Problem Installing Papyrus Code Gen Add-Ins To Juno [message #1148248] |
Mon, 21 October 2013 07:23  |
I run Eclipse Juno (Version: Juno Service Release 2 / Build id: 20130225-0426)and have been trying to get Papyrus and its coding add-ins for C/C++, Java and Ada installed so that I can try writing apps directly from UML.
Initial difficulties installing Papyrus were somehow (I don't know why it failed to install from the site finder but did install from the downloaded folder . . . ) overcome.
But when I try to install the add-ins (and I only tried to install the code generator add-ins and their required dependencies, not all of the available add-ins since stuff like embedded code utilities are of no use to me) I get an error message stating that there are missing components. Refer to attached screenshot.
The error message reads :
Cannot complete the install because one or more required items could not be found.
Software being installed: C/C++ code generators for Papyrus 1.13.0.200911231358 (com.cea.papyrus.gen.cdt.feature.group 1.13.0.200911231358)
Missing requirement: C/C++ code generators for Papyrus 1.13.0.200911231358 (com.cea.papyrus.gen.cdt.feature.group 1.13.0.200911231358) requires 'com.cea.papyrus.feature.feature.group [1.7.0,2.0.0)' but it could not be found
Ignoring the C/C++ and Java code gens and trying to install the Ada code generator add-in on its own simply brings up the following error message :
Software currently installed: ADA 2005 code generator for Papyrus 1.0.1.200911231214 (com.adacore.uml2ada2005_feature.feature.group 1.0.1.200911231214)
Missing requirement: Customactions Plug-in 1.0.1.200911231214 (com.adacore.uml2ada2005.customactions 1.0.1.200911231214) requires 'bundle fr.obeo.acceleo.chain 0.0.0' but it could not be found
Cannot satisfy dependency:
From: com.adacore.uml2ada2005 1.0.1.200911231214 (com.adacore.uml2ada2005 1.0.1.200911231214)
To: bundle com.adacore.uml2ada2005.customactions 0.0.0
From: ADA 2005 code generator for Papyrus 1.0.1.200911231214 (com.adacore.uml2ada2005_feature.feature.group 1.0.1.200911231214)
To: com.adacore.uml2ada2005 [1.0.1.200911231214]
I have already installed Acceleo Common, Evaluation Engine, Model & Profiler Model.
But I am not sure if the code generators being installed require additional 'bridging' by means of the Acceleo Integration plugin -- therefore I included it in my install.
Any help from the producers of the coding add-ins for Papyrus would be most welcome with this issue.
[Updated on: Mon, 21 October 2013 07:41] by Moderator
FUDForum. Page generated in 0.04776 seconds
