Home » Eclipse Projects » Eclipse Platform » Contributing to eclipse.ini (from plugin?)
Contributing to eclipse.ini (from plugin?) [message #1153371] |
Thu, 24 October 2013 11:11  |
I need an ability to optionally add some arguments to eclipse's JVM (-javaagent option to be more precise). As far as I know, JVM's options are configured from the eclipse.ini file. Is there any standard way I can contribute an entry into eclipse.ini from a plugin?
Asking user to modify his config is acceptable, but I think an automated way is much better.
[Updated on: Thu, 24 October 2013 12:05] by Moderator
Re: Contributing to eclipse.ini [message #1160449 is a reply to message #1159481] |
Tue, 29 October 2013 02:11   |
IIRC p2 can write there!
Tom
On 28.10.13 16:14, Ed Merks wrote:
> So no, there isn't a standard way. You'd have to manipulate that file
> textually.
> On 28/10/2013 3:12 PM, Bug Menot wrote:
>> Ed Merks wrote on Sat, 26 October 2013 06:23
>>> If you're doing something in a plugin, the ini has already been used
>>> so it would be too late (for that JVM) and a restart would be
>>> required, right? I.e., JVM arguments are processed by the JVM before
>>> anything else happens in code that you run in that JVM...
>> yeah, I understand that, and asking user for reboot is reasonable
Re: Contributing to eclipse.ini [message #1160814 is a reply to message #1160449] |
Tue, 29 October 2013 07:19   |
Tom,
Really?! What's the API for that? This would be useful for the
installer tool Eike and I are working on where we're already using P2 to
install things...
> Tom
>> textually.
Re: Contributing to eclipse.ini [message #1162520 is a reply to message #1160814] |
Wed, 30 October 2013 08:35  |
Damn, it's the config.ini that p2 modifies :-( But if someone has API
for that then it is p2.
Tom
On 29.10.13 12:19, Ed Merks wrote:
> Tom,
> install things...
>> Tom
>>> textually.
Current Time: Sat Jul 26 03:19:16 EDT 2025
Powered by FUDForum. Page generated in 0.70894 seconds
