Home » Modeling » EMF » XSD to ECore generation: 'group' attribute for every 'xsd:choice'(When an xsd type has a xsd:choice of elements, EAttribute 'group' is generated in ecore for such a type)
XSD to ECore generation: 'group' attribute for every 'xsd:choice' [message #1149853] Tue, 22 October 2013 06:59 Go to next message
Say we have a following xsd:
<xsd:schema xmlns:xsd="less that 5 posts, no links" xmlns:jxb="" xmlns:fn="" xmlns:xs="" xmlns:fo="">
	<xsd:complexType name="oauth20">
		<xsd:choice minOccurs="0" maxOccurs="unbounded">
			<xsd:element name="group" type="oauth20.group">
			</xsd:element>
		</xsd:choice>
	</xsd:complexType>
	<xsd:complexType name="oauth20.group">
	</xsd:complexType>
	<xsd:element name="oauth" type="oauth20" />
</xsd:schema>
Because it has '<xsd:choice>' and not an '<xsd:sequence>', after ecore generation that type has an additional structural feature:
<eStructuralFeatures xsi:type="ecore:EAttribute" name="group" unique="false" upperBound="-1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EFeatureMapEntry">
That wouldn't be that big of a problem if xsd didn't have and element with a name 'group'.
But right now it gets 'group1' name like this:
<eStructuralFeatures xsi:type="ecore:EReference" name="group1" upperBound="-1"
        eType="#//Oauth20Group" volatile="true" transient="true" derived="true" containment="true" resolveProxies="false">
So why do we need such a feature, and how to work around this problem? Replace all xsd:choice with xsd:sequence? Delete all EAttribues 'group' from ecore?
Any light is appreciated.
Re: XSD to ECore generation: 'group' attribute for every 'xsd:choice' [message #1150225 is a reply to message #1149853] Tue, 22 October 2013 12:28 Go to previous messageGo to next message
Roman,
Comments below.
> </xsd:element>
> </xsd:choice>
> </xsd:complexType>
> </xsd:complexType>
> </xsd:schema>
No, it's because it's a group with a maxOccurs > 1
You can use annotations to choose the name.
> upperBound="-1"
To preserve the mixed order, of the elements though this degenerate case
of a single element is odd. Why is it like this? Why not put the
multiplicities on the element....
> xsd:sequence?
No, but if you can eliminate a maxOccurs on a model group, that would be
good.
No.
If you must haven them, you can choose the names using annotations.
Re: XSD to ECore generation: 'group' attribute for every 'xsd:choice' [message #1150245 is a reply to message #1150225] Tue, 22 October 2013 12:44 Go to previous message
Thanks for the response. I've simplified xsd to reduce the noice. There's never a single element under 'xsd:choice'.
It's more like this:
<xsd:complexType name="sharedlibrary">
            <xsd:element name="fileset" type="sharedlibrary.fileset">
                <xsd:annotation>
                    <xsd:documentation>Id of referenced Fileset</xsd:documentation>
                    <xsd:appinfo>
                        <ext:label>Fileset</ext:label>
                    </xsd:appinfo>
                </xsd:annotation>
            </xsd:element>
            <xsd:element name="folder" type="sharedlibrary.folder">
                <xsd:annotation>
                    <xsd:documentation>Id of referenced folder</xsd:documentation>
                    <xsd:appinfo>
                        <ext:label>Folder</ext:label>
                    </xsd:appinfo>
                </xsd:annotation>
            </xsd:element>
            <xsd:element name="file" type="sharedlibrary.file">
                <xsd:annotation>
                    <xsd:documentation>Id of referenced File</xsd:documentation>
                    <xsd:appinfo>
                        <ext:label>File</ext:label>
                    </xsd:appinfo>
                </xsd:annotation>
            </xsd:element>
        </xsd:choice>
and 30k lines more.
I'll try 'choose the names using annotations'. Right now all 'xsd:choice' are replaced by 'xsd:sequence' and multiplicities are on the elements.
This
EStructuralFeature feature = eObject.eClass().getEStructuralFeature(featureName);
is much better than this
EList eAllStructuralFeatures = eObject.eClass().getEAllStructuralFeatures();
	for (int i = 0; i < eAllStructuralFeatures.size(); i++) {
		if (featureName.equals(EcoreUtil.getAnnotation(
			(EModelElement) eAllStructuralFeatures.get(i), EXTENDED_META_DATA_URI, NAME_KEY))) {
			feature = (EStructuralFeature) eAllStructuralFeatures.get(i);
Thanks again.
[Updated on: Wed, 23 October 2013 05:43] by Moderator
Previous Topic:Does ChangeRecorder record inverted ChangeKind about ResourceChange?
Next Topic:cdo server on windows xp
Current Time: Sat Jul 26 22:26:27 EDT 2025
Powered by FUDForum. Page generated in 0.06021 seconds
