Home » Archived » BIRT » Using new Docx Emitter programmatically
Using new Docx Emitter programmatically [message #1129372] Tue, 08 October 2013 11:06 Go to next message
I tried to upgrade to Birt 4.3.1 in order to make use of the new docx emitter.
I tried to use it by using DocxRenderOptions and setting the outputFormat to "docx" and writing a file with the docx extension. However, Birt tell me that "docx" is not supported (yes, I'm sure I compile against 4.3.1).
The format extension "docx" is just not in the format2MIMEType list.
So I figured I need to explicitly setting the emitter ID. However, using "org.eclipse.birt.report.engine.emitter.docx" leads to another exception telling me this emitter is not valid.
What am I doing wrong? here's my code setting the render options:
case DOCX:
	DocxRenderOption docxRenderOption = new DocxRenderOption();
	OutputStream docxStream = createOutputStream(format); // format needs to be "doc" in order to make it happen
	if (docxStream != null) {
		docxRenderOption.setOutputStream(docxStream);
	} else {
		docxRenderOption.setOutputFileName(getOutputFileName(format));
	docxRenderOption.setOutputFormat(getBIRTFormat(format)); // getBirtFormat returns doc in order to make it happen
	docxRenderOption.setEmitterID("org.eclipse.birt.report.engine.emitter.docx"); // this does not work... why? Even when format is docx it does not work
	docxRenderOption.setOption(IRenderOption.HTML_PAGINATION, Boolean.TRUE);
	docxRenderOption.setOption(IRenderOption.RENDER_DPI, 96);
	docxRenderOption.setOption(IPDFRenderOption.PAGE_OVERFLOW, IPDFRenderOption.FIT_TO_PAGE_SIZE);
	return docxRenderOption;
Re: Using new Docx Emitter programmatically [message #1129447 is a reply to message #1129372] Tue, 08 October 2013 12:34 Go to previous messageGo to next message
Okay, I figured that I missed to add some dependencies in the platform feature.
These are:
* org.eclipse.birt.report.engine.emitter.config.docx
* org.eclipse.birt.report.engine.emitter.docx
* org.eclipse.birt.report.engine.ooxml
Re: Using new Docx Emitter programmatically [message #1142848 is a reply to message #1129447] Thu, 17 October 2013 18:19 Go to previous messageGo to next message
Glad you got it working!
Re: Using new Docx Emitter programmatically [message #1354938 is a reply to message #1142848] Wed, 14 May 2014 09:47 Go to previous messageGo to next message
I'm using the same method as Robert. But I'm always getting the error:
EmitterID org.eclipse.birt.report.engine.emitter.docx for render option is invalid.
I have included the following library to my project: org.eclipse.birt.runtime_4.3.2.v20140225-1404.jar
This library includes the package "rg.eclipse.birt.report.engine.emitter.docx" - The package is as well accessible in the class.
Do you have any idea how I may use the docx emitter?
Thank you very much.
Re: Using new Docx Emitter programmatically [message #1371796 is a reply to message #1354938] Wed, 21 May 2014 10:47 Go to previous message
> is invalid.
What version of BIRT are you using? Can you explain your problem a
little more?
Previous Topic:xls export failing for large data Birt 2.6.2
Next Topic:BIRT bug when adding a parameter to a data set
Current Time: Sun Jul 27 12:00:44 EDT 2025
Powered by FUDForum. Page generated in 0.04585 seconds
