Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Update database schema with Teneo/Hibernate
Update database schema with Teneo/Hibernate [message #115490] |
Sun, 23 March 2008 14:10  |
Originally posted by: schlamp.medihack.org
The question belongs a bit more to Hibernate than Teneo, but I think it
must be quite a common database problem especially for Rich Client
Applications.
When I have to change my EMF model, that is persisted with
Teneo/Hibernate, for a new version of my application, then what is the
best way to update the database schema?
As I understand, the automatic Hibernate updater is very limited (e.g.
can't delete columns or whole tables).
I found an interesting 4 year old discussion on the Hibernate message
board, but without any good solution.
How do developers solve this problem now? I there a good sql dialect
independent solution? Any suggestions?
Kai
Re: Update database schema with Teneo/Hibernate [message #115513 is a reply to message #115490] |
Sun, 23 March 2008 16:15   |
Hi Kai,
It is true that hibernate won't delete tables or columns. On the other hand it will add columns and
tables (but not indexes). Many times this is sufficient, tables and columns which are not used
anymore are ignored and this works fine (as long as the columns are nullable ofcourse).
For me the hibernate update mode has been sufficient. I do not know of any other/better way.
Although if you find one then I would be interested to hear of it to :-).
gr. Martin
> Applications.
> Best regards,
> Kai
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Update database schema with Teneo/Hibernate [message #115540 is a reply to message #115513] |
Sun, 23 March 2008 20:06  |
Teneo allow to export/import a datastore in xmi format, which is very
helpful. After the export you can drop/recreate the database, or use
hibernate to drop/create the schema. Most of the time, it is very helpful
if you have for example column length changes.
But if you have for example in column name, or other more complicated
changes in the mapping, I recommend to export the datastore from with the
old version of your application, and to export the xmi with the new
version.
The only problem is when you have a lot of data, because your hibernate
resource will very memory and time consuming. But you can export/import
subset of the datastore, by modifying for example the computeTopEntities of
the datastore.
Matthieu Helleboid.
Martin Taal wrote:
> Hi Kai,
> hand it will add columns and tables (but not indexes). Many times this is
> sufficient, tables and columns which are not used anymore are ignored and
> this works fine (as long as the columns are nullable ofcourse). For me the
> other/better way. Although if you find one then I would be interested to
> hear of it to :-).
> gr. Martin
>> Applications.
>> Best regards,
>> Kai
Re: Update database schema with Teneo/Hibernate [message #615962 is a reply to message #115490] |
Hi Kai,
gr. Martin
> Applications.
> Best regards,
> Kai
The Netherlands
Re: Update database schema with Teneo/Hibernate [message #615964 is a reply to message #115513] |
version.
the datastore.
Matthieu Helleboid.
Martin Taal wrote:
> Hi Kai,
> hear of it to :-).
> gr. Martin
>> Applications.
>> Best regards,
>> Kai
Current Time: Wed Sep 17 12:49:38 EDT 2025
Powered by FUDForum. Page generated in 0.09062 seconds
