Home » Archived » Sapphire » Questions on Drag-n-Drop in Forms
Questions on Drag-n-Drop in Forms [message #1145331] Sat, 19 October 2013 08:33 Go to next message
I have two questions on the drag-n-drop in an outline.
1. Dropping a node as a child of another node seems to be possible only if there's already a child. Can this be changed, so that a node can be dropped as the first child of anode?
2. I would also like to copy nodes with drag-n-drop. Is there a way to implement this?
Re: Questions on Drag-n-Drop in Forms [message #1145561 is a reply to message #1145331] Sat, 19 October 2013 12:14 Go to previous messageGo to next message
In addition to dropping between nodes in a list, you can also drop onto a node. That will add the dropped to the end of the node's child list. Also works if the node has no children yet.
There is no facility to customize drag-n-drop behavior in the master details outline. I can see enhancing drag-n-drop with modifiers. Maybe holding down the shift key turns a move into a copy. Please open an enhancement request.
Re: Questions on Drag-n-Drop in Forms [message #1145654 is a reply to message #1145561] Sat, 19 October 2013 13:42 Go to previous messageGo to next message
1. No, whatever I try, I cannot drop onto a node. There is always the black line above or below the node, and on drop, the node is inserted above or below the destination node, on the same level (Sapphire 0.6.6).
2. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=419913
Re: Questions on Drag-n-Drop in Forms [message #1148604 is a reply to message #1145654] Mon, 21 October 2013 12:25 Go to previous messageGo to next message
It sounds like you have trouble with the case where a node with a child node factory is itself a direct product of a child node factory. So a list within a list without intermediary static nodes. I will try to setup a repro for this scenario. I don't believe any of the existing samples do this.
Re: Questions on Drag-n-Drop in Forms [message #1148757 is a reply to message #1148604] Mon, 21 October 2013 14:27 Go to previous messageGo to next message
Yes, all nodes are a direct product of a child node factory.
Re: Questions on Drag-n-Drop in Forms [message #1148882 is a reply to message #1148757] Mon, 21 October 2013 16:17 Go to previous messageGo to next message
Both of the issues have been resolved. Please verify and confirm in bugzilla.
Re: Questions on Drag-n-Drop in Forms [message #1148883 is a reply to message #1148882] Mon, 21 October 2013 16:18 Go to previous messageGo to next message
Copy modifier is not supported for DND in forms
Unable to drop onto a node if the node is itself part of a list
https://bugs.eclipse.org/bugs/show_bug.cgi?id=420021
Re: Questions on Drag-n-Drop in Forms [message #1150430 is a reply to message #1148883] Tue, 22 October 2013 15:28 Go to previous messageGo to next message
Tried both. Works perfect. Many thanks, also for your fast response.
Now, may I kindly ask for a backport to 0.6.x? The reason is, the Eclipse 3rd party product we are targeting with the Sapphire plugin is still Helios/3.6, and there seem to be no real plans to move forward. According to your announcement, 0.7.x requires at least Indigo/3.7. If so, having the two changes also in 0.6.x would be more than helpful.
Re: Questions on Drag-n-Drop in Forms [message #1150952 is a reply to message #1150430] Tue, 22 October 2013 23:41 Go to previous messageGo to next message
Ok. I have backported the fixes to 0.6.x line. Please verify.
https://hudson.eclipse.org/sapphire/job/0.6.x/
Re: Questions on Drag-n-Drop in Forms [message #1151557 is a reply to message #1150952] Wed, 23 October 2013 08:35 Go to previous messageGo to next message
Hello Konstantin, works perfectly. Many thanks again.
Re: Questions on Drag-n-Drop in Forms [message #1151756 is a reply to message #1151557] Wed, 23 October 2013 11:28 Go to previous messageGo to next message
You are welcome. Could you add a node regarding verification on 0.6.x line to the two bugs, so that I can close them again?
Re: Questions on Drag-n-Drop in Forms [message #1151928 is a reply to message #1151756] Wed, 23 October 2013 13:57 Go to previous message
Done for both.
Previous Topic:Property depending on path property not refreshed after Browse dialog closes
Next Topic:Delegated Implementation
Current Time: Thu Jul 24 23:59:36 EDT 2025
Powered by FUDForum. Page generated in 0.27068 seconds
