Home » Archived » Tigerstripe » Refactoring
| Refactoring [message #11507] |
Wed, 09 July 2008 11:23  |
Dear all,
while trying to import from XMI, I had an object for which I had to choose
the artefact. I choose Entity, but after loading, I got the message Key
not found and I realized it should have being a Datatype artefact.
How can I change from an artefact to another?
I looked into Refactor, but there is just rename and move.
Marc
| Re: Refactoring [message #11543 is a reply to message #11507] |
Wed, 09 July 2008 11:39   |
Hi Marc,
There used to be an additional entry in the refactor menu to do that, but it
was mostly broken, so we took it out as part of the open-source move.
The initial design was wrong in that you'd be able to refactor from anything
to anything whereas some refactor don't make sense (association to entity
makes no sense).
So, what we need is "refactoring options that make sense based on the
starting point". For example:
- Entity<->Datatype
- Association<->Dependency
- Association<->AssociationClass
- Datatype<->Query<->UpdateProc<->Event
Bug 221443 covers the refactoring from Association to Association Class.
And should be extended to address the other cases.
Does that make sense to you?
Eric
On 7/9/08 8:23 AM, in article
32fc6d642c0af7145037a4b5f3bfa794$1@www.eclipse.org, "Marc FLAUW"
<marc.flauw@hp.com> wrote:
> Dear all,
> Marc
| Re: Refactoring [message #11580 is a reply to message #11543] |
Wed, 09 July 2008 11:44   |
Now... A work around would be for you to edit the .java file for that thing.
Change the top level tag from
@tigerstripe.managedEntity to @tigerstripe.datatype.
Save it and open it with the Tigerstripe Explorer, and make a tiny change
(description e.g.) to force it to reparse/save it.
This is a hack... But in the meantime it may help :-).
Eric
On 7/9/08 8:39 AM, in article C49A29A7.652B%erdillon@cisco.com, "Eric
Dillon" <erdillon@cisco.com> wrote:
> Hi Marc,
> makes no sense).
> - Entity<->Datatype
> Eric
>> Dear all,
>> Thanks,
>> Marc
| Re: Refactoring [message #11651 is a reply to message #11616] |
Thu, 10 July 2008 10:07  |
Go ahead with the enhancement bug :-)
Eric
On 7/10/08 3:36 AM, in article
f07a06a2ce83c208af4f8e7e84d1bdad$1@www.eclipse.org, "Marc FLAUW"
> Eric,
> Thanks for the response.
> I know the hack. I used it already, but today, I am just playing with the
> SID model so I don't have the time to hack each file.
> I understand the concern around refactoring, but I had this exact need
> with the model import: I don't know exactly what X is, so let's make it an
> entity and then Tigerstripe complain about no key after the import is
> completed and you realize that it should have been a datatype.
> So this situation is likely to happen. I agree we need to restrict what we
> can refactor to, as some combinations don't make sense.
> Do you want me to open an enhancement bug?
> Marc
| Re: Refactoring [message #563531 is a reply to message #11507] |
Hi Marc,
makes no sense).
- Entity<->Datatype
Eric
> Dear all,
> Marc
| Re: Refactoring [message #563555 is a reply to message #11543] |
Eric
> Hi Marc,
> makes no sense).
> - Entity<->Datatype
> Eric
>> Dear all,
>> Thanks,
>> Marc
| Re: Refactoring [message #563579 is a reply to message #11580] |
Thu, 10 July 2008 06:36  |
Eric,
Marc
| Re: Refactoring [message #563605 is a reply to message #11616] |
Eric
> Eric,
> Marc
Current Time: Mon Nov 10 09:12:45 EST 2025
Powered by FUDForum. Page generated in 0.04619 seconds
