Home » Eclipse Projects » Remote Application Platform (RAP) » Strange behavior of computeSize() methods
Strange behavior of computeSize() methods [message #1138753] |
Tue, 15 October 2013 05:53  |
I've seen several strange behaviors with computeSize() methods. Please let me know if they are bugs or expected behaviors.
1/ Lots of Control.computeSize implementation often adds 2 or more pixels when wHint or hHint is not SWT.DEFAULT:
Button.computeSize(50, SWT.DEFAULT) will always return Point(52, XXX)
Button.computeSize(SWT.DEFAULT, 50) will always return Point(XXX, 52).
The 2 additional pixels comes from the border width * 2 that is always added at the end but it does not seem to make sense to me when hint is provided.
Also this behavior is different from SWT behavior running on GTK.
I've seen this on:
* Label
* Button
* Combo
* Text widget is even stranger (text.computeSize(SWT.DEFAULT, 50) returns Point {XXX, 62}) I didn't investigate why.
CLabel seems to work as expected.
2/ On Button when using SWT.WRAP the Button.computeSize seems wrong and so button with long text are often layed-out with truncated text.
From what I can see this problems comes from using wHint directly at
Line 391:
extent = TextSizeUtil.textExtent( getFont(), text, wHint );
instead of using wHint we should use the wrapWidth:
int wrapWidth = SWT.DEFAULT;
if (wHint != SWT.DEFAULT) {
// Width is constrained so we compute the remaining width for text
wrapWidth = wHint - borderwidth*2 - padding.width;
if (hasImage) {
// remove space related to image
wrapWidth = imageBoundx.width - spacing;
extent = TextSizeUtil.textExtent( getFont(), text, wrapWidth );
[Updated on: Tue, 15 October 2013 05:55] by Moderator
Re: Strange behavior of computeSize() methods [message #1138836 is a reply to message #1138753] |
Tue, 15 October 2013 07:00   |
Hi Seb,
1) Widget trimming are added on top of wHint/hHint. For Button this is
the border, for Text - border + scrollbar width. At least this is the
SWT behavior under Windows.
Text text = new Text( shell, SWT.BORDER | SWT.MULTI );
System.out.println( text.computeSize( 100, SWT.DEFAULT ) ); // 112, 21
Button button = new Button( shell, SWT.BORDER | SWT.PUSH );
System.out.println( button.computeSize( 100, SWT.DEFAULT ) ); // 104, 29
Label label = new Label( shell, SWT.BORDER );
System.out.println( label.computeSize( 100, SWT.DEFAULT ) ); // 102, 17
2) I think you are right. Could you open a bugzilla about this issue and
attach a patch against RAP git master with your proposed solution?
Best,
Ivan
On 10/15/2013 12:53 PM, Sebastien Arod wrote:
> provided.
> I've seen this on:
> * Label
> * Button
> Line 391: extent = TextSizeUtil.textExtent( getFont(), text, wHint );
> if (hasImage) {
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Strange behavior of computeSize() methods [message #1138903 is a reply to message #1138896] |
Tue, 15 October 2013 07:59   |
Hi Seb,
see my answers below.
> 1) If it's the expected behavior is it normal that CLabel behaves
> differently than Label regarding border?
Here is the output of computeSize methods including CLabel under SWT
(Windows):
CLabel clabel = new CLabel( shell, SWT.BORDER );
System.out.println( clabel.computeSize( 100, SWT.DEFAULT ) ); // 100, 21
As you can see CLabel behaves differently :-).
> 2) I opened bug 419441 [Button] computeSize algorithm is wrong when
> using SWT.WRAP. I'll create a path ASAP
Thanks.
Ivan Furnadjiev
Current Time: Fri Jul 25 23:40:20 EDT 2025
Powered by FUDForum. Page generated in 0.25272 seconds
