Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore] Problem sharing project
[EMFStore] Problem sharing project [message #1158642] Sun, 27 October 2013 22:55 Go to next message
I ran into another snag using EMFStore. Here's my scenario:
First, I create a new project.
Second, I load my model instance from local disk using the standard EMF
XMI Resource.
Next, I add the contents of this Resource (a single root EObject) to the
EMFStore project modelElements list.
Finally, when I attempt to share my local project on the EMFStore server
I get the following error on the server console. What are possible
causes of this?
Oct 27, 2013 9:49:27 PM org.apache.xmlrpc.server.XmlRpcErrorLogger log
SEVERE: Failed to invoke method createEmptyProject in class
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl:
org.apache.xmlrpc.common.XmlRpcInvocationException: Failed to invoke
at
org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.invoke(ReflectiveXmlRpcHandler.java:129)
at
org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.execute(ReflectiveXmlRpcHandler.java:106)
at
org.apache.xmlrpc.server.XmlRpcServerWorker.execute(XmlRpcServerWorker.java:46)
at org.apache.xmlrpc.server.XmlRpcServer.execute(XmlRpcServer.java:86)
at
org.apache.xmlrpc.server.XmlRpcStreamServer.execute(XmlRpcStreamServer.java:200)
at org.apache.xmlrpc.webserver.Connection.run(Connection.java:208)
at org.apache.xmlrpc.util.ThreadPool$Poolable$1.run(ThreadPool.java:68)
Caused by:
org.eclipse.emf.emfstore.internal.server.exceptions.InvalidInputException:
at
org.eclipse.emf.emfstore.internal.server.core.AbstractSubEmfstoreInterface.sanityCheckObject(AbstractSubEmfstoreInterface.java:189)
at
org.eclipse.emf.emfstore.internal.server.core.AbstractSubEmfstoreInterface.sanityCheckObjects(AbstractSubEmfstoreInterface.java:176)
at
org.eclipse.emf.emfstore.internal.server.core.subinterfaces.ProjectSubInterfaceImpl.createProject(ProjectSubInterfaceImpl.java:173)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at
org.eclipse.emf.emfstore.internal.server.core.AbstractSubEmfstoreInterface.execute(AbstractSubEmfstoreInterface.java:149)
at
org.eclipse.emf.emfstore.internal.server.core.EMFStoreImpl.invoke(EMFStoreImpl.java:129)
at com.sun.proxy.$Proxy4.createEmptyProject(Unknown Source)
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl.createEmptyProject(XmlRpcEmfStoreImpl.java:89)
at
at
at
org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.invoke(ReflectiveXmlRpcHandler.java:115)
... 6 more
Caused by:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Oct 27, 2013 10:25:57 PM org.apache.xmlrpc.server.XmlRpcErrorLogger log
SEVERE: Couldn't parse EObject: Failed to retrieve ID for EObject
contained in project:
com.humanfactor.rw.model.regatta.impl.RegattaImpl@b6c31dc
(abbreviatedName: Catch the Cooper Masters R...[truncated lots of
serialized object text]....xswainEntryCost: 75.0,
fourWithoutCoxswainEntryCost: 75.0, quadEntryCost: 75.0, eightEntryCost:
100.0, octupleEntryCost: 100.0, raceDesignType: sprint,
missingBowNumbers: null, regattaId: 1490)
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResult(EObjectTypeParser.java:67)
at
org.apache.xmlrpc.parser.RecursiveTypeParserImpl.endValueTag(RecursiveTypeParserImpl.java:78)
at
org.apache.xmlrpc.parser.XmlRpcRequestParser.endElement(XmlRpcRequestParser.java:162)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:601)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.java:1782)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2939)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:647)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:140)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:511)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at
org.apache.xmlrpc.server.XmlRpcStreamServer.getRequest(XmlRpcStreamServer.java:65)
at
org.apache.xmlrpc.server.XmlRpcStreamServer.execute(XmlRpcStreamServer.java:199)
Caused by:
org.eclipse.emf.emfstore.internal.server.exceptions.SerializationException:
Failed to retrieve ID for EObject contained in project:
com.humanfactor.rw.model.regatta.impl.RegattaImpl@5152a09f
(abbreviatedName: Stotesbury Cup Regatta, duration: 2, regattaHomePage:
null, registeredUsRowing: false, resultsUrl: , lifeCycleS...[truncated
lots of serialized object text]....raceDesignType: sprint,
missingBowNumbers: null, regattaId: 1460)
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResultfromResource(EObjectTypeParser.java:108)
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResult(EObjectTypeParser.java:61)
... 17 more
Re: [EMFStore] Problem sharing project [message #1159263 is a reply to message #1158642] Mon, 28 October 2013 08:02 Go to previous messageGo to next message
Hi Scott,
thank you for your report! Is it possible that you changed one of the
generated getters or setters or the generated factory? This could be the
reason for a new object being created during deserialization (and hence
this object has no ID).
If this is not the case:
Is it possible to share the model plugin and/or the Ecore with us?
Could you share the code snippet that loads the resource and puts its
contents into the project?
Hope this helps!
Maximilian
Am 28.10.2013 03:55, schrieb scott@xxxxxxxx:
> XMI Resource.
> causes of this?
> at
> at
> at
> at
> Caused by:
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> ... 6 more
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> at
> at
> ... 17 more
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EMFStore] Problem sharing project [message #1159386 is a reply to message #1159263] Mon, 28 October 2013 09:47 Go to previous messageGo to next message
Maximilian,
I made no changes to the ID generation --- I'm using the out of the box
ID generator.
I made some progress debugging this problem using a simpler test case
outside of my application. It turns out that ordering of the operations
in my scenario matters. If the model instance is added to EMFStore's
model element list *before* the local project is shared, the exception
occurs.
On the other hand, if my model instance is added *after* sharing the
local project, no problem. I haven't tested beyond this, but wanted to
give you this update and get your thoughts.
Is this expected behavior for EMFStore?
I'll look into creating a standalone test case.
Scott
On 10/28/2013 8:02 AM, Maximilian Koegel wrote:
> Hi Scott,
> Hope this helps!
> Cheers,
> Maximilian
>> XMI Resource.
>> causes of this?
>> at
>> at
>> at
>> at
>> Caused by:
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 6 more
>> Caused by:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> at
>> at
>> ... 17 more
Re: [EMFStore] Problem sharing project [message #1159473 is a reply to message #1159386] Mon, 28 October 2013 11:06 Go to previous messageGo to next message
Maximilian,
Here's a test case that replicates the issue. It's based on your
HelloWorld example code as a base. If a model element is added to the
local project before it is shared AND that model element is part of an
EMF Resource, then problem occurs.
Hope this helps. Is there a workaround I can use?
Scott
package org.eclipse.emf.emfstore.example.helloworld;
import java.io.File;
import java.io.IOException;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.XMIResource;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl;
import org.eclipse.emf.emfstore.bowling.BowlingFactory;
import org.eclipse.emf.emfstore.bowling.League;
import org.eclipse.emf.emfstore.bowling.Player;
import org.eclipse.emf.emfstore.client.ESLocalProject;
import org.eclipse.emf.emfstore.client.ESRemoteProject;
import org.eclipse.emf.emfstore.client.ESServer;
import org.eclipse.emf.emfstore.client.ESUsersession;
import org.eclipse.emf.emfstore.client.ESWorkspace;
import org.eclipse.emf.emfstore.client.ESWorkspaceProvider;
import org.eclipse.emf.emfstore.client.exceptions.ESServerNotFoundException;
import
org.eclipse.emf.emfstore.client.exceptions.ESServerStartFailedException;
import org.eclipse.emf.emfstore.common.ESSystemOutProgressMonitor;
import org.eclipse.emf.emfstore.server.exceptions.ESException;
import org.eclipse.equinox.app.IApplication;
import org.eclipse.equinox.app.IApplicationContext;
* An application that runs the demo.<br>
* Run a client and local server that demo the basic features of EMFStore.
public class TestCaseApplication implements IApplication {
* {@inheritDoc}
public Object start(IApplicationContext context) {
try {
// Create a client representation for a local server and start a
local server.
ESServer localServer = ESServer.FACTORY.createAndStartLocalServer();
// Run a client on the local server that shows the basic features of
the EMFstore
runClient(localServer);
} catch (ESServerStartFailedException e) {
System.out.println("Server start failed!");
e.printStackTrace();
} catch (ESException e) {
// If there is a problem with the connection to the server,
// e.g., a network, a specific EMFStoreException will be thrown.
System.out.println("Connection to Server failed!");
return IApplication.EXIT_OK;
* Run an EMFStore Client connecting to the given server.
* @param server the server
* @throws ESException if the server connection fails
public static void runClient(ESServer server) throws ESException {
System.out.println("Client starting...");
// The workspace is the core controller to access local and remote
projects.
// A project is a container for models and their elements (EObjects).
// To get started, we obtain the current workspace of the client.
ESWorkspace workspace = ESWorkspaceProvider.INSTANCE.getWorkspace();
// The workspace stores all available servers that have been
configured. We add the local server that has
// already
// been started on the workspace.
workspace.addServer(server);
// Next, we remove all other existing servers
for (ESServer existingServer : workspace.getServers()) {
if (existingServer != server) {
try {
workspace.removeServer(existingServer);
} catch (ESServerNotFoundException e) {
// The workspace also contains a list of local projects that have
either been created locally or checked out
// from a server.
// We create a new local project. The project new created is not yet
shared with the server.
ESLocalProject demoProject = workspace.createLocalProject("DemoProject");
* When the model elements are added here before the project is shared
AND the model element (league in this
* case) is contained in a resource, then this exception is thrown.
The loadModelOrig() works fine, while
* loadModel2(), loadModel3() and loadModel4() all throw exceptions.
* SEVERE: Couldn't parse EObject: Failed to retrieve ID for EObject
* org.eclipse.emf.emfstore.bowling.impl.LeagueImpl@20ec6bb1
League league = loadModel2();
demoProject.getModelElements().add(league);
demoProject.save();
// We delete all projects from the local workspace other than the one
just created.
for (ESLocalProject existingLocalProject : workspace.getLocalProjects()) {
if (existingLocalProject != demoProject) {
try {
existingLocalProject.delete(new ESSystemOutProgressMonitor());
} catch (IOException e) {
// Next, we create a user session by logging in to the local EMFStore
server with default super user
// credentials.
ESUsersession usersession = server.login("super", "super");
// Now we can share the created local project to our server.
ESRemoteProject remoteDemoProject =
demoProject.shareProject(usersession, new ESSystemOutProgressMonitor());
// We also retrieve a list of existing (and accessible) remote
projects on the server.
// Remote projects represent a project that is currently available on
the server.
// We delete all remote projects to clean up remaining projects from
previous launches.
for (ESRemoteProject existingRemoteProject :
server.getRemoteProjects(usersession)) {
if
(!existingRemoteProject.getGlobalProjectId().equals(remoteDemoProject.getGlobalProjectId()))
existingRemoteProject.delete(usersession, new NullProgressMonitor());
// Now we are all set: we have a client workspace with one server
configured and exactly one project shared to a
// server with only this one project.
// We check out a second, independent copy of the project (simulating
a second client).
ESLocalProject demoProjectCopy =
demoProject.getRemoteProject().checkout("DemoProject Copy",
// We start working now with the local project and later we will
synchronize it with the copy of the project we
// just checked out.
// We create some EObjects and add them to the project, that is, to
project�s containment tree. Everything
// that
// is
// in the project�s containment tree (spanning tree on containment
references) is considered part of the
// project. We will use an example model about bowling.
// First we add a league and set the league name.
// League league = loadModel();
// Next we add the league to the root of the project. The project has
a containment feature called model
// element that holds all root elements of a project. This list is
comparable to the content list in EMF
// Resources that
// you can retrieve with getContents(). Adding something to the list
will add it to the project.
// demoProject.getModelElements().add(league);
// Then we create two players.
Player player1 = BowlingFactory.eINSTANCE.createPlayer();
player1.setName("Maximilian");
Player player2 = BowlingFactory.eINSTANCE.createPlayer();
player2.setName("Ottgar");
// Finally, we add the players to the league. Since the league is
already part of the project and League.players
// is a containment feature, the players also become part of the project.
league.getPlayers().add(player1);
league.getPlayers().add(player2);
// To synchronize the local changes of the client with the server, we
will commit the project.
demoProject.commit("My message", null,
// The server is now up-to-date, but we still need to synchronize the
copy of the project we checked out
// earlier.
demoProjectCopy.update(new ESSystemOutProgressMonitor());
// We will now retrieve the copy of the league from the copy of the
project and assert its name and player count
// are equal with the name of the project�s league.
League leagueCopy = (League) demoProjectCopy.getModelElements().get(0);
if (league.getName().equals(leagueCopy.getName()) &&
league.getPlayers().size() == leagueCopy.getPlayers().size()) {
System.out.println("Leagues names and player count are equal.");
// Of course, we can also change something in the project copy and
synchronize it back to the project.
// We change the league name to correct the type and then commit and
update accordingly.
// This time, we use the IDs assigned to every EObject of a project to
identify the copy of league in the
// project�s copy.
demoProjectCopy.getModelElement(demoProject.getModelElementId(league));
league.setName("Superbowling League");
demoProject.commit(new ESSystemOutProgressMonitor());
System.out.println("Leagues names and player count are still equal.");
* {@inheritDoc}
public void stop() {
public static League loadModelOrig() {
// This works fine
League league = BowlingFactory.eINSTANCE.createLeague();
league.setName("Suprbowling League");
return league;
public static League loadModel2() {
// This fails
URI uri = createURI();
Resource resource = new XMIResourceImpl(uri);
resource.getContents().add(league);
return league;
public static League loadModel3() {
// This fails
ResourceSet resourceSet = createResourceSet();
Resource resource = resourceSet.createResource(uri);
return league;
public static League loadModel4() {
// This fails
League league;
createModel();
try {
resource.load(null);
league = (League) resource.getContents().get(0);
league = null;
return league;
public static void createModel() {
try {
resource.save(null);
System.out.println("Saved league to " + uri);
public static URI createURI() {
return URI.createFileURI(new File("MyLeague.league").getAbsolutePath());
public static ResourceSet createResourceSet() {
// For testing to see whether UUIDs caused the problem
ResourceSet resourceSet = new ResourceSetImpl() {
public Resource createResource(URI uri) {
XMIResource resource = new XMIResourceImpl(uri) {
protected boolean useUUIDs() {
return false;
return resource;
return resourceSet;
On 10/28/2013 9:47 AM, scott@xxxxxxxx wrote:
> Maximilian,
> ID generator.
> occurs.
> Scott
>> Hi Scott,
>> Hope this helps!
>> Cheers,
>> Maximilian
>>> XMI Resource.
>>> causes of this?
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 6 more
>>> Caused by:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> at
>>> ... 17 more
Re: [EMFStore] Problem sharing project [message #1163098 is a reply to message #1159473] Wed, 30 October 2013 16:56 Go to previous messageGo to next message
Hi Scott,
thanks for the test case and sorry for the delay (we're are currently
attending EclipseCon). We'll integrate a test case like this in our test
suite, since apparently it was missing. We also do have a fix ready and
will look at the other issues you reported as soon as possible.
We're planning to do a hotfix release addressing the reported issues at
the end of next week.
Edgar
Am 28.10.2013 16:06, schrieb scott@xxxxxxxx:
> Maximilian,
> Scott
> import
> import
> * {@inheritDoc}
> try {
> start a local server.
> features of the EMFstore
> thrown.
> remote projects.
> (EObjects).
> // already
> try {
> have either been created locally or checked out
> // from a server.
> not yet shared with the server.
> shared AND the model element (league in this
> thrown. The loadModelOrig() works fine, while
> exceptions.
> demoProject.save();
> the one just created.
> try {
> EMFStore server with default super user
> // credentials.
> available on the server.
> from previous launches.
> if
> server configured and exactly one project shared to a
> (simulating a second client).
> will synchronize it with the copy of the project we
> is, to project�s containment tree. Everything
> // that
> // is
> containment references) is considered part of the
> project has a containment feature called model
> is comparable to the content list in EMF
> // Resources that
> list will add it to the project.
> is already part of the project and League.players
> the project.
> server, we will commit the project.
> synchronize the copy of the project we checked out
> // earlier.
> the project and assert its name and player count
> equal.");
> and synchronize it back to the project.
> commit and update accordingly.
> project to identify the copy of league in the
> // project�s copy.
> still equal.");
> * {@inheritDoc}
> // This works fine
> return league;
> // This fails
> return league;
> // This fails
> return league;
> // This fails
> League league;
> createModel();
> try {
> league = null;
> return league;
> try {
> @Override
> @Override
> return false;
> return resource;
> return resourceSet;
>> Maximilian,
>> ID generator.
>> occurs.
>> Scott
>>> Hi Scott,
>>> Hope this helps!
>>> Cheers,
>>> Maximilian
>>>> XMI Resource.
>>>> the
>>>> server
>>>> causes of this?
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 6 more
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> eightEntryCost:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> ... 17 more
Edgar Mueller
Re: [EMFStore] Problem sharing project [message #1164320 is a reply to message #1159473] Thu, 31 October 2013 11:45 Go to previous message
Scott,
thank you very much for the test case. A work around would be to remove
the object you add to the project from the resource prior to adding it
to the project. You can do this with resource.getContents().remove().
Maximilian
> Maximilian,
> Scott
> import
> import
> * {@inheritDoc}
> try {
> thrown.
> remote projects.
> (EObjects).
> // already
> try {
> // from a server.
> exceptions.
> demoProject.save();
> try {
> // credentials.
> if
> // that
> // is
> // Resources that
> project.
> // earlier.
> equal.");
> // project�s copy.
> equal.");
> * {@inheritDoc}
> // This works fine
> return league;
> // This fails
> return league;
> // This fails
> return league;
> // This fails
> League league;
> createModel();
> try {
> league = null;
> return league;
> try {
> @Override
> @Override
> return false;
> return resource;
> return resourceSet;
>> Maximilian,
>> ID generator.
>> occurs.
>> Scott
>>> Hi Scott,
>>> Hope this helps!
>>> Cheers,
>>> Maximilian
>>>> XMI Resource.
>>>> the
>>>> server
>>>> causes of this?
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 6 more
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> eightEntryCost:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> ... 17 more
Maximilian Kögel
Previous Topic:[Teneo] How to use real text datatypes in database?
Next Topic:PrimitiveTypes For Metamodel
Current Time: Wed Jul 23 20:29:56 EDT 2025
Powered by FUDForum. Page generated in 0.24143 seconds
