Strange behavoir with Text since last CVS update [message #115349] |
Thu, 11 December 2008 11:09  |
today I update from CVS.
But now the Text-Widget behaves very strange.
When i click in it, type nothing and click after out of it, for example
on a button, I get a java.lang.NumberFormatException.
Here is the Stacktrace:
java.lang.NumberFormatException: For input string: "undefined"
at
java.lang.NumberFormatException.forInputString(NumberFormatE xception.java:48)
at java.lang.Integer.parseInt(Integer.java:447)
at java.lang.Integer.parseInt(Integer.java:497)
at
org.eclipse.swt.internal.widgets.textkit.TextLCAUtil.readSel ection(TextLCAUtil.java:95)
at
org.eclipse.swt.internal.widgets.textkit.TextLCAUtil.readTex tAndSelection(TextLCAUtil.java:54)
at
org.eclipse.swt.internal.widgets.textkit.SingleTextLCA.readD ata(SingleTextLCA.java:36)
at
org.eclipse.swt.internal.widgets.textkit.TextLCA.readData(Te xtLCA.java:36)
at
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA$1.doV isit(DisplayLCA.java:322)
at
org.eclipse.swt.internal.widgets.WidgetTreeVisitor$AllWidget TreeVisitor.visit(WidgetTreeVisitor.java:28)
at
org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(Wi dgetTreeVisitor.java:59)
at
org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(Wi dgetTreeVisitor.java:51)
at
at
at
at
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.readD ata(DisplayLCA.java:329)
at org.eclipse.rwt.internal.lifecycle.ReadData.execute(ReadData .java:26)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.continueLife Cycle(RWTLifeCycle.java:206)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.sleep(RWTLif eCycle.java:307)
at org.eclipse.swt.widgets.Display.sleep(Display.java:706)
at
org.eclipse.ui.application.WorkbenchAdvisor.eventLoopIdle(Wo rkbenchAdvisor.java:361)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2347)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:425)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:408)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at com.mycompany.rap.Application.createUI(Application.java:15)
at
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:228)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
at java.lang.Thread.run(Thread.java:613)
FUDForum. Page generated in 0.03598 seconds
