Home » Archived » Hudson » Hudson delete job fails
Hudson delete job fails [message #1111374] Wed, 18 September 2013 01:57 Go to next message
when trying to delete a hudson (3.0.1-b2) job with admin rights the popup screen "Checking if the job can be deleted.." does not disappear and nothing more happens.
Firebug says:
h..ps://xx.com/hudson/job/xxService2/1/api/json?_=1379483494833 403 forbidden
Is there a solution or workaround to the problem?
Re: Hudson delete job fails [message #1111755 is a reply to message #1111374] Wed, 18 September 2013 13:33 Go to previous messageGo to next message
We fixed a bug in Hudson 3.1.0 that could solve this issue. More over in Hudson 3.1.0 more error details will be displayed in the dialog.
See bugs
https://bugs.eclipse.org/bugs/show_bug.cgi?id=414846
https://bugs.eclipse.org/bugs/show_bug.cgi?id=410333
Re: Hudson delete job fails [message #1114836 is a reply to message #1111755] Mon, 23 September 2013 05:18 Go to previous messageGo to next message
Thank you! We need a production release, so I´ll wait for that..
Re: Hudson delete job fails [message #1115017 is a reply to message #1114836] Mon, 23 September 2013 10:31 Go to previous messageGo to next message
3.1.0 is already released it. You can get it from
http://eclipse.org/downloads/download.php?file=/hudson/war/hudson-3.1.0.war
Re: Hudson delete job fails [message #1115483 is a reply to message #1115017] Tue, 24 September 2013 03:00 Go to previous messageGo to next message
Great that the update is available! But: Installed the update, clicked on "delete project", same error as before Sad
Re: Hudson delete job fails [message #1148078 is a reply to message #1115483] Mon, 21 October 2013 04:44 Go to previous messageGo to next message
Is there a way to get a job deleted without the frontend? I would try to delete the job from the database, or is there a better way?
Re: Hudson delete job fails [message #1149548 is a reply to message #1148078] Tue, 22 October 2013 02:36 Go to previous messageGo to next message
Ok, found out: Just delete the folder and restart Hudson, job is gone.
Re: Hudson delete job fails [message #1245956 is a reply to message #1149548] Fri, 14 February 2014 09:14 Go to previous messageGo to next message
I have the problem too with Hudson 3.1.0 IE and Chrome...
When can we expect a release to correct this?
Re: Hudson delete job fails [message #1246124 is a reply to message #1245956] Fri, 14 February 2014 13:53 Go to previous message
Can you try 3.1.2. I have added more debugging in the delete dialog. BTW, one of my co-worker had the same problem and it turned out the job could not be physically deleted, because it was in a NFS mounted disk and there was a lock preventing it from deleting. Do you have any such issue?
Previous Topic:hudson3 Cannot create a session after the response has been committed
Next Topic:[Hudson 3.1.2 - Upgraded from 1.384] Loading Dashboard very slow & Cannot delete job.
Current Time: Wed Jul 23 05:44:04 EDT 2025
Powered by FUDForum. Page generated in 0.07177 seconds
