Home » Eclipse Projects » Remote Application Platform (RAP) » dispose of images
dispose of images [message #113646] Wed, 26 November 2008 10:24 Go to next message
out RAP website (www.gebrauchtteile.ch) gets slower over time indicating
memory leaks.
we do have a lot of changing images and as images can not be disposed() in
RAP i fear that memory finally gets exhausted.
Questions:
is there a internal mechanism that disposes images from time to time?
if not: what can we do to dispose() old images that are no longer used.
Andrej
Re: dispose of images [message #113690 is a reply to message #113646] Wed, 26 November 2008 15:06 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Andrej,
I assume that you refer to the server side which slower over time.
Which version of RAP are you using?
Images in RAP do not hold the actual image data but only a string
that denotes the location of the image file. Hence this is not what
exhausts the memory.
Best thing would probably be to use a profiler to track down the
problem.
Rüdiger
adiinfo wrote:
> Hi
> memory leaks.
> in RAP i fear that memory finally gets exhausted.
> Questions:
> Thanks
> Andrej
Re: dispose of images [message #113701 is a reply to message #113690] Wed, 26 November 2008 15:45 Go to previous messageGo to next message
Originally posted by: benjamin.wolff.web.de
Hi Rüdiger,
can you recommend a special Java Profiler? which one do you use? i'd like to do some memory analysing on my RAP app, too.
thanks!
Greetings,
-Ben
Rüdiger Herrmann schrieb:
> Andrej,
> I assume that you refer to the server side which slower over time. Which
> Images in RAP do not hold the actual image data but only a string that
> denotes the location of the image file. Hence this is not what exhausts
> the memory.
> Best thing would probably be to use a profiler to track down the problem.
> Cheers,
> Rüdiger
> adiinfo wrote:
>> Hi
>> indicating memory leaks.
>> disposed() in RAP i fear that memory finally gets exhausted.
>> Questions:
>> Thanks
>> Andrej
Re: dispose of images [message #113713 is a reply to message #113690] Wed, 26 November 2008 16:20 Go to previous messageGo to next message
Hi Rüdiger
yes, i refer to the server side.
i use 1.1.1 SR-1. 1.2 is not possible as IE 6 is not supported.
could you recommend a profiler?
Thanks for the insights about how RAP is handling images.
Andrej
Re: dispose of images [message #113750 is a reply to message #113713] Thu, 27 November 2008 04:39 Go to previous message
Andrej,
we mostly use YourKit (http://www.yourkit.com) that offers CPU and
memory profiling. If only a memory analyzer is needed, the Eclipse
MAT (http://www.eclipse.org/mat) is highly recommendable.
HTH
Rüdiger
adiinfo wrote:
> Hi Rüdiger
> Andrej
Previous Topic:RAP and Draw2D/GEF
Next Topic:Deploying a RAP application
Current Time: Sun Jul 27 08:04:39 EDT 2025
Powered by FUDForum. Page generated in 0.04563 seconds
