Home » Modeling » TMF (Xtext) » Limiting the scope to elements in the same resource
Limiting the scope to elements in the same resource [message #1142329] Thu, 17 October 2013 10:52 Go to next message
Hello everyone,
in one of my (numerous) Xtext projects I have a fairly straight-forward entity DSL which is compiled and used to populate a database. Usually when creating cross-references, Xtext offers all matching objects from all resources within the project as completion proposals, and normally this is fine. However, in my case, having cross-references between files does not make sense for the use case and may even break the compile process.
So, the question is: what is the simplest way of narrowing down the scope of reference targets to only those objects which are declared in the same file as the reference source object? I tried to use a custom ScopeProvider, but it turned out to be not that easy with all those IEObjectDescription objects involved...
Alan
Re: Limiting the scope to elements in the same resource [message #1142470 is a reply to message #1142329] Thu, 17 October 2013 12:46 Go to previous messageGo to next message
Did you try to change the global scope provider? Or the imported
namespace aware local scope promise I?
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Limiting the scope to elements in the same resource [message #1143583 is a reply to message #1142470] Fri, 18 October 2013 05:34 Go to previous messageGo to next message
Hi Christian,
so far I haven't really changed anything. I tried to implement a custom scope provider by adding code to the auto-generated <LanguageName>ScopeProvider that extends from AbstractDeclarativeScopeProvider, but I must admit that I was unsuccessful in doing so since I don't know all the internals of Xtext. My language does not make use of any kind of "import" statements, does not use Xbase and has no other special features except a custom validator. Where can I find the Global Scope Provider you mentioned?
Alan
[Updated on: Fri, 18 October 2013 05:34] by Moderator
Re: Limiting the scope to elements in the same resource [message #1143609 is a reply to message #1143583] Fri, 18 October 2013 05:51 Go to previous message
org.eclipse.xtext.scoping.impl.DefaultGlobalScopeProvider
or ImportedNamespaceAwareLocalScopeProvider.getGlobalScope
Previous Topic:Global vars with "new" GlobalVarExtensions.getGlobalVar
Next Topic:How should an inferrer fail correctly?
Current Time: Mon Jul 21 02:05:16 EDT 2025
Powered by FUDForum. Page generated in 0.27547 seconds
