Home » Modeling » TMF (Xtext) » JvmModelInferrer: Serializing a JvmTypeReference and Generating a method body
JvmModelInferrer: Serializing a JvmTypeReference and Generating a method body [message #1143822] Fri, 18 October 2013 08:53 Go to next message
I'm writing a JvmModelInferrer in which I create classes with methods with bodies.
In these body, I would like to declare variables of a given type, so I do something like that:
body = [
  aType.newTypeRef().serializeSafely(it)
  append(" varName = methodCall();")
newTypeRef comes from JvmTypesBuilder and serializeSafely comes from ErrorSafeExtensions.
The problem is that because this JvmTypeReference does not have any eContainer, when serialize (from TypeReferenceSerializer) is called by ErrorSafeExtensions with context set to the JvmTypeReference's eContainer which is null, I get a NPE...
Question:
1) is that the correct way of serializing a JvmTypeReference?
2) is there a better way to generate the body of the method? For example by building an XEpression instead of doing it by hand? How to build such an XEpression?
Thank you Smile
Victor
[Updated on: Fri, 18 October 2013 08:53] by Moderator
Re: JvmModelInferrer: Serializing a JvmTypeReference and Generating a method body [message #1143873 is a reply to message #1143822] Fri, 18 October 2013 09:30 Go to previous messageGo to next message
Hi where does a type come from and what type is it?
And why don't you simply write the type down?
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: JvmModelInferrer: Serializing a JvmTypeReference and Generating a method body [message #1143879 is a reply to message #1143822] Fri, 18 October 2013 09:38 Go to previous messageGo to next message
BTW if atype is a jvmtype you can call
Append(atype)
Re: JvmModelInferrer: Serializing a JvmTypeReference and Generating a method body [message #1143911 is a reply to message #1143879] Fri, 18 October 2013 10:06 Go to previous messageGo to next message
This type reference has type arguments: it is a reference, not a type, that's why I want to use serialize.
The type itself is a class generated with JvmModelInferrer.
Let's say I did in the infer method:
anObjectOfMyModel.toClass(name) [
  typeParameters += ...
I thus got a JvmGenericType, and then, I want to have a reference to this type, but with specific arguments.
Re: JvmModelInferrer: Serializing a JvmTypeReference and Generating a method body [message #1143922 is a reply to message #1143911] Fri, 18 October 2013 10:12 Go to previous messageGo to next message
Sorry have no idea on that
Re: JvmModelInferrer: Serializing a JvmTypeReference and Generating a method body [message #1143980 is a reply to message #1143922] Fri, 18 October 2013 11:04 Go to previous messageGo to next message
maybe you can use one of org.eclipse.xtext.xbase.compiler.TypeReferenceSerializer.serialize(JvmTypeReference, EObject, IAppendable)
and put your model object as context.
~Christian
Re: JvmModelInferrer: Serializing a JvmTypeReference and Generating a method body [message #1144012 is a reply to message #1143980] Fri, 18 October 2013 11:27 Go to previous message
Thank you, that works perfectly yes :)
If anybody comes around and knows the answer to the second question, it would be nice.
That would be much more elegant I think, but I guess xtext is not ready for meta-programming (yet ;).
Previous Topic:Documenting the Grammar to use it in the DSL-Editor
Next Topic:ClusteringBuilderState - Error validating
Current Time: Sat Jul 26 00:35:39 EDT 2025
Powered by FUDForum. Page generated in 0.08232 seconds
