| Engine API Example [message #115624] |
Wed, 25 January 2006 08:44  |
Originally posted by: martyn.bedford.greenhatconsulting.com
I have been using a standalone java class based heavily on the integration
example for version 1, with the advent of version 2 it does not work and I
get the following console output.
25-Jan-2006 13:25:12
org.eclipse.birt.report.model.metadata.ExtensionLoader load
SEVERE: Message:The extension point
[org.eclipse.birt.report.model.reportItemModel] is not found. Error
code:EXTENSION_POINT_NOT_FOUND
25-Jan-2006 13:25:13
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper openReportDesign
SEVERE: invalid design file C:\Documents and
Settings\mbedford.GREENHAT\workspace\Scratch\Status.rptdesig n
Report Status.rptdesign not found!
the command line example works and I can use it to generate a html report
from this rptdesign file so I am assuming ;) that all is well with the the
report file.
There does not appear to be a version 2 specific integration example,
before I spend loads of time trying to fix this am I doing somthing stupid.
Martyn
FUDForum. Page generated in 0.04291 seconds
