Home » Eclipse Projects » Eclipse 4 » Kepler SR 1 (4.3.1): e4 key bindings will be removed by BindingToModelProcessor
Kepler SR 1 (4.3.1): e4 key bindings will be removed by BindingToModelProcessor [message #1137183] Mon, 14 October 2013 06:09 Go to next message
I have migrated an e4 RCP application to the most recent Kepler 4.3.1 release.
The RCP application has dependencies to org.eclipse.ui and therefore also to org.eclipse.ui.workbench.
While doing a regression test after switching to the 4.3.1 target platform, I noticed that key bindings defined in the e4 application model were broken.
I tracked the problem down to the org.eclipse.ui.internal.BindingToModelProcessor which deletes all key bindings which do not have the tag "type:user". This includes also the bindings defined by my e4 application model.
This behavior has been introduced by a fix to bug 406003 (sry, can't post eclipse links because of forum restrictions).
The attachment contains the e4 sample application project (modification: added org.eclipse.ui dependency) that demonstrates the problem. Just startup the application in Kepler 4.3.1 and try to open the about dialog (CTRL+A) -> the key binding won't work.
Is this new behavior for e4 RCP applications intended? If so, how to correctly define key bindings in the e4 application model?
[Updated on: Mon, 14 October 2013 09:40] by Moderator
Re: Kepler SR 1 (4.3.1): e4 key bindings will be removed by BindingToModelProcessor [message #1140219 is a reply to message #1137183] Wed, 16 October 2013 03:55 Go to previous messageGo to next message
Problem is even worse. The removal of key bindings affects all plugins in an application. Even the Live Editor cannot be opened anymore.
PS: I also noticed that tracing key bindings doesn't work. Perhaps this is connected.
Re: Kepler SR 1 (4.3.1): e4 key bindings will be removed by BindingToModelProcessor [message #1143549 is a reply to message #1140219] Fri, 18 October 2013 05:04 Go to previous messageGo to next message
So no one knows how to do it correctly? Certainly adding the tag "type:user" to the key binding can not be a proper solution. It works quite good but it seems to be a misusage of the "type:user" tag, as it should be used for user defined key bindings.
Should I file this as a bug?
Re: Kepler SR 1 (4.3.1): e4 key bindings will be removed by BindingToModelProcessor [message #1245788 is a reply to message #1143549] Fri, 14 February 2014 04:12 Go to previous messageGo to next message
Was this ever filed as a Bug?
Re: Kepler SR 1 (4.3.1): e4 key bindings will be removed by BindingToModelProcessor [message #1264593 is a reply to message #1245788] Wed, 05 March 2014 05:44 Go to previous messageGo to next message
Please file a bug on https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform&component=UI
Re: Kepler SR 1 (4.3.1): e4 key bindings will be removed by BindingToModelProcessor [message #1426512 is a reply to message #1264593] Thu, 18 September 2014 17:42 Go to previous messageGo to next message
I've created a workaround using a custom model processor that simply adds the tag "type:user" to all key bindings, see this Gist:
gist.github.com/mbackschat/21b6d2254f1eb962fa50
Re: Kepler SR 1 (4.3.1): e4 key bindings will be removed by BindingToModelProcessor [message #1708544 is a reply to message #1426512] Thu, 17 September 2015 07:38 Go to previous messageGo to next message
The bug is https://bugs.eclipse.org/bugs/show_bug.cgi?id=461037
Re: Kepler SR 1 (4.3.1): e4 key bindings will be removed by BindingToModelProcessor [message #1737156 is a reply to message #1137183] Wed, 06 July 2016 03:39 Go to previous message
How can I get the workaround for the CSS Spy Editor?
My own key bindings work now, since using the "type:user" tag.
Previous Topic:TERRIBLE update to Neon
Next Topic:Updated target platform to Eclipse Neon (4.6) and now Placeholder elements require 'ref' attribute
Current Time: Sat Jul 19 04:47:17 EDT 2025
Powered by FUDForum. Page generated in 0.04277 seconds
