Home » Eclipse Projects » Eclipse Platform » which plugins implement Open Declaration?
which plugins implement Open Declaration? [message #114715] Fri, 22 August 2003 11:40 Go to next message
Originally posted by: xing.cs.ualberta.ca
hi,
when you press F3, the declaration of java element will be opened. which
plugins implement that?
thanks
zhenchang
Re: which plugins implement Open Declaration? [message #114731 is a reply to message #114715] Fri, 22 August 2003 11:53 Go to previous messageGo to next message
> hi,
Check org.eclipse.jdt.ui (Stuff like actions, dialogs, editors is mostly
there ;)
Ok Ok here is the correct class and hey I give you a quick snippet;)
public class OpenDeclaringTypeAction extends OpenStackFrameAction {
protected String getTypeNameToOpen(IDebugElement frame)
throws DebugException {
return ((IJavaStackFrame)frame).getDeclaringTypeName();
protected void doAction(Object e) throws DebugException {
Object sourceElement= getSourceElement(e);
if (sourceElement != null) {
openInEditor(sourceElement);
Martin (Kersten)
PS: Just a tipp. Create a new Workspace, add all plugin sources of eclipse
to it and then use open type option to look for it. (remember the use of
The classes are named well (I looked at Preferences->Keys found
'Open Declaration' and just looked for it ;).
Re: which plugins implement Open Declaration? [message #114781 is a reply to message #114731] Fri, 22 August 2003 12:00 Go to previous messageGo to next message
Martin Kersten wrote:
> > hi,
> there ;)
> Martin (Kersten)
that's actually great. thanks so much.
BTW, how to create a new workspace? [message #114831 is a reply to message #114731] Fri, 22 August 2003 12:05 Go to previous messageGo to next message
> > hi,
> there ;)
> Martin (Kersten)
BTW, how to create a new Workspace? ;)
Re: BTW, how to create a new workspace? [message #115061 is a reply to message #114831] Fri, 22 August 2003 15:36 Go to previous message
eclipse
You can specify the directory of you workspace when you start eclipse.
Add -data directory as commandline option.
Win2k:
C:\eclipse\eclipse.exe -mx256m -ms64m -data c:/eclipse/workspace-XXX
I have a link for every workspace so I can choose em easily. You can run
as many workspaces as you like. But I advice to copy an existing
workspace and use the copy as new one. So you can get all the settings
of the old to be used by the new one ;)
Martin (Kersten)
Previous Topic:DefaultUndoManager undoable()
Next Topic:how to parse .java source file programmatically
Current Time: Thu Nov 06 09:06:45 EST 2025
Powered by FUDForum. Page generated in 0.04575 seconds
