Home » Archived » BIRT » Wanna an Xls emitter?
Wanna an Xls emitter? [message #114511] Tue, 24 January 2006 13:19 Go to next message
Originally posted by: qauck.msn.com
Hi guys,
For those who wanted an xls emitter for a long time, finally here may be
a chance to taste:). Thanks the Apache POI project and the new layout
engine of BIRT 2.0, now we can easily create an xls emitter though it
looks obviously not that fancy yet. Anyway, this is a start.:)
Please visit http://qauck.wordpress.com for more details.
thanks
Shawn
Re: Wanna an Xls emitter? [message #114662 is a reply to message #114511] Tue, 24 January 2006 11:10 Go to previous messageGo to next message
Shawn,
Nice work! Look forward to seeing the source code.
Jason Weathersby
BIRT PMC
"Shawn Qualia" <qauck@msn.com> wrote in message
news:dr5r4m$rk3$1@utils.eclipse.org...
> Hi guys,
> For those who wanted an xls emitter for a long time, finally here may be a
> chance to taste:). Thanks the Apache POI project and the new layout engine
> of BIRT 2.0, now we can easily create an xls emitter though it looks
> thanks
> Shawn
Re: Wanna an Xls emitter? [message #114771 is a reply to message #114511] Tue, 24 January 2006 15:55 Go to previous messageGo to next message
Originally posted by: andy.lawton.nospam.com
Tried downloading - but got a
Forbidden
You don't have permission to access /xls-emitter.zip on this server.
message...
Andy
> Hi guys,
> thanks
> Shawn
Re: Wanna an Xls emitter? [message #114808 is a reply to message #114662] Tue, 24 January 2006 16:13 Go to previous messageGo to next message
Originally posted by: mlorenz.nc.rr.com
You might check out JXLS (http://jxls.sourceforge.net/). It was quite
simple to work with. I can provide an example if there is interest.
Mark
Re: Wanna an Xls emitter? [message #115017 is a reply to message #114771] Tue, 24 January 2006 23:00 Go to previous messageGo to next message
I got the same thing, except when I did "Save Target As..." it downloaded!
Re: Wanna an Xls emitter? [message #115030 is a reply to message #114808] Tue, 24 January 2006 23:02 Go to previous messageGo to next message
Definitely interested in example.
Re: Wanna an Xls emitter? [message #115066 is a reply to message #115017] Wed, 25 January 2006 00:36 Go to previous messageGo to next message
I am getting same error,I am also looking for excel option.
Re: Wanna an Xls emitter? [message #115156 is a reply to message #115066] Wed, 25 January 2006 02:40 Go to previous messageGo to next message
I got the download and i downloaded binaries for BIRT so how do i replace
these things.So i can get preview in excel?
org.eclipse.birt.chart.reportitem
org\eclipse\birt\chart\reportitem\ChartReportItemPresentatio nImpl
org.eclipse.birt.report.designer.ui
org\eclipse\birt\report\designer\ui\actions\PreviewToolbarMe nuAction
org.eclipse.birt.report.viewer
org\eclipse\birt\report\viewer\aggregation\layout\EngineFrag ment
Re: Wanna an Xls emitter? [message #115220 is a reply to message #114808] Wed, 25 January 2006 03:11 Go to previous messageGo to next message
> Mark
Yes, Mark, JXLS is another greate XLS library, but actually it also uses
Apache POI internally. And as I understand, it mainly targets on
transforming to a xls file from bean objects and template files. That
may not quite meet the need of a BIRT emitter which is usually creating
the output from scratch.
thanks
Shawn
Re: Wanna an Xls emitter? [message #115232 is a reply to message #114771] Wed, 25 January 2006 03:17 Go to previous messageGo to next message
Could you access http://qauck.host.sk or http://www.host.sk ? I don't
think this is a permission issue though the site do sometimes not be
very stable. If you still can't access it, please try some free web
proxies:). for example, http://www.phproxy.org/ .
thanks
Shawn
> Forbidden
> message...
> Andy
Re: Wanna an Xls emitter? [message #115270 is a reply to message #115156] Wed, 25 January 2006 04:01 Go to previous messageGo to next message
Hi Jack,
Just replace the class files in following jars with the downloaded patch
files.
ChartReportItemPresentationImpl in
plugins/org.eclipse.birt.chart.reportitem_2.0.0/reportitem.j ar
PreviewToolbarMenuAction in
plugins/org.eclipse.birt.report.designer.ui_2.0.0/ui.jar
EngineFragment in
plugins/org.eclipse.birt.report.viewer_2.0.0/birt/WEB-INF/li b/viewservlets.jar
you can check http://qauck.wordpress.com for a detailed description.
thanks
Shawn
> replace these things.So i can get preview in excel?
Re: Wanna an Xls emitter? [message #115283 is a reply to message #114662] Wed, 25 January 2006 04:06 Go to previous messageGo to next message
Thanks Jason, now the source code is also available at
http://qauck.wordpress.com . Hope it looks not very bad. :)
Shawn
Jason Weathersby wrote:
> Shawn,
> Jason Weathersby
> BIRT PMC
>> Hi guys,
>> thanks
>> Shawn
Re: Wanna an Xls emitter? [message #116775 is a reply to message #115220] Wed, 25 January 2006 15:45 Go to previous messageGo to next message
Absolutely true on all counts. My example is using templates and beans.
Both are fine for my situations - we just create the template to look like
we want and then fill in the values based on beans' behaviors (mostly
getters and setters).
Works really well.
I guess I don't know what kind of XLS output requires no template ahead of
time - even if you create it "from scratch" as you call it, you have to
know what you're trying to do and can thus create a template to use (which
is a lot easier than POI or other frameworks).
Mark
Re: Wanna an Xls emitter? [message #116787 is a reply to message #115030] Wed, 25 January 2006 15:46 Go to previous message
look at my other message on this thread and if you're still interested,
let me know and I'll put it together in the next day or two.
Mark
Previous Topic:Confused about requirements for BIRT Install
Next Topic:Parameters in Scripted Data Source
Current Time: Tue Jul 22 06:39:32 EDT 2025
Powered by FUDForum. Page generated in 0.82164 seconds
