Home » Eclipse Projects » GEF » ...gef.ui.actions.DeleteAction not found
...gef.ui.actions.DeleteAction not found [message #115339] Tue, 03 February 2004 10:59 Go to next message
I am trying to run the NetworkEditor from the RED BOOK, using EMF and GEF.
When I try to create a document of the type .network I get a java
NoSuchMethodError for ...get.ui.actions.DeleteAction.
I have installed 2.1.2 GEF and am running Eclipse 2.1.2.
Any ideas..?
Mark.
Re: ...gef.ui.actions.DeleteAction not found [message #115352 is a reply to message #115339] Tue, 03 February 2004 11:32 Go to previous messageGo to next message
And which method is it that is missing? Are you compiling the source
yourself? You should have a compoile error.
"Mark Geib" <mark.geib@echostar.com> wrote in message
news:bvogh6$119$1@eclipse.org...
> Any ideas..?
> Mark.
Re: ...gef.ui.actions.DeleteAction not found [message #115364 is a reply to message #115352] Tue, 03 February 2004 11:36 Go to previous messageGo to next message
I assume the DeleteAction method...
I have done a complete rebuild of the project, no compiler error.
Mark.
> > Any ideas..?
> > Thanks,
> > Mark.
Re: ...gef.ui.actions.DeleteAction not found [message #115377 is a reply to message #115339] Tue, 03 February 2004 11:55 Go to previous messageGo to next message
Is it possible that the classpath for the runtime workbench is not
correct..? Since I have compile errors it seems to be runtime only.
Mark
> Any ideas..?
> Mark.
Re: ...gef.ui.actions.DeleteAction not found [message #115384 is a reply to message #115377] Tue, 03 February 2004 12:02 Go to previous message
Sorry, that was it.
I checked the library list for the plugin developement target platform,
and the new version of GEF was not listed. I restarted Eclipse and
everything is working.
Mark.
> Mark
> > Any ideas..?
> > Thanks,
> > Mark.
Previous Topic:DND
Next Topic:Connection Problems
Current Time: Sun Nov 09 01:32:37 EST 2025
Powered by FUDForum. Page generated in 0.03797 seconds
