Home » Eclipse Projects » Eclipse Scout » LoginDialog example(User login dialog)
LoginDialog example [message #1109597] Sun, 15 September 2013 13:39 Go to next message
Very new to Scout but have been using RCP for 5+ years. In my RCP app i use the splash screen to provide a login dialog. this is limited to 3.x
What is the preferred method with scout? Are there any examples? where does the authentication process fit in the startup of the application?
Any pointers appreciated.
Re: LoginDialog example [message #1109605 is a reply to message #1109597] Sun, 15 September 2013 13:51 Go to previous messageGo to next message
OK found some info in the 3.9 Scout book, this and the modify login dialog thread on this forum should be sufficient.
Any fuller descriptions would be great.
Thanks anyway
Re: LoginDialog example [message #1112386 is a reply to message #1109605] Thu, 19 September 2013 12:06 Go to previous messageGo to next message
Hi Dominic,
Here some useful links that may help you:
Scout Security Concept
Example using LDAP Authentication
Example how to extend the standard login dialog
Some sample demo applications. E.g. the bahbah Chat application makes heavy use of security filters.
If you have any other questions, don't hesitate to ask!
Kind regards
matthias
Re: LoginDialog example [message #1135816 is a reply to message #1112386] Sun, 13 October 2013 08:27 Go to previous messageGo to next message
thanks for those links.
The issue I have now is that my SWT client happily uses DataSourceSecurityFilter but I have had no luck getting my RAP client to do so. Are there any resources relating to this issue.
Thanks in advance
Re: LoginDialog example [message #1136944 is a reply to message #1135816] Mon, 14 October 2013 02:54 Go to previous messageGo to next message
Dominic Hanlan wrote on Sun, 13 October 2013 14:27
What DB are you using? If you are using embededd Derby (as the minicrm tutorial does), then this would explain it: It only allows one simultaneous connection to the DB, which is already occupied by the scout server, so when the RAP client tries to connect, the connection fails.
Either switching to a derby server instead of using the embedded driver should solve this problem (though I haven't tested it).
Re: LoginDialog example [message #1137199 is a reply to message #1136944] Mon, 14 October 2013 06:22 Go to previous messageGo to next message
no I'm using Postgresql with the following RAP config.ini entry
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#active=true
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#realm=DENTABYTE
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#jdbcDriverName=org.postgresql.Driver
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#jdbcMappingName=jdbc:postgresql://192.168.0.53:5432/dentabyte_test
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#jdbcUsername=xxxx
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#jdbcPassword=xxxx
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#selectUserPass=SELECT LOWER(subscriber_username) FROM subscriber WHERE LOWER(subscriber_username)=? AND subscriber_password=?
This on the SWT client works perfectly but with RAP gives the following
!ENTRY org.eclipse.scout.http.servletfilter 4 0 2013-10-14 11:11:15.924
!MESSAGE org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter.isValidUser(DataSourceSecurityFilter.java:168) Cannot SELECT user/pass.
!STACK 0
java.lang.ClassNotFoundException: org.postgresql.Driver cannot be found by org.eclipse.scout.http.servletfilter_3.9.0.20130510-1229
Any ideas?? I tried adding the com.bsiag.scout.rt.server.jdbc.postgresql9 as a dependency to the RAP client but this gives me an OSGI unresolved bundle error when I start the client
/Dominic
Re: LoginDialog example [message #1137462 is a reply to message #1137199] Mon, 14 October 2013 10:10 Go to previous messageGo to next message
Hi Dominic,
Have you tried adding the postgresql driver fragment (org.postgres.postgresql9.jdbc.fragment) to your RAP product file? Or is this already present?
Kind regards
matthias
[CLOSED]Re: LoginDialog example [message #1151595 is a reply to message #1137462] Wed, 23 October 2013 09:07 Go to previous message
many thanks for that, worked a treat
/Dominic
Previous Topic:Swing desktop execClosing problem
Next Topic:JUnit test for the Scout Search Form
Current Time: Sat Jul 26 11:52:14 EDT 2025
Powered by FUDForum. Page generated in 0.09495 seconds
