Home » Language IDEs » Java Development Tools (JDT) » What are the ".index" files - can I safely delete them?(Docs for JDT metadata appreciated )
What are the ".index" files - can I safely delete them? [message #1137475] Mon, 14 October 2013 10:16 Go to next message
Trying to reduce the size of my (DB synced) workspace - realized that the folder
${workspace_loc}\.metadata\.plugins\org.eclipse.jdt.core
was taking ~35 Mbytes - the contents of the folder are `.index` files (which take the most space) and some others (which are a couple Kb worth) :
    [0-9]*\.index
    externalLibsTimeStamps
    indexNamesMap.txt
    invalidArchivesCache
    javaLikeNames.txt
    nonChainingJarsCache
    participantsIndexNames.txt
    savedIndexNames.txt
    variablesAndContainers.dat
I can't seem to be able to find docs on those. Can I safely delete them ? Can you point me to some docs on the JDT plugin folders/files contained in
${workspace_location}\.metadata\
directory ?
Is there any way via the gui to clean up the caches (preferably periodically) ?
PS : I 'm on Kepler if this makes a difference
PS2 : links to docs may be links to code comments and such
Re: What are the ".index" files - can I safely delete them? [message #1137589 is a reply to message #1137475] Mon, 14 October 2013 11:51 Go to previous messageGo to next message
The index-files is where JDT stores informations need to do content
assist, ... , if you delete them they'll get recreated IIRC because you
really need them!
Tom
> the folder
> [0-9]*\.index
> indexNamesMap.txt
> javaLikeNames.txt
> savedIndexNames.txt
> contained in ${workspace_location}\.metadata\ directory ? Is there any
Re: What are the ".index" files - can I safely delete them? [message #1137651 is a reply to message #1137589] Mon, 14 October 2013 12:41 Go to previous message
As has been pointed out in another thread. Don't sync workspaces. Sync your projects. Syncing projects uses much less space and is how the product is designed.
Previous Topic:Toggling between a Mac and PC using Dropbox/SugarSync
Next Topic:define new Proposal Kind in the content assist
Current Time: Sun Aug 31 07:56:57 EDT 2025
Powered by FUDForum. Page generated in 0.03959 seconds
