Namespace information lost in reference [message #1150149] |
Tue, 22 October 2013 11:23  |
I have a problem with an ecore-model generated from a xml-schema. The source-schema is for the speech synthesis markup language ssml. I took the xsd-files, generated a model and generated editor code for this model. With the generated ssml-editor everything works fine. Here an example of the code:
<speech_synthesis:speak xmlns:speech_synthesis="http://www.w3.org/2001/10/synthesis">this is a<speech_synthesis:s>test</speech_synthesis:s></speech_synthesis:speak>
You can see, that here the namespace information for all elements is available. Now I tried to add the DocumentRoot class of this generated model to another model, by defining a reference. The result of the file, created by the editor is now this one:
<presentation xsi:type="io:SpeechSynthesis" device="speaker" modality="speech" language="de-DE">
<ssmlDocument>
<speak>
this is a
<s>
test
<s/>
</speak>
</ssmlDocument>
</presentation>
You can see that the namespace information is missing. This is not only a problem for me, it makes it impossible to reload this file into the editor:
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 's' not found.
Any idea how to solve this issue?
Thanks a lot,
Robert
[Updated on: Tue, 22 October 2013 11:29] by Moderator
Re: Namespace information lost in reference [message #1150232 is a reply to message #1150149] |
Tue, 22 October 2013 12:34   |
Robert,
Comments below.
On 22/10/2013 5:23 PM, Robert Neßelrath wrote:
Hmm. That doesn't really make sense if you want some well formed XML
that conforms to the schema.... In XML Schema you'd refer to some
global element of another schema, so you need to do something that
matches this approach.
> modality="speech" language="de-DE" utterance="Willkommen beim
> Sprach-Browser von BMW">
> <ssmlDocument>
> <speak>
> this is a <s>
> test
> <s/>
> </speak>
> </ssmlDocument>
> </presentation>
> the editor:
> found.
Yes, it's all not sensible.
Are you writing this other model directly in Ecore? Better you write a
small schema instead (even export your Ecore's corresponding *.genmodel
to an XML Schema and ensure that you use a global element from your
other schema or use a complex type from your other schema. Don't use
the DocumentRoot like this. It only functions, as the name implies, as
the root object in a resource/document...
> Thanks a lot,
> Robert
Re: Namespace information lost in reference [message #1151313 is a reply to message #1150232] |
Wed, 23 October 2013 05:04  |
The other model is written in Ecore, quite complex and linked to several other models. So I prefered not to write or generate a schema for this. If I add not the DocumentRoot but the first element of it instead, I face the same problem. But I have found a solution for the problem by creating a small example ecore model, that refers to the DocumentRoot. Here it worked correclty and the only difference was the Model Resource Type setting in the genmodel. After changing this from XMI to XML in the more complex model it also adds the namespaces to the serialized model.
FUDForum. Page generated in 0.03646 seconds
