Home » Eclipse Projects » e(fx)clipse » Cannot add an item to the toolbar programmatically
Cannot add an item to the toolbar programmatically [message #1137376] Mon, 14 October 2013 08:51 Go to next message
I'm trying to create a toolbar that will be filled in programmatically. Unfortunately I cannot add a new item to the toolbar due to ClassCastException. I try to add a button to the toolbar in the following way:
String commandId = "example.command";
MToolBar toolbar = ...
MHandledToolItem element = eModelService.createModelElement(MHandledToolItem.class);
element.setElementId("my.new.item.id");
element.setLabel("New item");
ParameterizedCommand wbCommand = getCommand(commandId);
element.setWbCommand(wbCommand);
toolbar.getChildren().add(element);
The last line throws the ClassCastException exception:
java.lang.ClassCastException: org.eclipse.fx.ui.workbench.renderers.fx.DefToolItemRenderer$ToolItemImpl cannot be cast to org.eclipse.fx.ui.workbench.renderers.base.widget.WLayoutedWidget
	at org.eclipse.fx.ui.workbench.renderers.base.BaseToolBarRenderer.childRendered(BaseToolBarRenderer.java:103)
	at org.eclipse.fx.ui.workbench.renderers.base.BaseToolBarRenderer.childRendered(BaseToolBarRenderer.java:1)
	at org.eclipse.fx.ui.workbench.fx.PartRenderingEngine.createGui(PartRenderingEngine.java:161)
	at org.eclipse.fx.ui.workbench.fx.PartRenderingEngine.createGui(PartRenderingEngine.java:251)
	at org.eclipse.fx.ui.workbench.renderers.base.BaseRenderer.engineCreateWidget(BaseRenderer.java:307)
	at org.eclipse.fx.ui.workbench.renderers.base.BaseToolBarRenderer.handleChildrenAddition(BaseToolBarRenderer.java:135)
	at org.eclipse.fx.ui.workbench.renderers.base.BaseToolBarRenderer.handleChildrenAddition(BaseToolBarRenderer.java:1)
	at org.eclipse.fx.ui.workbench.renderers.base.EventProcessor$1.handleEvent(EventProcessor.java:41)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.fx.ui.workbench.fx.E4Application$1.syncExec(E4Application.java:156)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
I also encountered one more issue with the toolbar. After starting my application all toolbar buttons(that I declared in the Application.e4xmi) are disabled. I checked your demo application (e4 Media Application) and toolbar is disabled as well.
Re: Cannot add an item to the toolbar programmatically [message #1137566 is a reply to message #1137376] Mon, 14 October 2013 11:31 Go to previous messageGo to next message
On 14.10.13 17:05, Pawel Zalejko wrote:
> following way:
> be cast to
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Filed as https://bugs.eclipse.org/bugs/show_bug.cgi?id=419373 and fixed
in master.
Filed as https://bugs.eclipse.org/bugs/show_bug.cgi?id=419375 and fixed
in master.
It looks like your Application.e4xmi is missing the
HandlerProcessingAddon. How did you bootstrap the the e4 application?
You can add it yourself next to the current addons:
<addons xmi:id="_CsUUmjTlEeOp9YyhHHv9bw"
elementId="org.eclipse.e4.ui.workbench.addons.HandlerProcessingAddon"
contributionURI="bundleclass://org.eclipse.e4.ui.workbench/org.eclipse.e4.ui.internal.workbench.addons.HandlerProcessingAddon"/>
Tom
Re: Cannot add an item to the toolbar programmatically [message #1138497 is a reply to message #1137566] Tue, 15 October 2013 01:56 Go to previous messageGo to next message
Hi Tom,
I added the HandlerProcessingAddon and now the toolbar works like a charm. All buttons are enabled Smile
Thanks!
Re: Cannot add an item to the toolbar programmatically [message #1138870 is a reply to message #1137376] Tue, 15 October 2013 07:31 Go to previous messageGo to next message
Hi Tom,
It looks that the problem with disabled buttons is not resolved. All buttons added to the toolbar programmatically are disabled(those buttons that are declared in the Application.e4xmi work fine).
// Set true in order to enable the button.
element.setEnabled(true);
element.setVisible(true);
element.setToBeRendered(true);
Even when I set following flags on "true" the problem is present:
Re: Cannot add an item to the toolbar programmatically [message #1138897 is a reply to message #1138870] Tue, 15 October 2013 07:54 Go to previous messageGo to next message
Can you please file a bug please and post the bug id to this thread.
Tom
On 15.10.13 13:31, Pawel Zalejko wrote:
> Hi Tom,
Re: Cannot add an item to the toolbar programmatically [message #1138913 is a reply to message #1138897] Tue, 15 October 2013 08:05 Go to previous messageGo to next message
Filed as https://bugs.eclipse.org/bugs/show_bug.cgi?id=419443.
Pawel
[Updated on: Tue, 15 October 2013 08:06] by Moderator
Re: Cannot add an item to the toolbar programmatically [message #1139044 is a reply to message #1137376] Tue, 15 October 2013 09:53 Go to previous messageGo to next message
I have also one question regarding the toolbar. Is it possible to make that toolbar's width will be the same as a window's width (set e.g. maxWidth="Infinity")?
[Updated on: Tue, 15 October 2013 09:54] by Moderator
Re: Cannot add an item to the toolbar programmatically [message #1139072 is a reply to message #1139044] Tue, 15 October 2013 10:15 Go to previous messageGo to next message
http://wiki.eclipse.org/Efxclipse/Runtime/e4#MTrimElement
Tom
> maxHeight="Infinity")?
Re: Cannot add an item to the toolbar programmatically [message #1139161 is a reply to message #1138913] Tue, 15 October 2013 11:28 Go to previous messageGo to next message
Your code is wrong you need assign an MCommand
Tom
On 15.10.13 14:05, Pawel Zalejko wrote:
> Filled as https://bugs.eclipse.org/bugs/show_bug.cgi?id=419443.
> Pawel
Re: Cannot add an item to the toolbar programmatically [message #1140218 is a reply to message #1137376] Wed, 16 October 2013 03:54 Go to previous message
Hi Tom,
You are right. It should be MCommand.
Many thanks for your efforts.
Pawel
Previous Topic:InjectionException at runtime of SWT/JavaFX product build with Maven
Next Topic:Model Processing and Rendering Window children of a Window
Current Time: Sat Jul 26 21:52:40 EDT 2025
Powered by FUDForum. Page generated in 9.56709 seconds
