Home » Archived » Jubula » Question: Jubula database on Amazon RDS
icon5.gif  Question: Jubula database on Amazon RDS [message #1142808] Thu, 17 October 2013 17:45 Go to next message
Hi there, has anyone tried this? Having the jubula database in an RDS instance in Amazon AWS?
I am trying it with the 1.3 Jubula client but it takes forever to connect.
If anyone has got this working or if the team has any insights into this, please share! Smile
Cheers
Re: Question: Jubula database on Amazon RDS [message #1143303 is a reply to message #1142808] Fri, 18 October 2013 01:25 Go to previous messageGo to next message
Hi Alejo,
We've not tried this ourselves, so I can't help with experience here. If you continue having problems, and no one can help, post again with any logs etc that might help.
Alex
Re: Question: Jubula database on Amazon RDS [message #1143793 is a reply to message #1143303] Fri, 18 October 2013 08:31 Go to previous message
Hi Alex, it's not actually that i'm hitting a problem but when trying to connect to the database it seems like it takes quite a long time to load. I couldn't tell how much time because I couldn't see it finishing after half an hour more or less. I can tell that it is loading projects because I can see it in the console:
Connection to Database successful.
Importing projects...
	Reading projects...
	Reading project file /resources/library/unbound_modules_rcp_6.1.xml.
	Reading project file /resources/library/unbound_modules_concrete_6.1.xml.
	Reading project file /resources/library/unbound_modules_swt_6.1.xml.
Project "unbound_modules_swt" in version 6.1 requires the following project(s):
- project "unbound_modules_concrete" in version 6.1
	Reading project file /resources/library/unbound_modules_html_6.1.xml.
	Finished reading projects.
	Importing unbound_modules_rcp_6.1...
	Finished importing unbound_modules_rcp_6.1.
	Importing unbound_modules_concrete_6.1...
I was wondering if there was something in Jubula about how it handles database connections that causes this kind of behavior when working with non-local (ping > 100 ms) databases. I've been playing around a little bit (creating a new project) and it seems like every step (creating a category, a test case, adding steps to a test case) takes a while, between 5~10 secs.
Being that the database is the main support of Jubula's architecture it would be great if we could have that support in a realiable infrastructure such as AWS.
Previous Topic:Unable to post replies in the forum
Next Topic:Running Jubula on a windows Jenkins agent requires a display plugin?
Current Time: Wed Jul 23 19:46:42 EDT 2025
Powered by FUDForum. Page generated in 0.04061 seconds
