitySupport(modul)}
Entry:{genEntryCode(modul)}
«ENDFOR»
is based an an XTEXT definition of:
Model: modules+=Module+;
Module: (Module1 | Module2 | Trigger | Entry | EntitySupport);
Re: Iterating through Xtext model and making decisions for Code Gen [message #1154806 is a reply to message #1154285] Fri, 25 October 2013 09:16 Go to previous messageGo to next message
Hi Christian,
Yes I've done a few of the tutorials and I have read about Xtend. I will admit that I have a hard time reading some of this material because I am not a professional developer and I don't understand what is meant by a lot of it. I will look into the dispatch method, thanks for the tip.
Hi Uli, thanks for the suggestion. I added this to my Xtend code:
			«FOR Element e : pr.elements»
				«switch e {
					Comment:{genComment(e)}
					Instruction:{genInstruction(e)}
					Mem:{genMem(e)}
					Equate:{genEquate(e)}
					Label:{genLabel(e)}
			«ENDFOR»
At this point I'm just printing out some debug stuff to the console.
		def genInstruction(Instruction inst) '''
		«switch inst {
			ReadRegister: println("ReadRegister")
			WriteRegister: println("WriteRegister")
And it does seem to be working. I'll keep working on it! Thanks so much.
GW
Re: Iterating through Xtext model and making decisions for Code Gen [message #1154834 is a reply to message #1154806] Fri, 25 October 2013 09:46 Go to previous messageGo to next message
Hmm,
then i wonder why you did not stumble around something like
	def generate(List<Element> elements)
		«FOR it : elements»
			«handle»
		«ENDFOR»
	def dispatch handle(AElement e) '''
		Here we are
	def dispatch handle(OtherElement e) '''
		there we are
Re: Iterating through Xtext model and making decisions for Code Gen [message #1158698 is a reply to message #1154834] Sun, 27 October 2013 23:53 Go to previous messageGo to next message
Hi Christian,
I went ahead and used Uli's suggestion for the Typeguard switch statement and it seems to be working pretty well so far. Is the "dispatch" approach better for any reason?
GW
Re: Iterating through Xtext model and making decisions for Code Gen [message #1158841 is a reply to message #1158698] Mon, 28 October 2013 02:09 Go to previous message
Maybe this one: Xtext handles order of type hierarchy automatically.
In your example you have to care yourself.
Previous Topic:JvmModelInferrer and JvmModelGenerator: generating error-less elements
Next Topic:Problem with XbaseCompiler
Current Time: Fri Jul 25 21:27:12 EDT 2025
Powered by FUDForum. Page generated in 0.04490 seconds
