Home » Archived » Test and Performance Tools Platform (TPTP) » [agr] ant execution error???
[agr] ant execution error??? [message #113113] Sun, 23 September 2007 12:08 Go to next message
Originally posted by: bmf1972.fastmail.fm
Hi all,
I am using TPTP 4.4 + AGR on Eclipse 3.3 on WinXP SP2.
The agent controller runs as a Windows service (the IAC causes Eclipse
to crash and I couldn't find what I am doing wrong; but that's other
issue...).
From the IDE the test run both in quick and in standard modes.
From Ant the execution fails with this error:
<snip>
C:\documents\administrator\workspace\wirexn-lang-eclipse-wiz ards-tests >ant
-lib
C:\PROGRA~1\Java\ECLIPS~2.0\plugins\OR3A3A~1.V20
Buildfile: build.xml
test:
[tptp:test] java.io.FileNotFoundException: C:\Documents and
Settings\Administrat
or\Local Settings\Temp\memento57791-out.dat (The system cannot find the
file spe
cified)
[tptp:test] at java.io.FileInputStream.open(Native Method)
[tptp:test] at java.io.FileInputStream.<init>(FileInputStream.java:106)
[tptp:test] at java.io.FileInputStream.<init>(FileInputStream.java:66)
[tptp:test] at
org.eclipse.hyades.automation.client.strategies.OutOfProcess S
trategy.restoreMemento(OutOfProcessStrategy.java:363)
[tptp:test] at
trategy.execute(OutOfProcessStrategy.java:302)
[tptp:test] at
org.eclipse.hyades.automation.client.ServiceProxy.execute(Se r
viceProxy.java:77)
[tptp:test] at
org.eclipse.hyades.automation.client.AutomationClient$Defaul t
..execute(AutomationClient.java:160)
[tptp:test] at
org.eclipse.hyades.automation.client.adapters.java.Automatio n
ClientAdapter.execute(AutomationClientAdapter.java:168)
[tptp:test] at
org.eclipse.hyades.automation.client.adapters.ant.Automation C
lientAdapter$Automation.execute(AutomationClientAdapter.java :305)
[tptp:test] at
lientAdapter$Execution.execute(AutomationClientAdapter.java: 611)
[tptp:test] at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j a
va:288)
[tptp:test] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
[tptp:test] at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce s
sorImpl.java:39)
[tptp:test] at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe t
hodAccessorImpl.java:25)
[tptp:test] at java.lang.reflect.Method.invoke(Method.java:597)
[tptp:test] at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch U
tils.java:105)
[tptp:test] at org.apache.tools.ant.Task.perform(Task.java:348)
[tptp:test] at org.apache.tools.ant.Target.execute(Target.java:357)
[tptp:test] at org.apache.tools.ant.Target.performTasks(Target.java:385)
[tptp:test] at
org.apache.tools.ant.Project.executeSortedTargets(Project.ja v
a:1329)
[tptp:test] at
org.apache.tools.ant.Project.executeTarget(Project.java:1298 )
[tptp:test] at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D e
faultExecutor.java:41)
[tptp:test] at
org.apache.tools.ant.Project.executeTargets(Project.java:118 1
[tptp:test] at org.apache.tools.ant.Main.runBuild(Main.java:698)
[tptp:test] at org.apache.tools.ant.Main.startAnt(Main.java:199)
[tptp:test] at
org.apache.tools.ant.launch.Launcher.run(Launcher.java:257)
[tptp:test] at
org.apache.tools.ant.launch.Launcher.main(Launcher.java:104)
BUILD FAILED
C:\documents\administrator\workspace\wirexn-lang-eclipse-wiz ards-tests\build.xml
:25: java.lang.NullPointerException
Total time: 1 second
</snip>
The build.xml file used is:
<project name="TPTP Ant Tasks Test Script"
default="test"
xmlns:tptp="antlib:org.eclipse.hyades.automation.client.adapters.ant ">
<property name="tptp.automation.eclipse"
value="C:/PROGRA~1/Java/ECLIPS~2.0"/>
<description>
This Ant script tests the TPTP automation Ant task client adapters
and also can be used to test the underlying execution of TPTP automatable
services via the TPTP automation server
</description>
<!-- Execute TPTP test suites -->
<target name="test" description="Executes TPTP Test Suites using
default TPTP Ant Tasks">
Execute a TPTP test suite using the test task and providing the workspace
<tptp:test
workspace="file:///C:/documents/administrator/workspace"
project="wirexn-lang-eclipse-wizards-tests"
suite=" src/test/resources/org/wirexn/lang/eclipse/wizards/tests/gui .testsuite "
synchronicity="synchronous"
vmargs="-XX:+UseParallelGC -XX:MaxPermSize=256M -Xmx512M -Xss4M"
connection="tptp:rac://localhost:10002"/>
</target>
</project>
Please help,
Adrian.
Re: [agr] ant execution error??? [message #113780 is a reply to message #113113] Mon, 01 October 2007 13:04 Go to previous messageGo to next message
Hi Adrian,
The exception you are seeing implies that the eclipse workbench launched
by ASF experienced an uncaught exception. ASF currently does a poor job
of marshalling errors from the workbench process back to the invoking
client adapter. This is a bug, covered by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=194503 .
The implication here is that you probably have an error in your ant
script / configuration, and bug 194503 is preventing you from seeing
what that error is. Looking at your script, the first thing I see is an
invalid workspace location. You have provided a URI, but you should
instead provide a fully qualified path (i.e.
"C:/documents/administrator/workspace").
If that doesn't solve your problem, I'd suggest running a simple TPTP
JUnit test from your ant script. If that runs correctly, then we will
have narrowed the problem down to the AGR test type. (And my next
question would ask to confirm that TPTP, all its dependencies and the
AGR feature are installed into "C:/PROGRA~1/Java/ECLIPS~2.0".)
Hope this helps,
--Joe
Adrian Herscu wrote:
> Hi all,
> issue...).
> <snip>
> -lib
> test:
> file spe
> cified)
> [tptp:test] at
> [tptp:test] at
> [tptp:test] at
> viceProxy.java:77)
> [tptp:test] at
> [tptp:test] at
> [tptp:test] at
> [tptp:test] at
> [tptp:test] at
> va:288)
> Method)
> [tptp:test] at
> sorImpl.java:39)
> [tptp:test] at
> [tptp:test] at
> tils.java:105)
> [tptp:test] at
> [tptp:test] at
> a:1329)
> [tptp:test] at
> [tptp:test] at
> [tptp:test] at
> [tptp:test] at
> [tptp:test] at
> BUILD FAILED
> </snip>
> default="test"
> <description>
> </description>
> <tptp:test
> </target>
> </project>
> Please help,
> Adrian.
Re: [agr] ant execution error??? [message #114537 is a reply to message #113780] Sun, 07 October 2007 05:16 Go to previous messageGo to next message
Hi Joe, and thanks for the hint.
It tried your suggestion and it seems that it solved the previous
problem. However, it runs into another problem now :-(
Here is the output:
<snip>
test:
[tptp:test] Test started!
[tptp:test] Test
'C:\documents\pm\eclipse-3.3-workspace\wirexn-lang-eclipse-w iza
rds-tests\src\test\resources\org\wirexn\lang\eclipse\wizards \tests\gui.testsuite
' executing
[tptp:test]
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrapp
edException: org.eclipse.core.internal.resources.ResourceException:
Resource '/w
irexn-lang-eclipse-wizards-tests/documents/pm/eclipse-3.3-wo rkspace/wirexn-lang-
eclipse-wizards-tests/src/test/resources/org/wirexn/lang/ecl ipse/wizards/tests/g
ui.testsuite' does not exist.
[tptp:test] at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe m
andLoadException(ResourceSetImpl.java:316)
[tptp:test] at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo a
dHelper(ResourceSetImpl.java:275)
[tptp:test] at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou r
ce(ResourceSetImpl.java:398)
[tptp:test] at
org.eclipse.hyades.test.core.services.AbstractTestExecutionS e
rvice.loadModelElement(AbstractTestExecutionService.java:757 )
[tptp:test] at
rvice.loadTestSuite(AbstractTestExecutionService.java:776)
[tptp:test] at
rvice.beforeLaunch(AbstractTestExecutionService.java:255)
[tptp:test] at
rvice.execute(AbstractTestExecutionService.java:519)
[tptp:test] at
org.eclipse.hyades.automation.server.AbstractService.execute (
AbstractService.java:43)
[tptp:test] at
org.eclipse.hyades.automation.server.ServiceProxy$1.run(Serv i
ceProxy.java:141)
[tptp:test] at
org.eclipse.hyades.automation.core.utils.ReusableThread.run( R
eusableThread.java:131)
[tptp:test] at java.lang.Thread.run(Unknown Source)
[tptp:test] Caused by:
org.eclipse.core.internal.resources.ResourceException: Re
source
'/wirexn-lang-eclipse-wizards-tests/documents/pm/eclipse-3.3 -workspace/wi
rexn-lang-eclipse-wizards-tests/src/test/resources/org/wirex n/lang/eclipse/wizar
ds/tests/gui.testsuite' does not exist.
[tptp:test] at
org.eclipse.core.internal.resources.Resource.checkExists(Res o
urce.java:310)
[tptp:test] at
org.eclipse.core.internal.resources.Resource.checkAccessible (
Resource.java:193)
[tptp:test] at
org.eclipse.core.internal.resources.File.getContents(File.ja v
a:285)
[tptp:test] at
a:276)
[tptp:test] at
org.eclipse.hyades.models.hierarchy.util.HierarchyURIConvert e
rImpl$WorkbenchHelper.createPlatformResourceInputStream(Hier archyURIConverterImp
l.java:290)
[tptp:test] at
rImpl.createPlatformResourceInputStream(HierarchyURIConverte rImpl.java:368)
[tptp:test] at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI n
putStream(URIConverterImpl.java:538)
[tptp:test] at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour c
eImpl.java:1152)
[tptp:test] at
d(ResourceSetImpl.java:256)
[tptp:test] at
dHelper(ResourceSetImpl.java:271)
[tptp:test] ... 9 more
BUILD FAILED
C:\documents\pm\eclipse-3.3-workspace\wirexn-lang-eclipse-wi zards-tests\build.xm
l:25: java.lang.NullPointerException
Total time: 8 seconds
</snip>
It looks like something gets confused about the supplied paths, which
eventually causes the following error message:
" '/wirexn-lang-eclipse-wizards-tests/documents/pm/eclipse-3.3 -workspace/wirexn-lang-
ui.testsuite' does not exist"
Adrian.
Joe Toomey wrote:
> Hi Adrian,
> Hope this helps,
> --Joe
>> Hi all,
>> issue...).
>> <snip>
>> -lib
>> test:
>> the file spe
>> cified)
>> [tptp:test] at
>> [tptp:test] at
>> [tptp:test] at
>> [tptp:test] at
>> [tptp:test] at
>> viceProxy.java:77)
>> [tptp:test] at
>> [tptp:test] at
>> [tptp:test] at
>> [tptp:test] at
>> [tptp:test] at
>> va:288)
>> Method)
>> [tptp:test] at
>> sorImpl.java:39)
>> [tptp:test] at
>> [tptp:test] at
>> tils.java:105)
>> [tptp:test] at
>> [tptp:test] at
>> a:1329)
>> [tptp:test] at
>> [tptp:test] at
>> [tptp:test] at
>> [tptp:test] at
>> [tptp:test] at
>> BUILD FAILED
>> </snip>
>> default="test"
>> <description>
>> automatable
>> </description>
>> <tptp:test
>> </target>
>> </project>
>> Please help,
>> Adrian.
Re: [agr] ant execution error??? [message #114610 is a reply to message #114537] Mon, 08 October 2007 10:47 Go to previous messageGo to next message
Hi Adrian,
Can you please post your modified ant script?
--Joe
<snip>
Re: [agr] ant execution error??? [message #114645 is a reply to message #114610] Mon, 08 October 2007 12:50 Go to previous messageGo to next message
Here it is:
<snip>
default="test"
<description>
</description>
<tptp:test
workspace="C:/documents/pm/eclipse-3.3-workspace"
</target>
</project>
</snip>
Joe Toomey wrote:
> Hi Adrian,
> --Joe
> <snip>
Re: [agr] ant execution error??? [message #114766 is a reply to message #114645] Tue, 09 October 2007 21:35 Go to previous messageGo to next message
Hi Adrian,
I just tested a copy of this script, with the appropriate changes to my
use paths on my machine, (with TPTP 4.4.0.3 and TPTP 4.4.1) and it
worked fine. Can you confirm which TPTP build you're using?
--Joe
> Here it is:
> <snip>
> default="test"
> <description>
> </description>
> <tptp:test
> </target>
> </project>
> </snip>
> Joe Toomey wrote:
>> Hi Adrian,
>> Thanks,
>> --Joe
>> <snip>
Re: [agr] ant execution error??? [message #115185 is a reply to message #114766] Wed, 10 October 2007 15:11 Go to previous messageGo to next message
I believe this is the right version info:
TPTP Core
Version: 4.4.0.v200707090100-8Q82EN-JEPilAkj70nCro
Build id: TPTP-4.4.0.1-200707090100B
TPTP Automated GUI Recording and Playback
Version: 4.1.100.v200705040100-773_70r733G3B8A3C76
Build id: TPTP-4.4.0.2-200708100100
Adrian.
Joe Toomey wrote:
> Hi Adrian,
> --Joe
>> Here it is:
>> <snip>
>> default="test"
>> <description>
>> automatable
>> </description>
>> <tptp:test
>> </target>
>> </project>
>> </snip>
>> Joe Toomey wrote:
>>> Hi Adrian,
>>> Thanks,
>>> --Joe
>>> <snip>
Re: [agr] ant execution error??? [message #115341 is a reply to message #115185] Fri, 12 October 2007 15:51 Go to previous messageGo to next message
This is perplexing. Can you please confirm that you have the correct
version of ant-tptp.jar in your ant/lib directory and not some older
version? (This file should be copied from the
org.eclipse.hyades.execution plug-in. The correct one for 4.4.0.1
should be 70k.)
--Joe
> TPTP Core
> Adrian.
> Joe Toomey wrote:
>> Hi Adrian,
>> my use paths on my machine, (with TPTP 4.4.0.3 and TPTP 4.4.1) and it
>> --Joe
>>> Here it is:
>>> <snip>
>>> default="test"
>>> <description>
>>> automatable
>>> </description>
>>> workspace
>>> <tptp:test
>>> </target>
>>> </project>
>>> </snip>
>>> Joe Toomey wrote:
>>>> Hi Adrian,
>>>> Thanks,
>>>> --Joe
>>>> <snip>
Re: [agr] ant execution error??? [message #115366 is a reply to message #115341] Sat, 13 October 2007 07:55 Go to previous message
Hi Joe,
I never copied the ant-tptp.jar file to my ${ant.home}/lib directory.
I have always used the -lib option with ant.
Adrian.
> should be 70k.)
> --Joe
>> TPTP Core
>> Adrian.
>> Joe Toomey wrote:
>>> Hi Adrian,
>>> --Joe
>>>> Here it is:
>>>> <snip>
>>>> default="test"
>>>> <description>
>>>> automatable
>>>> </description>
>>>> workspace
>>>> <tptp:test
>>>> -Xss4M"
>>>> </target>
>>>> </project>
>>>> </snip>
>>>> Joe Toomey wrote:
>>>>> Hi Adrian,
>>>>> Thanks,
>>>>> --Joe
>>>>> <snip>
Previous Topic:test
Next Topic:TPTP environments
Current Time: Sun Jul 27 11:21:02 EDT 2025
Powered by FUDForum. Page generated in 0.27817 seconds
