Home » Eclipse Projects » Eclipse Platform » Relative path of resource in plugin
Relative path of resource in plugin [message #115241] Fri, 22 August 2003 23:53 Go to next message
I am developing a plugin that depends on a schema file. I ship the schema
file along with the plugin distribution - so I will have something like:
ECLIPSE_HOME/plugins/com.mycompany.myplugin/xml/myschema.xsd
How do I refer to this schema location programatically in my plugin? Is
there a "ECLISPE_HOME" property that I could access? Basically I need to
know the location of where my plugin is installed and then accesss the
schema file relative to that location. Also, how does one do this when
testing the plugin with the run-time workbench?
Vijay
Re: Relative path of resource in plugin [message #115256 is a reply to message #115241] Sat, 23 August 2003 00:29 Go to previous messageGo to next message
Originally posted by: paull.NOSPAMcodetelligence.com
Can you use something like this (with your plugin name)?
MyPlugin.getDefault().getDescriptor().getInstallURL()
Paul
"Vijay Ganesan" <vijay@mindspring.com> wrote in message
news:bi6ofc$iol$1@eclipse.org...
> Thanks
> Vijay
Re: Relative path of resource in plugin [message #115441 is a reply to message #115256] Sat, 23 August 2003 10:24 Go to previous messageGo to next message
I had tried that before but getInstallURL() for my plugin gives:
platform:/plugin/com.x.myplugin_1.0.0/
I need to reference the xml/myschema.xsd file which is at:
ECLIPSE_HOME/plugins/com.x.myplugin_1.0.0/xml/myschema.xsd
Don't know how to go from the URL to this file location.
Vijay
"Paul L" <paull@NOSPAMcodetelligence.com> wrote in message
news:bi6qi8$juh$1@eclipse.org...
> Paul
schema
> > Thanks
> > Vijay
Re: Relative path of resource in plugin [message #115462 is a reply to message #115241] Sat, 23 August 2003 10:26 Go to previous messageGo to next message
You can start with the plugin registry and locate your own plugin.
This will allow you to access your own files, like the schema
Methods in org.eclipse.core.runtime that return IPluginRegistry
static IPluginRegistry Platform.getPluginRegistry()
Returns the plug-in registry for this platform.
Chris Laffra
> Thanks
> Vijay
Re: Relative path of resource in plugin [message #115487 is a reply to message #115462] Sat, 23 August 2003 14:08 Go to previous messageGo to next message
Locating the plugin is no problem. From the plugin registry, what methods do
I use to get to the relative location of my plugin specific schema file? I
can get the plugin descriptor from which I can getInstallURL() which brings
me back to my previous question. (See my previous post)
thanks
Vijay
"Chris Laffra" <Chris_Laffra@oti.com> wrote in message
news:bi7thi$9ml$1@eclipse.org...
> Chris Laffra
schema
> > Thanks
> > Vijay
Re: Relative path of resource in plugin [message #115498 is a reply to message #115441] Sat, 23 August 2003 16:14 Go to previous messageGo to next message
ok I figured it out.
URL installURL = myPlugin.getDefault().getDescriptor().getInstallURL()
URL fileURL = new URL(installURL, "xml/myschema.xsd")
URL locURL = Platform.asLocalURL(fileURL)
String fname = locURL.getFile()
Vijay
news:bi7tdi$9jj$1@eclipse.org...
> Vijay
> > Paul
> schema
like:
Is
to
> > > Thanks
> > > Vijay
Re: Relative path of resource in plugin [message #115511 is a reply to message #115487] Sat, 23 August 2003 16:18 Go to previous message
Did you try Platform.getLocation() ?
news:bi8ain$i98$1@eclipse.org...
do
brings
> thanks
> Vijay
> > Chris Laffra
> schema
like:
Is
to
> > > Thanks
> > > Vijay
Previous Topic:Change Eclipse Default Menu Labels
Next Topic:Problems with plugin as RMI client
Current Time: Sun Nov 09 04:00:04 EST 2025
Powered by FUDForum. Page generated in 0.04965 seconds
