Home » Archived » Eclipse Examples » UDP CHAT + Java(How can I do..//Como puedo hacer..)
UDP CHAT + Java [message #1139083] Tue, 15 October 2013 10:25 Go to next message
Hi, I am doing a udp chat with Java in Eclipse.
I have two classes Chat Client and Chat Server, the first of this one,contains the JFrame of what comes to be the chat screen, the main and a controller that manages connections to the server. The Chat Server has a Message and User.
The problem is that in the ChatClientController I have problems when implementing the functions: connecting ... disconnecting ...
I use a socket to send datagrams (messages)
If you can help me, I would be very grateful.
I can send you the code of the classes, if necessary.
Hola, estoy realizando un chat udp, cuento con dos clases Chat Client y Chat Server, el primero de ellos tengo el JFrame de lo que viene a ser la pantalla del chat, el main y un controller que gestiona las conexiones con el servidor. El Chat Server tiene un Message y User.
El problema es que en el ChatClientController tengo problemas a la hora de implementar las funciones de conectar...desconectar...utilizo un socket para mandar los datagramas(mensajes)
Si me podeis ayudar, estaría muy agradecido.
Puedo enviaros las clases por si es necesario.
Re: UDP CHAT + Java [message #1143538 is a reply to message #1139083] Fri, 18 October 2013 04:54 Go to previous message
import java.net.DatagramSocket;
import java.util.ArrayList;
import java.util.List;
import java.util.Observer;
import es.deusto.ingenieria.ssdd.util.observer.local.LocalObservable;
import es.deusto.ingenieria.ssdd.chat.data.User;
public class ChatClientController {
private String serverIP;
private int serverPort;
private User connectedUser;
private User chatReceiver;
private LocalObservable observable;
public ChatClientController() {
this.observable = new LocalObservable();
this.serverIP = null;
this.serverPort = -1;
public String getConnectedUser() {
if (this.connectedUser != null) {
return this.connectedUser.getNick();
} else {
return null;
public String getChatReceiver() {
if (this.chatReceiver != null) {
return this.chatReceiver.getNick();
} else {
return null;
public String getServerIP() {
return this.serverIP;
public int gerServerPort() {
return this.serverPort;
public boolean isConnected() {
return this.connectedUser != null;
public boolean isChatSessionOpened() {
return this.chatReceiver != null;
public void addLocalObserver(Observer observer) {
this.observable.addObserver(observer);
public void deleteLocalObserver(Observer observer) {
this.observable.deleteObserver(observer);
public boolean connect(String ip, int port, String nick) {
//CODE
try
DatagramSocket udpSocket = new DatagramSocket();
catch(Exception e){
this.connectedUser = new User();
this.connectedUser.setNick(nick);
this.serverIP = ip;
this.serverPort = port;
return true;
public boolean disconnect() {
//CODE
this.connectedUser = null;
this.chatReceiver = null;
return true;
public List<String> getConnectedUsers() {
List<String> connectedUsers = new ArrayList<>();
//CODE
connectedUsers.add("Default");
return connectedUsers;
public boolean sendMessage(String message) {
//CODE
return true;
public void receiveMessage() {
//CODE
String message = "Received message";
//Notify the received message to the GUI
this.observable.notifyObservers(message);
public boolean sendChatRequest(String to) {
//CODE
this.chatReceiver = new User();
this.chatReceiver.setNick(to);
return true;
public void receiveChatRequest() {
//CODE
String message = "Chat request details";
//Notify the chat request details to the GUI
public boolean acceptChatRequest() {
//CODE
return true;
public boolean refuseChatRequest() {
//CODE
return true;
public boolean sendChatClosure() {
//CODE
return true;
public void receiveChatClosure() {
//CODE
Previous Topic:tomcat preference page
Next Topic:Open Sound Control (OSC)
Current Time: Fri Jul 25 00:48:36 EDT 2025
Powered by FUDForum. Page generated in 0.05551 seconds
