reportContext.getHttpServletRequest() not working on BIRT 2.2.1.1 [message #262803] |
Thu, 06 December 2007 06:36  |
Originally posted by: ycai.serena.com
Hi, all
I am trying to set chart title at runtime. I put these script in the
initialize script:
importPackage(Packages.javax.servlet.http);
req = reportContext.getHttpServletRequest();
title = "default ...";
if (req != null) {
title = req.getAttribute('title');
reportContext.setPersistentGlobalVariable("title", title);
and put this function in the onRender script of the chart element:
function beforeGeneration( chart, context )
importPackage(Packages.org.eclipse.birt.chart.model.type.imp l);
newChartTitle =
context.getExternalContext().getScriptable().getPersistentGl obalVariable( "title");
chart.getTitle().getLabel().getCaption().setValue(newChartTi tle);
However, the chart's title is showing "default ...", not the value of
the request attribute. Therefore, this is a bug that
reportContext.getHttpServletRequest() returns null.
yc
Re: reportContext.getHttpServletRequest() not working on BIRT 2.2.1.1 [message #262833 is a reply to message #262803] |
Thu, 06 December 2007 10:00   |
Originally posted by: jasonweathersby.alltel.net
Try this report. It retrieves info from the request.
Are you sure title is set as a request attribute?
Jason
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.6"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.0.1
Build <20060222-1204></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 Innovent Solutions,
Inc.</property>
<method name="beforeFactory"><![CDATA[// Create a hash table which
will contain lists of other lists
var topMap = new Packages.java.util.Hashtable();
// Request Attributes
var request = reportContext.getHttpServletRequest();
var requestAttrMap = new Packages.java.util.Hashtable();
var attrNames = request.getAttributeNames();
do {
var aName = attrNames.nextElement();
requestAttrMap.put(aName, request.getAttribute(aName).toString());
} while (attrNames.hasMoreElements())
topMap.put("requestAttributes", requestAttrMap);
// Request Parameters
var requestParamMap = new Packages.java.util.Hashtable();
var paramIter = request.getParameterMap().entrySet().iterator();
do{
var entry = paramIter.next();
requestParamMap.put(entry.getKey(), (entry.getValue()[0]));
} while (paramIter.hasNext())
topMap.put("requestParameters",requestParamMap);
// Session Attributes
var sessionAttrMap = new Packages.java.util.Hashtable();
var session = request.getSession();
// Insert a variable on the session
session.setAttribute("ReportAttribute", "arbitrary value to pass to
container");
var sessionAttrNames = session.getAttributeNames();
var i = 0;
do {
i ++;
var aaa = sessionAttrNames.nextElement();
sessionAttrMap.put(aaa, session.getAttribute(aaa));
} while (sessionAttrNames.hasMoreElements())
topMap.put("sessionAttributes", sessionAttrMap);
// Get the system properties
topMap.put("systemProps", Packages.java.lang.System.getProperties());
// Store top map as a global
reportContext.setPersistentGlobalVariable("topMap", topMap);]]></method>
<data-sources>
<script-data-source name="setScript" id="4"/>
</data-sources>
<data-sets>
<script-data-set name="setEnvironmentVars" id="5">
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">propName</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">propValue</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">propType</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">propName</property>
</structure>
<structure>
<property name="columnName">propValue</property>
</structure>
<structure>
<property name="columnName">propType</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">setScript</property>
<method name="open"><![CDATA[aMap =
reportContext.getPersistentGlobalVariable("topMap");
topIter = aMap.entrySet().iterator();
if (topIter == null)
topIterator = new Packages.java.util.Iterator();
Packages.java.util.logging.Logger.getLogger("").info("OPEN NULL " );
innerIter = null;]]></method>
<method name="fetch"><![CDATA[do
{ // find an innerIter that has a new value
if (innerIter == null || innerIter.hasNext() == false)
{ // no value in the inner iterator, get the next Hashtable out of the
toHashtable
if (topIter.hasNext())
outerObject = topIter.next();
innerIter = outerObject.getValue().entrySet().iterator();
else
{ // no more top hash tables. close things up
return false;
while (innerIter.hasNext() == false)
// we must have another innerIter
innerObject = innerIter.next();
row["propName"] = innerObject.getKey();
row["propValue"] = innerObject.getValue().toString();
row["propType"] = outerObject.getKey();
return true;
Iterator i = topMap.entrySet().iterator();
while (i.hasNext()) {
Entry entry = (Entry) i.next();
logger.info(entry.getKey() + " " + entry.getValue() );
*/]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="detail" id="36">
<property name="backgroundColor">#FFFF80</property>
<property name="fontFamily">Arial</property>
<property name="fontSize">small</property>
</style>
<style name="headerfooter" id="37">
<property name="backgroundColor">#004080</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
</style>
<style name="groupheader" id="38">
<property name="backgroundColor">#0080FF</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="orientation">landscape</property>
<property name="topMargin">0.5in</property>
<property name="leftMargin">0.5in</property>
<property name="bottomMargin">0.5in</property>
<property name="rightMargin">0.5in</property>
</simple-master-page>
</page-setup>
<body>
<table id="6">
<property name="width">100%</property>
<property name="dataSet">setEnvironmentVars</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["propName"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["propValue"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["propType"]</expression>
<property name="aggregateOn">propType</property>
</structure>
</list-property>
<column id="16"/>
<column id="17"/>
<header>
<row id="7">
<property name="style">headerfooter</property>
<cell id="8">
<label id="18">
<text-property
name="text">propName</text-property>
</label>
</cell>
<cell id="9">
<label id="20">
<text-property
name="text">propValue</text-property>
</label>
</cell>
</row>
</header>
<group id="22">
<property name="groupName">propType</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr">row["propType"]</expression>
<header>
<row id="23">
<cell id="24">
<data id="29">
<property
name="resultSetColumn">propType</property>
</data>
</cell>
<cell id="25"/>
</row>
<row id="33">
<property name="height">2pt</property>
<property name="backgroundColor">#000000</property>
<cell id="34"/>
<cell id="35"/>
</row>
</header>
<footer>
<row id="26">
<cell id="27"/>
<cell id="28"/>
</row>
</footer>
</group>
<detail>
<row id="10">
<property name="style">groupheader</property>
<cell id="11">
<data id="19">
<property
name="resultSetColumn">propName</property>
</data>
</cell>
<cell id="12">
<data id="21">
<property
name="resultSetColumn">propValue</property>
</data>
</cell>
</row>
<row id="30">
<property name="backgroundColor">#C0C0C0</property>
<cell id="31"/>
<cell id="32"/>
</row>
</detail>
<footer>
<row id="13">
<cell id="14"/>
<cell id="15"/>
</row>
</footer>
</table>
</body>
</report>
ycai wrote:
> Hi, all
> initialize script:
> if (req != null) {
> newChartTitle =
> yc
Re: reportContext.getHttpServletRequest() not working on BIRT 2.2.1.1 [message #1141905 is a reply to message #262833] |
Thu, 17 October 2013 05:06  |
nevertheless, it is a bug!
getHttpServletRequest() returns null when it shouldn't.
i was trying to use this call to distinguish between running in a web server environment or not.
getHttpServletRequest() == true
always.
is there any other way to distinguish between the contexts? after all in one case we inject a servlet context into Birt, and in another we inject a file context...
FUDForum. Page generated in 0.03661 seconds
