Home » Eclipse Projects » GEF » In orphan-add process, can the child editpart be copied instead of move?
In orphan-add process, can the child editpart be copied instead of move? [message #114639] |
Thu, 29 January 2004 05:12  |
Originally posted by: sckimos.enet.co.kr
Hi, all.
I want the child editpart to be copied, when Ctrl key is pressed while
orphan-add process.
I've pressed the Ctrl key while draging the editpart, but it is still
moved...
Is there any method to copy editpart, only when the specific key is pressed?
Or any other method to copy or move the child editpart?
thanks for reading.
Re: In orphan-add process, can the child editpart be copied instead of move? [message #114750 is a reply to message #114725] |
Thu, 29 January 2004 13:44   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Randy Hudson wrote:
| We are working on a REQ_CLONE request for the 3.0 release. It will be
| active when CTRL is being pressed.
| "Kimos" <sckimos@enet.co.kr> wrote in message
| news:bvam79$tpn$1@eclipse.org...
|>Hi, all.
|>orphan-add process.
|>moved...
| pressed?
|>thanks for reading.
I have such a setup but Its hard to make it clean. Lots needs to change
to support that. The problem is that orphans are children which have
already been born. And children do not maintain ALL information about
themselves. Some is in the parent. While you can easily clone the
model, one can not so easily clone the editPart which contains the
model. Well unless GEF changes some workings under the hood.
is their a repository for the experiment?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAGVSFVbJM14DSCi0RAn6IAKDG/DuwRNsl4dsTJ9Kjr8xl07iUKwCf d3r+
9F/vEy2B5oCW3YruYyHfy6w=
=ZDYB
-----END PGP SIGNATURE-----
Re: In orphan-add process, can the child editpart be copied instead of move? [message #114763 is a reply to message #114750] |
Thu, 29 January 2004 14:41   |
REQ_CLONE functionality is present in the latest build of GEF. It is
implemented in the Logic example by cloning the model objects (not
EditParts). You can check out this functionality for yourself by holding
down CTRL while dragging an object in the Logic example. Please note there
may be changes in the implementation for the 3.0 release.
"CL [dnoyeb] Gilbert" <Lamont_Gilbert@rigidsoftware.com> wrote in message
news:bvbk65$7up$2@eclipse.org...
> Hash: SHA1
> |>Hi, all.
> |>orphan-add process.
> |>moved...
> | pressed?
> |>thanks for reading.
> Respectfully,
> CL Gilbert
> =ZDYB
Re: In orphan-add process, can the child editpart be copied instead of move? [message #114902 is a reply to message #114789] |
Fri, 30 January 2004 11:09   |
It is up to you whether you use a CreationFactory or not. It is your
command, and you have access to the EditPart being cloned, so I don't see
why you should have any trouble cloning the object, and even transfering
"parent" properties to the new parent all within that command.
news:bvci3g$8ov$1@eclipse.org...
> Hash: SHA1
there
message
> I know you can clone the models, but how do you get them into an
> editpart? They cant go through orpahn, because they are not orphans,
> they have yet to be layed out right?
> i actually made a cloning model factory and can clone too. this is how
> i made cut-paste work. but it essentially sends the clone models back
> throught he factory. orphans dont go through the factory do they?
> CL
> and by latest build, what do you mean? I am on 2.1.2 is their a
> compatible build there?
> anything new for GEF in 3.x, and how soo till 3.x is released??
> iD8DBQFAGcwwVbJM14DSCi0RAmwWAKCleT0zKRxWmG+eyCBbBuxwp2wiLgCg 2gmb
> NSO2H5WbiCKeODdcXRGrx7E=
> =6PO8
Re: In orphan-add process, can the child editpart be copied instead of move? [message #115055 is a reply to message #114789] |
Fri, 30 January 2004 15:36  |
I was referring to the latest Integration build (found on the downloads
page). The most recent works with Eclipse 3.0 M6 - and contains some of the
new things that will be in GEF 3.0 - which will be released sometime near
the Eclipse 3.0 release.
Current Time: Wed Jul 23 10:14:27 EDT 2025
Powered by FUDForum. Page generated in 0.13476 seconds
