Home » Archived » Hudson » how to deploy a war file to a glassfish 3.1 server using hudson
how to deploy a war file to a glassfish 3.1 server using hudson [message #1140595] Wed, 16 October 2013 09:19 Go to next message
Hi can any one help me to deploy a .war file in a glassfish 3.1 server using hudson.
Iam able to create a .war file using ant in hudson.
And under Post-build Actions i have done following settings.
Apart from these do i need to do any other settings
WAR/EAR files --------> war name
Context path
Container -----glassfish3.1
Manager user name------ username
Manager password ------passwd
GlassFish home -----path
GlassFish admin port --port
GlassFish hostname -----localhost
thanks
Dhanu
Re: how to deploy a war file to a glassfish 3.1 server using hudson [message #1152393 is a reply to message #1140595] Wed, 23 October 2013 21:08 Go to previous message
That seems to be correct. I've create a war (using maven, not ant) and deployed with the following settings
https://dl.dropboxusercontent.com/u/13144273/Glassfish%20Deploy%20Settings.png
After successful build, I got
Deploying /Users/wjprakash/Hudson/Hudson3-plugins/deploy-plugin/work/jobs/glassfish-test/workspace/target/MavenWarProjetcForHudson-1.0-SNAPSHOT.war to container GlassFish 3.x Remote
Finished: SUCCESS
Also I looked at the deployed applications via glassfish admin console and saw the deployed application (tested it and it worked fine Smile )
https://dl.dropboxusercontent.com/u/13144273/Glassfish%20Deployed%20Application.png
Note: The deploy plugin may not work correctly in a slave. If you have to create the war in a slave, the best bet is to archive the war and use another job that is tied to the master and copy the archive from previous job using copy artifacts plugin and then deploy the war.
Previous Topic:Hudson job with Maven 3.1.0
Next Topic:Deploy to Wildfly (jBoss 8.x?)
Current Time: Thu Jul 24 20:44:23 EDT 2025
Powered by FUDForum. Page generated in 0.24154 seconds
