Code generation problem [message #1128150] |
Mon, 07 October 2013 07:49  |
Hello everybody.
I am developing plugins for Eclipse using Xtext and I have to use code-generation quite a lot. For example, whenever I add\change some source files of type 'A', I have to generate a source file 'B' for each of A's. Obviously, I would like to avoid rebuilding the workspace after saving every B-file. However, I can't get it right.
From manuals\FAQs I have learnt that for performing multiple modifications I should use IWorkspaceRunnable type of job in such a situation, however, it does not work the way I want. Namely, the task gets cancelled after saving a single file, and then gets restarted again, which causes an auto-build on each generated file. No surprise, if I have 200 'A' sources, auto-build job is launched 200 times.
Thus, right now the structure of my code is the following (pseudo):
class MyBuilderParticipant implements IXtextBuilderParticipant {
public void build(final IBuildContext context, final IProgressMonitor monitor) {
if (!isEnabled(context)) {
return;
final int numberOfDeltas = context.getDeltas().size();
SubMonitor progress = SubMonitor.convert(monitor, numberOfDeltas);
for (int i = 0; i < numberOfDeltas; i++) {
if (progress.isCanceled()) {
throw new OperationCanceledException();
// generate and store in memory a file for each delta
// store generator results
final IWorkspaceRunnable runnable = new IWorkspaceRunnable() {
public void run(final IProgressMonitor monitor) {
try {
foreach (GeneratedFile file : generatedFiles) {
// store all the generated files in workspace
progress.worked(1);
} finally {
if (monitor != null) {
monitor.done();
ISchedulingRule rule = context.getBuiltProject();
try {
ResourcesPlugin.getWorkspace().run(runnable, rule, IWorkspace.AVOID_UPDATE, monitor);
} catch (CoreException e) {
throw new WrappedException(e);
For some reason, on the second iteration of the loop in IWorkspaceRunnable the task gets cancelled and build method gets invoked again later on. What do I do wrong?
Re: Code generation problem [message #1149549 is a reply to message #1128150] |
Tue, 22 October 2013 02:35  |
The BuilderParticipant is called during a build, in which you can change
the workspace as it seems fit, that is you shouldn't wrap the code
generation in a runnable. The changes would even be ignored (no deltas
and subsequent builds) unless you call needsRebuild on the IBuildContext.
Am 10/7/13 2:29 PM, schrieb Maksim Rubanov:
> Hello everybody.
> monitor) {
> return;
> try {
> progress.worked(1);
> } finally {
> monitor.done();
> try {
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
FUDForum. Page generated in 0.26196 seconds
