Home » Modeling » TMF (Xtext) » Terminal rules driving me nuts(Noob)
Terminal rules driving me nuts [message #1145742] Sat, 19 October 2013 15:09 Go to next message
I have some parts of syntax where I need the following flexibility:
equ kfactor 1.3
rdax reg0, 1
rdax 32, -1
rdax reg1, 1.9
rdax reg3, -2.0
rdax reg3, kfactor
rdax reg3, -kfactor
So, arg1 can be an INT or an ID, while arg2 (ultimately resolving to a double) needs to be able to be represented as a +/- INT, +/- REAL, or +/- ID. "+" is never explicitly represented so I just need to accommodate the possibility of "-".
Trying to represent these possibilities as mutually exclusive terminal rules without unintended side effects is making my brain hurt. It seems like I should just explicitly declare terminal rules which could loosely handle what I just stated, and figure out the details in the data validator itself.
Just wondering what the general consensus is, since I read one of the tutorials which recommended against trying to be too clever with terminal rules.
GW
[Updated on: Sat, 19 October 2013 15:30] by Moderator
Re: Terminal rules driving me nuts [message #1145802 is a reply to message #1145742] Sat, 19 October 2013 16:02 Go to previous messageGo to next message
Did. you have a look at Datatype Rules?
MyStuff '-'? (ID | (INT ( "." ID)?));
Re: Terminal rules driving me nuts [message #1147014 is a reply to message #1145802] Sun, 20 October 2013 11:28 Go to previous message
Thanks Christian! That was just the hint I needed.
Previous Topic:xtext - formatting with new lines in the language
Next Topic:Problems with scoping after migrating to xtext 2.0
Current Time: Fri Jul 25 11:38:48 EDT 2025
Powered by FUDForum. Page generated in 0.04006 seconds
