Home » Modeling » EMF » Understanding Net4j
Understanding Net4j [message #1157598] |
Sun, 27 October 2013 06:15  |
I am a beginner to Net4j Signalling Platform. I installed "Net4j signalling platform" in a classic eclipse(Kepler). Then I tried to run the Buddies example. But it did not work. I could start the server without any problems. But I could not start any of the clients. I receive an exception showing "No application ID has been found".
Then I installed the same "Net4j signalling platform" in a Modeling eclipse(Kepler). But it works now. I can run it without any problems. I think it is because there is CDO already in the Modeling Eclipse but not in the classic eclipse. So I just unchecked the CDO plugins then run the clients. Now I get the same problem which I received in the classic version of eclipse.
Now, the question is: I always believed CDO is based on Net4j. So, Net4j should not require CDO for its operation. But why could not I run the Net4j examples when I do not have CDO?
Another question is that: Why there is CDO-Server.xml file (in the config folder) in the "org.eclipse.net4j.buddies.server" plugin project?
Re: Understanding Net4j [message #1157785 is a reply to message #1157764] |
Sun, 27 October 2013 09:11   |
Hi Eike,
I do not really know on which port the server is running.
I did not change anything. I am just running the example as it is.
Could you please tell me, how to see the port on which the Server
is running on?
I will definitely make a tutorial. If I get understand how it works in the future.
It will be a really useful thing to do.
The complete Errorlog is given below
Time to load bundles: 35
Starting application: 7683
main [debug.om] Starting bundle org.eclipse.net4j.util
main [debug.lifecycle] Activating ManagedContainer
main [debug.lifecycle] Activating {}
main [debug.lifecycle.dump] DUMP PluginFactoryRegistry
ShareableLifecycle.refCount = null
Registry.autoCommit = true
Registry.transaction = null
HashMapRegistry.map =
org.eclipse.net4j.acceptors[ssl]=Factory[org.eclipse.net4j.acceptors, ssl]
org.eclipse.net4j.connectors[ssl]=Factory[org.eclipse.net4j.connectors, ssl]
org.eclipse.net4j.util.security.credentialsProviders[interactive]=Factory[org.eclipse.net4j.util.security.credentialsProviders, interactive]
org.eclipse.net4j.randomizers[default]=Factory[org.eclipse.net4j.randomizers, default]
org.eclipse.net4j.userManagers[file]=Factory[org.eclipse.net4j.userManagers, file]
org.eclipse.net4j.buddies.clientFacilities[chat]=Factory[org.eclipse.net4j.buddies.clientFacilities, chat]
org.eclipse.net4j.serverProtocols[heartbeat]=Factory[org.eclipse.net4j.serverProtocols, heartbeat]
org.eclipse.net4j.util.ui.elementWizards[org.eclipse.net4j.acceptors:jvm]=Factory[org.eclipse.net4j.util.ui.elementWizards, org.eclipse.net4j.acceptors:jvm]
org.eclipse.net4j.authenticators[file]=Factory[org.eclipse.net4j.authenticators, file]
org.eclipse.net4j.util.ui.elementWizards[org.eclipse.net4j.connectors:jvm]=Factory[org.eclipse.net4j.util.ui.elementWizards, org.eclipse.net4j.connectors:jvm]
org.eclipse.net4j.bufferProviders[default]=Factory[org.eclipse.net4j.bufferProviders, default]
org.eclipse.net4j.acceptors[tcp]=Factory[org.eclipse.net4j.acceptors, tcp]
org.eclipse.net4j.util.ui.elementWizards[org.eclipse.net4j.connectors:tcp]=Factory[org.eclipse.net4j.util.ui.elementWizards, org.eclipse.net4j.connectors:tcp]
org.eclipse.net4j.util.ui.elementWizards[org.eclipse.net4j.acceptors:tcp]=Factory[org.eclipse.net4j.util.ui.elementWizards, org.eclipse.net4j.acceptors:tcp]
org.eclipse.net4j.connectors[tcp]=Factory[org.eclipse.net4j.connectors, tcp]
org.eclipse.net4j.executorServices[default]=Factory[org.eclipse.net4j.executorServices, default]
org.eclipse.net4j.buddies.serverFacilities[chat]=Factory[org.eclipse.net4j.buddies.serverFacilities, chat]
org.eclipse.net4j.util.timers[daemon]=Factory[org.eclipse.net4j.util.timers, daemon]
org.eclipse.net4j.selectors[tcp]=Factory[org.eclipse.net4j.selectors, tcp]
container = ManagedContainer
extensionRegistryListener = org.eclipse.net4j.internal.util.factory.PluginFactoryRegistry$1@13e10bc
main [debug.lifecycle] Activating []
main [debug.om] Starting bundle org.eclipse.net4j.tcp
main [debug.lifecycle.dump] DUMP PluginElementProcessorList
processors =
org.eclipse.net4j.TransportInjector@47c92
org.eclipse.net4j.signal.heartbeat.HeartBeatProtocol$Server$TimerInjector@8e595a
org.eclipse.net4j.internal.tcp.TCPSelectorInjector@18c5435
extensionRegistryListener = org.eclipse.net4j.internal.util.container.PluginElementProcessorList$1@1ec8e6d
main [debug.lifecycle.dump] DUMP PluginContainer
ManagedContainer.factoryRegistry =
ManagedContainer.postProcessors =
ManagedContainer.elementRegistry =
main [debug.om] Plugin container created: ManagedContainer
main [debug.om] Starting bundle org.eclipse.net4j.util.ui
main [debug.om] Starting bundle org.eclipse.net4j.buddies.ui
main [debug.lifecycle] Activating SessionManager
main [debug.om] Starting bundle org.eclipse.net4j.buddies.common
main [debug.lifecycle.dump] DUMP SessionManager
session = null
state = DISCONNECTED
connecting = false
flashing = false
main [debug.om] Starting bundle org.eclipse.net4j.ui.shared
Application Started: 13341
buddies-connector [debug.connector] Setting userID null for TCPClientConnector[localhost:2 036]
buddies-connector [debug.lifecycle] Activating BufferPool[4 096]
buddies-connector [debug.lifecycle.dump] DUMP BufferPool
BufferProvider.bufferCapacity = 4096
BufferProvider.providedBuffers = 0
BufferProvider.retainedBuffers = 0
provider = BufferFactory[4 096]
pooledBuffers = 0
buddies-connector [debug.lifecycle] Activating TCPSelector
buddies-connector [debug.lifecycle.dump] DUMP TCPSelector
selector = sun.nio.ch.WindowsSelectorImpl@117c544
clientOperations =
serverOperations =
thread = Thread[TCPSelector,6,main]
running = true
buddies-connector [debug.lifecycle] Activating TCPClientConnector[localhost:2 036]
buddies-connector [debug.connector] Setting state CONNECTING (was disconnected) for TCPClientConnector[localhost:2 036]
buddies-connector [debug.lifecycle] Activating Channel[Control, CLIENT]
buddies-connector [debug.lifecycle] Activating ReceiveSerializer
buddies-connector [debug.lifecycle.dump] DUMP ReceiveSerializer
Worker.daemon = true
Worker.activationTimeout = 10000
Worker.deactivationTimeout = 10000
QueueWorker.queue =
QueueWorker.pollMillis = 100
buddies-connector [debug.lifecycle.dump] DUMP ControlChannel
Channel.userID = null
Channel.channelMultiplexer = TCPClientConnector[localhost:2 036]
Channel.id = 0
Channel.receiveExecutor = java.util.concurrent.ThreadPoolExecutor@d0892[Running, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0]
Channel.receiveHandler = null
Channel.receiveSerializer = ReceiveSerializer
Channel.sendQueue =
Channel.sentBuffers = 0
Channel.receivedBuffers = 0
acknowledgements = SynchronizingCorrelator{}
buddies-connector [debug] Ordering client operation REGISTER java.nio.channels.SocketChannel[unconnected]
TCPSelector [debug] Executing client operation REGISTER java.nio.channels.SocketChannel[unconnected]
TCPSelector [debug] Registering java.nio.channels.SocketChannel[unconnected]
buddies-connector [debug.lifecycle.dump] DUMP TCPClientConnector
ChannelMultiplexer.config = TransportConfig[receiveExecutor=java.util.concurrent.ThreadPoolExecutor@d0892[Running, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0], bufferProvider=BufferPool[4 096], protocolProvider=org.eclipse.net4j.ContainerProtocolProvider$Client@54e88c, negotiator=null]
ChannelMultiplexer.openChannelTimeout = -1
ChannelMultiplexer.channels =
Connector.userID = null
Connector.connectorState = CONNECTING
TCPConnector.socketChannel = java.nio.channels.SocketChannel[unconnected]
TCPConnector.selector = TCPSelector
TCPConnector.writeQueue =
TCPConnector.inputBuffer = null
TCPConnector.controlChannel = Channel[Control, CLIENT]
TCPConnector.host = localhost
TCPConnector.port = 2036
TCPSelector [debug] Connecting java.nio.channels.SocketChannel[connection-pending remote=localhost/127.0.0.1:2036]
Exception in thread "buddies-connector" org.eclipse.net4j.util.lifecycle.LifecycleException: Could not activate TCPClientConnector[localhost:2 036]
at org.eclipse.net4j.util.container.ManagedContainer.activateElement(ManagedContainer.java:355)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:325)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:301)
at org.eclipse.net4j.Net4jUtil.getConnector(Net4jUtil.java:81)
at org.eclipse.net4j.Net4jUtil.getConnector(Net4jUtil.java:98)
at org.eclipse.net4j.Net4jUtil.getConnector(Net4jUtil.java:117)
at org.eclipse.net4j.internal.buddies.SessionManager$1.run(SessionManager.java:116)
[Updated on: Sun, 27 October 2013 17:20] by Moderator
Re: Understanding Net4j [message #1165412 is a reply to message #1157785] |
Fri, 01 November 2013 05:04   |
Sorry for the late reply. The launch configs are a little out-dated. In the server launch you need to add the
org.eclipse.emf.cdo.server.net4j plugin and its required plugins. In the clients that you launch make sure that you
first go to the preferences and use unique userIDs in the Net4j Buddies settings of each client. Then make sure that you
also open the Collaborations view.
After years this example system could need some polishing, but unfortunately I have no time. If you want to work a
little on it your contributions would be welcome ;-)
Cheers
/Eike
http://www.esc-net.de
Am 27.10.2013 14:11, schrieb UmaShankar Subramani:
> Hi Eike,
> HashMapRegistry.map = org.eclipse.net4j.acceptors[ssl]=Factory[org.eclipse.net4j.acceptors, ssl]
> interactive]
> processors = mailto:org.eclipse.net4j.TransportInjector@47c92
> mailto:org.eclipse.net4j.internal.tcp.TCPSelectorInjector@18c5435
> ManagedContainer.factoryRegistry = org.eclipse.net4j.acceptors[ssl]=Factory[org.eclipse.net4j.acceptors, ssl]
> interactive]
> ManagedContainer.postProcessors = mailto:org.eclipse.net4j.TransportInjector@47c92
> session = null
> connecting = false
> flashing = false
> pooledBuffers = 0
> selector = mailto:sun.nio.ch.WindowsSelectorImpl@117c544
> clientOperations = serverOperations = thread = Thread[TCPSelector,6,main]
> running = true
> QueueWorker.queue = QueueWorker.pollMillis = 100
> Channel.id = 0
> Channel.receiveExecutor = mailto:java.util.concurrent.ThreadPoolExecutor@d0892[Running, pool size = 0, active threads
> Channel.sendQueue = Channel.sentBuffers = 0
> TransportConfig[receiveExecutor=mailto:java.util.concurrent.ThreadPoolExecutor@d0892[Running, pool size = 0, active
> ChannelMultiplexer.channels = Connector.userID = null
> TCPConnector.writeQueue = TCPConnector.inputBuffer = null
Re: Understanding Net4j [message #1169802 is a reply to message #1167445] |
Mon, 04 November 2013 02:44   |
Am 02.11.2013 18:24, schrieb UmaShankar Subramani:
> Hi Eike,
> Thanks for your reply. Now, the Buddies Example is working fine.
> It works only in the "Modeling Eclipse". I am okay with the "Modelling Eclipse", where I can run BuddiesExample
> without any problem. But I am curious to know abount running BuddiesExample on the "Classic Eclipse".
> What are the plugins should I install. When I tried to install just "Net4j Signalling Platform" alone it obviously
> did not work. So, I think CDO should also be installed.
> Is it not possible to use "Net4j Sinalling Platform" without CDO's support even today?
Net4j can perfectly run without CDO because it doesn't have any dependencies on it. Only the Buddies example uses CDO's
server/config file mechanism, which I think is acceptale for an example.
> Finally, I am really happy to Contribute to Eclipse. I can do the polishing thing for this BuddiesExample. I am also
> thinking about making a tutorial for installing "Net4j Signalling Platform", using the Buddies Example, with steps.
That would be awesome. Send me a link when you want me to review it.
Cheers
/Eike
Current Time: Sat Jul 26 06:18:11 EDT 2025
Powered by FUDForum. Page generated in 0.07403 seconds
