Home » Archived » Visual Editor (VE) » VE 1.1.0.1 Parse Error with NullPointerException
VE 1.1.0.1 Parse Error with NullPointerException [message #113677] Mon, 19 December 2005 11:51 Go to next message
I've been using VE for awhile. After I reinstalled my system (Windows XP
SP2) with same JDK (1.4.2_08) and using same eclipse distribution (3.1.1
SDK), now VE no longer works for me.
at
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.retrieveFromCache(DefaultVisitorFactoryRule.ja va:83)
at
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.getTypeVisitor(DefaultVisitorFactoryRule.java: 109)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:508)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:417)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:832)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:914)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:575)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1881)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
with IWAV0181E Parsing Error.
So, I reinstalled everything in different directory with new workspace,
I created new Java Project, I created new Visual Class using New Java
Visual Class viwzard, and didn't modify anything. Still VE gives me same
exception and not doing much.
this is my eclipse configruation details:
*** Date: Mon Dec 19 08:48:36 PST 2005
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20050929-0840
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\a\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
2a8_78
-data
C:\eclipse\workspace5
-clean
-refresh
-vm
C:\j2sdk1.4.2_08\bin\javaw.exe
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1135010443687
eclipse.vm=C:\j2sdk1.4.2_08\bin\javaw.exe
eclipse.vmargs=-Xms64M
-Xmx256M
-jar
C:\a\eclipse\startup.jar
eof=eof
file.encoding=MS949
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\a\eclipse\startup.jar
java.class.version=48.0
java.endorsed.dirs=C:\j2sdk1.4.2_08\jre\lib\endorsed
java.ext.dirs=C:\j2sdk1.4.2_08\jre\lib\ext
java.home=C:\j2sdk1.4.2_08\jre
java.io.tmpdir=c:\tmp\sang\
java.library.path=C:\j2sdk1.4.2_08\bin;.;C:\WINDOWS\system32 ;C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System 32\Wbem;C:\Program
Files\ESTsoft\ALZip\;C:\Program Files\Microsoft Visual
Studio\Common\Tools\WinNT;C:\Program Files\Microsoft Visual
Studio\Common\MSDev98\Bin;C:\Program Files\Microsoft Visual
Studio\Common\Tools;C:\Program Files\Microsoft Visual
Studio\VC98\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\Sy stem32\Wbem;C:\Program
Files\ESTsoft\ALZip\;C:\cygwin\bin;C:\Program Files\Inno Setup
5;%JAVA_HOME\bin;C:\Program Files\Microsoft Visual Studio\Common\VSS\win32
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_08-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_08
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_08-b03
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.4
org.osgi.framework.language=ko
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imag eio,javax.imageio.event,javax.imageio.metadata,javax.imageio .plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.n aming,javax.naming.directory,javax.naming.event,javax.naming .ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,j avax.print.attribute,javax.print.attribute.standard,javax.pr int.event,javax.rmi,javax.rmi.CORBA,javax.security.auth,java x.security.auth.callback,javax.security.auth.kerberos,javax. security.auth.login,javax.security.auth.spi,javax.security.a uth.x500,javax.security.cert,javax.sound.midi,javax.sound.mi di.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parse
r,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,jav ax.transaction,javax.transaction.xa,javax.xml.parsers,javax. xml.transform,javax.xml.transform.dom,javax.xml.transform.sa x,javax.xml.transform.stream,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.CurrentPackage,org.omg.PortableServer .POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg .PortableServer.portable,org.omg.PortableServer.ServantLocat orPackage,org.omg.SendingConte
xt,org.omg.stub.java.rmi,org.w3c.dom,org.xml.sax,org.xml.sax .ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=c:\a\eclipse\configuration\org.eclipse.osgi \bundles
osgi.clean=true
osgi.configuration.area=file:/c:/a/eclipse/configuration/
osgi.framework=file:/c:/a/eclipse/plugins/org.eclipse.osgi_3 .1.1.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.1.1
osgi.install.area=file:/c:/a/eclipse/
osgi.instance.area=file:/C:/eclipse/workspace5/
osgi.instance.area.default=file:/C:/Documents and Settings/sang/workspace/
osgi.logfile=C:\eclipse\workspace5\.metadata\.log
osgi.manifest.cache=c:\a\eclipse\configuration\org.eclipse.o sgi\manifests
osgi.nl=ko_KR
osgi.os=win32
osgi.splashLocation=c:\a\eclipse\plugins\org.eclipse.platfor m_3.1.1\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\a\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\j2sdk1.4.2_08\jre\lib\rt.jar;C:\j2sdk 1.4.2_08\jre\lib\i18n.jar;C:\j2sdk1.4.2_08\jre\lib\sunrsasig n.jar;C:\j2sdk1.4.2_08\jre\lib\jsse.jar;C:\j2sdk1.4.2_08\jre \lib\jce.jar;C:\j2sdk1.4.2_08\jre\lib\charsets.jar;C:\j2sdk1 .4.2_08\jre\classes
sun.boot.library.path=C:\j2sdk1.4.2_08\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium i486 i386
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=Service Pack 2
user.country=KR
user.dir=C:\Documents and Settings\sang\Desktop
user.home=C:\Documents and Settings\sang
user.language=ko
user.name=sang
user.timezone=America/Los_Angeles
user.variant=
*** Features:
org.eclipse.emf (2.1.1) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)"
org.eclipse.gef (3.1.1) "Graphical Editing Framework"
org.eclipse.jdt (3.1.1) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.1) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0.1) "Java EMF Model"
org.eclipse.pde (3.1.1) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.1) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.1) "Eclipse Platform"
org.eclipse.platform.source (3.1.1) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.1) "Eclipse RCP"
org.eclipse.rcp.source (3.1.1) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.1) "Eclipse Project SDK"
org.eclipse.ve (1.1.0.1) "Visual Editor"
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Active]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.1) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.1) "Ant UI" [Resolved]
org.eclipse.compare (3.1.1) "Compare Support" [Active]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32
org.eclipse.core.runtime (3.1.1) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Active]
org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.1) "Debug UI" [Active]
org.eclipse.draw2d (3.1.1) "Draw2d" [Active]
org.eclipse.emf (2.1.1) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Active]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit
Support" [Resolved]
org.eclipse.emf.ecore.edit (2.1.1) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
[Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO)
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Active]
org.eclipse.emf.edit (2.1.1) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.1) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.1.1) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore
Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.1) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping
Editor" [Resolved]
org.eclipse.gef (3.1.1) "Graphical Editing Framework" [Active]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.ui (3.1.1) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.1) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.1) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.1.1) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.1.1) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.1) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.1) "Java Development Tools JUnit support"
[Active]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit
runtime support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching
Support" [Active]
[Resolved]
org.eclipse.jdt.ui (3.1.1) "Java Development Tools UI" [Active]
org.eclipse.jem (1.1.0.1) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.1.0.1) "Java EMF Model BeanInfo
(Introspection) Support" [Active]
org.eclipse.jem.proxy (1.1.0.1) "Java EMF Model Proxy Support" [Active]
org.eclipse.jem.ui (1.1.0.1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0.1) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.1.0.1) "Java EMF Model Workbench Support"
[Active]
org.eclipse.jface (3.1.1) "JFace" [Active]
org.eclipse.jface.text (3.1.1) "JFace Text" [Active]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.1.1) "Refactoring UI" [Active]
org.eclipse.osgi.services (3.1.1) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.1) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Resolved]
org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.1) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.1) "Eclipse Plug-in Development User
Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.1) "Plug-in Development Environment
Runtime" [Active]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.1) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.1) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.1) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.1) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.1.1) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.1.1) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.1) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.1.1) "Search Support" [Active]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.1.1) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.1.1) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.1) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.1.1) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.1.1) "Team Support UI" [Resolved]
org.eclipse.text (3.1.1) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.1) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.1) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.1.1) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.0) "Console" [Active]
org.eclipse.ui.editors (3.1.1) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.1) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.1.1) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.1) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.1) "Views" [Active]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.1.1) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.1) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.1) "Install/Update Core" [Resolved]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.1) "Install/Update UI" [Resolved]
org.eclipse.ve (1.1.0) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.1.0.1) "Visual Editor Common Data Editor" [Active]
org.eclipse.ve.doc (1.1.0) "Visual Editor for Java User Guide" [Resolved]
org.eclipse.ve.java.core (1.1.0.1) "Visual Editor Java Core" [Active]
org.eclipse.ve.jfc (1.1.0.1) "Visual Editor for Java Foundation Classes"
[Active]
org.eclipse.ve.propertysheet (1.1.0.1) "Visual Editor PropertySheet"
[Active]
org.eclipse.ve.swt (1.1.0.1) "Visual Editor for Standard Widget Toolkit"
[Resolved]
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)" [Resolved]
org.eclipse.xsd.ecore.importer (2.1.0) "XML Schema Importer for EMF"
[Resolved]
org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.editor (2.1.0) "XML Schema Editor" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
system.bundle (3.1.1) "OSGi System Bundle" [Active]
*** User Preferences:
#Mon Dec 19 08:48:36 PST 2005
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.pde.runtime/orderValue=-1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=C\:/j2sdk1.4.2_08/jre/lib/rt.jar
/instance/org.eclipse.ve.java.core/PALETTE_WIDTH=125
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.ui.ide/platformState=143
/instance/org.eclipse.ui.ide/quickStart=true
/instance/org.eclipse.ui.workbench/PLUGINS_NOT_ACTIVATED_ON_ STARTUP=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
@org.eclipse.ve.java.core=1.1.0.1
file_export_version=3.0
@org.eclipse.pde.core=3.1.1
@org.eclipse.jdt.ui=3.1.1
/instance/org.eclipse.pde.core/platform_path=c\:\\a\\eclipse
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRC=C\:/j2sdk1.4.2_08/src.zip
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=c\:/a/eclipse
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
@org.eclipse.jdt.launching=3.1.0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
/instance/org.eclipse.pde.runtime/orderType=2
/instance/org.eclipse.ui/showIntro=false
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.jdt.core=3.1.1
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\ecl ipse\\workspace
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_templates= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<templates/>
/instance/org.eclipse.pde.runtime/column4=150
@org.eclipse.ui.ide=3.1.1
/instance/org.eclipse.pde.runtime/column3=150
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.pde.runtime/column2=300
/instance/org.eclipse.jdt.ui/fontPropagated=true
@org.eclipse.pde.runtime=3.1.1
@org.eclipse.core.resources=3.1.0
@org.eclipse.ui=3.1.1
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 ">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" name\="j2sdk1.4.2_08" path\="C\:\\j2sdk1.4.2_08"
javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api/"/>\r\n</vmType>\r\n</vmSettings>\r\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=c\:/a/eclipse/plugins/org.junit_3.8.1
@org.eclipse.ui.workbench=3.1.1
/instance/org.eclipse.pde.runtime/activate=true
@org.eclipse.ui.editors=3.1.1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=8
/instance/org.eclipse.ve.java.core/VISUAL_CLASS_WIZARD_SELEC TED_ELEMENT_KEY=org.eclipse.ve.jfc.swing.cat-Desktop
Pane-javax.swing.JDesktopPane
/instance/org.eclipse.ui.workbench/org.eclipse.ui.commands=<?xml
version\="1.0" encoding\="UTF-8"?>\r\n<org.eclipse.ui.commands/>
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
*** Current Install Configuration:
Install configuration:
Last changed on 2005. 12. 19.
Location: file:/c:/a/eclipse/configuration/org.eclipse.update/platform .xml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.platform, Version: 3.1.1
ID: org.eclipse.jdt, Version: 3.1.1
ID: org.eclipse.jdt.source, Version: 3.1.1
ID: org.eclipse.jem, Version: 1.1.0.1
ID: org.eclipse.gef, Version: 3.1.1
ID: org.eclipse.pde.source, Version: 3.1.1
ID: org.eclipse.sdk, Version: 3.1.1
ID: org.eclipse.rcp.source, Version: 3.1.1
ID: org.eclipse.emf, Version: 2.1.1
ID: org.eclipse.platform.source, Version: 3.1.1
ID: org.eclipse.rcp, Version: 3.1.1
ID: org.eclipse.ve, Version: 1.1.0.1
ID: org.eclipse.pde, Version: 3.1.1
ID: org.eclipse.emf.ecore.sdo, Version: 2.1.1
ID: org.eclipse.xsd, Version: 2.1.1
Configured plug-ins:
file:/c:/a/eclipse/plugins/com.ibm.etools.emf.event_3.0.0.1/
file:/c:/a/eclipse/plugins/org.apache.ant_1.6.5/
file:/c:/a/eclipse/plugins/org.apache.lucene_1.4.3/
file:/c:/a/eclipse/plugins/org.eclipse.ant.core_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.ant.ui_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.compare_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.core.boot_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.core.commands_3.1.0.j ar
file:/c:/a/eclipse/plugins/org.eclipse.core.expressions_3.1. 0.jar
file:/c:/a/eclipse/plugins/org.eclipse.core.filebuffers_3.1. 0.jar
file:/c:/a/eclipse/plugins/org.eclipse.core.resources.compat ibility_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.core.resources.win32_ 3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.core.resources_3.1.0. jar
file:/c:/a/eclipse/plugins/org.eclipse.core.runtime.compatib ility_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.core.runtime_3.1.1.ja r
file:/c:/a/eclipse/plugins/org.eclipse.core.variables_3.1.0. jar
file:/c:/a/eclipse/plugins/org.eclipse.debug.core_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.debug.ui_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.draw2d_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ant_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.codegen.ecore.ui_ 2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.codegen.ecore_2.1 .0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.codegen.ui_2.1.0. jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.codegen_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.common.ui_2.1.0.j ar
file:/c:/a/eclipse/plugins/org.eclipse.emf.commonj.sdo_2.1.0 .jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.common_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ecore.change.edit _2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ecore.change_2.1. 0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ecore.editor_2.1. 0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ecore.edit_2.1.1. jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ecore.sdo.editor_ 2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ecore.sdo.edit_2. 1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ecore.sdo_2.1.1.j ar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ecore.xmi_2.1.0.j ar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ecore_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.edit.ui_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.edit_2.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.importer.ecore_2. 1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.importer.java_2.1 .1.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.importer.rose_2.1 .1.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.importer_2.1.0.ja r
file:/c:/a/eclipse/plugins/org.eclipse.emf.mapping.ecore2eco re.editor_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.mapping.ecore2eco re_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.mapping.ecore2xml .ui_2.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.mapping.ecore2xml _2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.mapping.ui_2.1.0. jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.mapping.xsd2ecore .editor_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.mapping.xsd2ecore _2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.mapping_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf_2.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.gef_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.help.appserver_3.1.0. jar
file:/c:/a/eclipse/plugins/org.eclipse.help.base_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.help.ui_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.help.webapp_3.1.0/
file:/c:/a/eclipse/plugins/org.eclipse.help_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.jdt.core_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.jdt.debug.ui_3.1.1.ja r
file:/c:/a/eclipse/plugins/org.eclipse.jdt.debug_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.jdt.doc.isv_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.jdt.doc.user_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.jdt.junit.runtime_3.1 .0/
file:/c:/a/eclipse/plugins/org.eclipse.jdt.junit_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.jdt.launching_3.1.0.j ar
file:/c:/a/eclipse/plugins/org.eclipse.jdt.source_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.jdt.ui_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.jdt_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.jem.beaninfo_1.1.0.1/
file:/c:/a/eclipse/plugins/org.eclipse.jem.proxy_1.1.0.1/
file:/c:/a/eclipse/plugins/org.eclipse.jem.ui_1.1.0.1/
file:/c:/a/eclipse/plugins/org.eclipse.jem.util_1.1.0.1/
file:/c:/a/eclipse/plugins/org.eclipse.jem.workbench_1.1.0.1 /
file:/c:/a/eclipse/plugins/org.eclipse.jem_1.1.0.1/
file:/c:/a/eclipse/plugins/org.eclipse.jface.text_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.jface_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.ltk.core.refactoring_ 3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3. 1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.osgi.services_3.1.1.j ar
file:/c:/a/eclipse/plugins/org.eclipse.osgi.util_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.osgi_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.pde.build_3.1.0/
file:/c:/a/eclipse/plugins/org.eclipse.pde.core_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.pde.doc.user_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.pde.junit.runtime_3.1 .0/
file:/c:/a/eclipse/plugins/org.eclipse.pde.runtime_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.pde.source_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.pde.ui_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.pde_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.platform.doc.isv_3.1. 1/
file:/c:/a/eclipse/plugins/org.eclipse.platform.doc.user_3.1 .1/
file:/c:/a/eclipse/plugins/org.eclipse.platform.source.win32 .win32.x86_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.platform.source_3.1.1 /
file:/c:/a/eclipse/plugins/org.eclipse.platform_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.rcp.source.win32.win3 2.x86_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.rcp.source_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.rcp_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.sdk_3.1.1/
file:/c:/a/eclipse/plugins/org.eclipse.search_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.swt.win32.win32.x86_3 .1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.swt_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.team.core_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.team.cvs.core_3.1.1.j ar
file:/c:/a/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.1.0/
file:/c:/a/eclipse/plugins/org.eclipse.team.cvs.ssh_3.1.0.ja r
file:/c:/a/eclipse/plugins/org.eclipse.team.cvs.ui_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.team.ui_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.text_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.tomcat_4.1.30.1/
file:/c:/a/eclipse/plugins/org.eclipse.ui.browser_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.cheatsheets_3.1.1. jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.console_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.editors_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.externaltools_3.1. 1.jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.forms_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.ide_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.intro_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.presentations.r21_ 3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.views_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.win32_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.workbench.compatib ility_3.1.0/
file:/c:/a/eclipse/plugins/org.eclipse.ui.workbench.textedit or_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.ui.workbench_3.1.1.ja r
file:/c:/a/eclipse/plugins/org.eclipse.ui_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.update.configurator_3 .1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.update.core.win32_3.1 .0.jar
file:/c:/a/eclipse/plugins/org.eclipse.update.core_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.update.scheduler_3.1. 0.jar
file:/c:/a/eclipse/plugins/org.eclipse.update.ui_3.1.1.jar
file:/c:/a/eclipse/plugins/org.eclipse.ve.cde_1.1.0.1/
file:/c:/a/eclipse/plugins/org.eclipse.ve.doc_1.1.0/
file:/c:/a/eclipse/plugins/org.eclipse.ve.java.core_1.1.0.1/
file:/c:/a/eclipse/plugins/org.eclipse.ve.jfc_1.1.0.1/
file:/c:/a/eclipse/plugins/org.eclipse.ve.propertysheet_1.1. 0.1/
file:/c:/a/eclipse/plugins/org.eclipse.ve.swt_1.1.0.1/
file:/c:/a/eclipse/plugins/org.eclipse.ve_1.1.0/
file:/c:/a/eclipse/plugins/org.eclipse.xsd.ecore.importer_2. 1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.xsd.editor_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.xsd.edit_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.xsd_2.1.1.jar
file:/c:/a/eclipse/plugins/org.junit_3.8.1/
error log
!ENTRY org.eclipse.ve.java.core 4 0 2005-12-19 08:44:09.31
!MESSAGE Exception thrown.
!STACK 0
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ve.java.core 4 0 2005-12-19 08:44:11.796
!STACK 0
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ve.java.core 4 0 2005-12-19 08:46:40.890
!STACK 0
at
at
at
at
at
at
at
at
created source by VE:
import javax.swing.JDesktopPane;
public class Test extends JDesktopPane {
* This is the default constructor
public Test() {
super();
initialize();
* This method initializes this
* @return void
private void initialize() {
this.setSize(300, 200);
Does anyone have good idea what's going on?
Sang Uk Seong
Re: VE 1.1.0.1 Parse Error with NullPointerException [message #113721 is a reply to message #113677] Mon, 19 December 2005 12:55 Go to previous messageGo to next message
Please do a Project > Clean all. It looks like the moving to a new
system messed up the cache.
Sri.
Sang Uk Seong wrote:
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> 2a8_78
> -data
> -clean
> -refresh
> -vm
> -Xmx256M
> -jar
> eof=eof
> file.encoding=MS949
> file.separator=\
> line.separator=
se
nte
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.clean=true
> osgi.nl=ko_KR
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> user.country=KR
> user.language=ko
> user.name=sang
> user.variant=
> *** Features:
> Resources"
> [Resolved]
> [Resolved]
> [Resolved]
> Support" [Resolved]
> [Resolved]
> Editor" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Editor" [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> Support" [Active]
> [Resolved]
> [Active]
> [Resolved]
> Support" [Resolved]
> Guide" [Resolved]
> Runtime" [Active]
> Guide" [Resolved]
> [Resolved]
> [Resolved]
> Windows" [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> [Active]
> [Resolved]
> [Active]
> [Active]
> [Resolved]
> [Resolved]
> Configured sites:
> platform:/base/
> error log
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> public Test() {
> super();
> initialize();
> * @return void
> Regards,
> Sang Uk Seong
Re: VE 1.1.0.1 Parse Error with NullPointerException [message #113738 is a reply to message #113721] Mon, 19 December 2005 14:12 Go to previous messageGo to next message
Sri Gunturi wrote:
> Hello,
Hello Sri,
I did Clean All multiple times in my original projects (I read previous
issues in newsgroup and tried all -- including using default JRE, clean
all...) and it didn't work . So I created new project in new workspace
and created new file with New Visual Class wizard. And this is output
from this new file in new project in new workspace.
I have nothing else in my workspace to be messed up with.
Sang Uk Seong
> Regards,
> Sri.
>> Hello,
>> XP SP2) with same JDK (1.4.2_08) and using same eclipse distribution
>> (3.1.1 SDK), now VE no longer works for me.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> workspace, I created new Java Project, I created new Visual Class
>> using New Java Visual Class viwzard, and didn't modify anything. Still
>> VE gives me same exception and not doing much.
>> win32
>> -ws
>> win32
>> -arch
>> x86
>> -launcher
>> -name
>> Eclipse
>> -showsplash
>> 600
>> -exitdata
>> 2a8_78
>> -data
>> -clean
>> -refresh
>> -vm
>> -Xmx256M
>> -jar
>> eof=eof
>> file.encoding=MS949
>> file.separator=\
>> line.separator=
r
> se
o
> nte
>> os.arch=x86
>> os.name=Windows XP
>> os.version=5.1
>> osgi.arch=x86
>> osgi.clean=true
>> osgi.nl=ko_KR
>> osgi.os=win32
>> osgi.ws=win32
>> path.separator=;
>> user.country=KR
>> user.language=ko
>> user.name=sang
>> user.variant=
>> *** Features:
>> Environment Developer Resources"
>> Win32 Fragment" [Resolved]
>> [Resolved]
>> UI" [Resolved]
>> [Resolved]
>> Support" [Resolved]
>> [Resolved]
>> (SDO) Editor" [Resolved]
>> [Resolved]
>> [Resolved]
>> [Resolved]
>> [Resolved]
>> [Resolved]
>> Editor" [Resolved]
>> [Resolved]
>> [Resolved]
>> [Active]
>> Support" [Active]
>> [Resolved]
>> [Active]
>> [Resolved]
>> Support" [Resolved]
>> Guide" [Resolved]
>> Runtime" [Active]
>> Environment Developer Resources" [Resolved]
>> Developer Guide" [Resolved]
>> [Resolved]
>> Windows" [Resolved]
>> [Resolved]
>> Compatibility" [Resolved]
>> [Active]
>> [Active]
>> Windows" [Resolved]
>> [Active]
>> Classes" [Active]
>> [Active]
>> Toolkit" [Resolved]
>> [Resolved]
>> Location:
>> Configured sites:
>> platform:/base/
>> error log
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> public Test() {
>> super();
>> initialize();
>> * @return void
>> Regards,
>> Sang Uk Seong
Re: VE 1.1.0.1 Parse Error with NullPointerException [message #113768 is a reply to message #113738] Mon, 19 December 2005 16:18 Go to previous messageGo to next message
Did you try providing the -clean option when launching Eclipse. And also
how about just downloading all the plugins again and extracting them to
a brand new eclipse/ folder and trying it.
Sri.
> Sri Gunturi wrote:
>> Hello,
> Hello Sri,
> Regards,
> Sang Uk Seong
>> Regards,
>> Sri.
>>> Hello,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Still VE gives me same exception and not doing much.
>>> win32
>>> -ws
>>> win32
>>> -arch
>>> x86
>>> -launcher
>>> -name
>>> Eclipse
>>> -showsplash
>>> 600
>>> -exitdata
>>> 2a8_78
>>> -data
>>> -clean
>>> -refresh
>>> -vm
>>> -Xmx256M
>>> -jar
>>> eof=eof
>>> file.encoding=MS949
>>> file.separator=\
>>> line.separator=
a
> r
>> se
C
> o
>> nte
>>> os.arch=x86
>>> os.name=Windows XP
>>> os.version=5.1
>>> osgi.arch=x86
>>> osgi.clean=true
>>> osgi.nl=ko_KR
>>> osgi.os=win32
>>> osgi.ws=win32
>>> path.separator=;
>>> user.country=KR
>>> user.language=ko
>>> user.name=sang
>>> user.variant=
>>> *** Features:
>>> [Resolved]
>>> UI" [Resolved]
>>> [Resolved]
>>> Support" [Resolved]
>>> [Resolved]
>>> (SDO) Edit Support" [Resolved]
>>> [Resolved]
>>> [Resolved]
>>> [Resolved]
>>> UI" [Resolved]
>>> [Resolved]
>>> [Resolved]
>>> Guide" [Resolved]
>>> [Active]
>>> Support" [Active]
>>> [Resolved]
>>> Support" [Active]
>>> [Resolved]
>>> Support" [Resolved]
>>> Guide" [Resolved]
>>> [Resolved]
>>> Runtime" [Active]
>>> [Resolved]
>>> Windows" [Resolved]
>>> [Resolved]
>>> [Active]
>>> [Active]
>>> Windows" [Resolved]
>>> [Active]
>>> [Resolved]
>>> Classes" [Active]
>>> [Active]
>>> Toolkit" [Resolved]
>>> [Resolved]
>>> Location:
>>> Configured sites:
>>> platform:/base/
>>> error log
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> public Test() {
>>> super();
>>> initialize();
>>> * @return void
>>> Regards,
>>> Sang Uk Seong
Re: VE 1.1.0.1 Parse Error with NullPointerException [message #113792 is a reply to message #113768] Mon, 19 December 2005 17:18 Go to previous messageGo to next message
Hello Sri,
I did what you told me.
Download again all new Eclipse 3.1.1 SDK, EMF-SDO-RUNTIME 2.1.0
GEF-runtime 3.1, VE-runtime 1.1.0.1 and install again on c:\a\eclipse
directory.
Create new workspace and create new project "a" and create test.java
using new Visual Class wizard.
I got same exception thrown. So, i clean all project and tried to open
the file again, and still same exception.
once again:
Configuration Details:
*** Date: Mon Dec 19 14:16:48 PST 2005
win32
-ws
win32
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
57c_78
-data
-clean
-refresh
-vm
eclipse.startTime=1135030567453
-Xmx256M
-jar
eof=eof
file.encoding=MS949
file.separator=\
line.separator=
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.clean=true
osgi.nl=ko_KR
osgi.os=win32
osgi.ws=win32
path.separator=;
user.country=KR
user.language=ko
user.name=sang
user.variant=
*** Features:
org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.1.0) "EMF Service Data Objects (SDO)"
org.eclipse.gef (3.1.0) "Graphical Editing Framework"
Resources"
org.eclipse.compare (3.1.1) "Compare Support" [Resolved]
org.eclipse.draw2d (3.1.0) "Draw2d" [Active]
org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)" [Resolved]
[Resolved]
[Resolved]
Support" [Resolved]
org.eclipse.emf.ecore.edit (2.1.0) "EMF Ecore Edit Support" [Resolved]
[Resolved]
Editor" [Resolved]
org.eclipse.emf.edit (2.1.0) "EMF Edit" [Resolved]
org.eclipse.emf.importer.java (2.1.0) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.1.0) "EMF Rose Importer" [Resolved]
[Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.0) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.gef (3.1.0) "Graphical Editing Framework" [Active]
[Resolved]
[Resolved]
[Active]
Support" [Active]
[Resolved]
[Active]
Support" [Resolved]
org.eclipse.pde.core (3.1.1) "Plug-in Development Core" [Resolved]
Guide" [Resolved]
Runtime" [Active]
Guide" [Resolved]
[Resolved]
[Resolved]
org.eclipse.search (3.1.1) "Search Support" [Resolved]
Windows" [Resolved]
[Resolved]
[Resolved]
[Active]
[Resolved]
[Active]
[Active]
[Resolved]
#Mon Dec 19 14:16:48 PST 2005
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<web-browsers
current\="0">\r\n<system/>\r\n<external name\="Firefox"
location\="C\:\\Program Files\\Mozilla
Firefox\\firefox.exe"/>\r\n<external name\="Internet Explorer"
location\="C\:\\Program Files\\Internet
Explorer\\iexplore.exe"/>\r\n</web-browsers>
/instance/org.eclipse.ui.ide/platformState=137
@org.eclipse.ui.browser=3.1.1
/instance/org.eclipse.ant.ui/useQuickDiffPrefPage=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\ecl ipse\\workspace5
defaultVMConnector\="">\r\n<vmType
id\="0" javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api/"
path\="C\:\\j2sdk1.4.2_08"/>\r\n</vmType>\r\n</vmSettings >\r\n
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/instance/org.eclipse.jdt.ui/layout=1
/instance/org.eclipse.ve.java.core/VISUAL_CLASS_WIZARD_SELEC TED_ELEMENT_KEY=org.eclipse.ve.jfc.swing.cat-Frame-javax.swi ng.JFrame
@org.eclipse.ant.ui=3.1.1
@org.eclipse.team.ui=3.1.1
/instance/org.eclipse.ant.ui/useAnnotationsPrefPage=true
Configured sites:
platform:/base/
ID: org.eclipse.gef, Version: 3.1.0
ID: org.eclipse.emf, Version: 2.1.0
ID: org.eclipse.emf.ecore.sdo, Version: 2.1.0
file:/c:/a/eclipse/plugins/org.eclipse.draw2d_3.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ecore.edit_2.1.0. jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.ecore.sdo_2.1.0.j ar
file:/c:/a/eclipse/plugins/org.eclipse.emf.edit_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.importer.java_2.1 .0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.importer.rose_2.1 .0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf.mapping.ecore2xml .ui_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.emf_2.1.0.jar
file:/c:/a/eclipse/plugins/org.eclipse.gef_3.1.0.jar
Error Log:
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-12-19 14:11:28.734
!MESSAGE
+++ Warning +++: Mon Dec 19 14:11:28 PST 2005 Build job waiting when
trying to start beaninfo registry. Possible race.
!ENTRY org.eclipse.ve.java.core 4 0 2005-12-19 14:11:29.718
!STACK 0
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ve.java.core 4 0 2005-12-19 14:13:32.609
!STACK 0
at
at
at
at
at
at
at
at
!SESSION 2005-12-19 14:16:07.453
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ko_KR
Framework arguments: -refresh
Command-line arguments: -os win32 -ws win32 -arch x86 -data
C:\eclipse\workspace5 -clean -refresh
!ENTRY org.eclipse.ve.java.core 4 0 2005-12-19 14:16:27.62
!STACK 0
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ve.java.core 4 0 2005-12-19 14:16:38.843
!STACK 0
at
at
at
at
at
at
at
at
-- test.java that VE generated --
import java.awt.BorderLayout;
import javax.swing.JPanel;
import javax.swing.JFrame;
public class test extends JFrame {
private JPanel jContentPane = null;
public test() {
super();
initialize();
* @return void
this.setContentPane(getJContentPane());
this.setTitle("JFrame");
* This method initializes jContentPane
* @return javax.swing.JPanel
private JPanel getJContentPane() {
if (jContentPane == null) {
jContentPane = new JPanel();
jContentPane.setLayout(new BorderLayout());
return jContentPane;
> Regards,
> Sri.
>> Sri Gunturi wrote:
>>> Hello,
>>> new system messed up the cache.
>> Hello Sri,
>> previous issues in newsgroup and tried all -- including using default
>> JRE, clean all...) and it didn't work . So I created new project in
>> new workspace and created new file with New Visual Class wizard. And
>> this is output from this new file in new project in new workspace.
>> Regards,
>> Sang Uk Seong
>>> Regards,
>>> Sri.
>>>> Hello,
>>>> (Windows XP SP2) with same JDK (1.4.2_08) and using same eclipse
>>>> distribution (3.1.1 SDK), now VE no longer works for me.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> win32
>>>> -ws
>>>> win32
>>>> -arch
>>>> x86
>>>> -launcher
>>>> -name
>>>> Eclipse
>>>> -showsplash
>>>> 600
>>>> -exitdata
>>>> 2a8_78
>>>> -data
>>>> -clean
>>>> -refresh
>>>> -vm
>>>> -Xmx256M
>>>> -jar
>>>> eof=eof
>>>> file.encoding=MS949
>>>> file.separator=\
>>>> line.separator=
p
> a
>> r
>>> se
g
> C
>> o
>>> nte
>>>> os.arch=x86
>>>> os.name=Windows XP
>>>> os.version=5.1
>>>> osgi.arch=x86
>>>> osgi.clean=true
>>>> osgi.nl=ko_KR
>>>> osgi.os=win32
>>>> osgi.ws=win32
>>>> path.separator=;
>>>> user.country=KR
>>>> user.language=ko
>>>> user.name=sang
>>>> user.variant=
>>>> *** Features:
>>>> Resources"
>>>> [Resolved]
>>>> [Resolved]
>>>> UI" [Resolved]
>>>> [Resolved]
>>>> Support" [Resolved]
>>>> [Resolved]
>>>> [Resolved]
>>>> [Resolved]
>>>> [Resolved]
>>>> UI"
Re: VE 1.1.0.1 Parse Error with NullPointerException [message #113810 is a reply to message #113792] Mon, 19 December 2005 17:42 Go to previous message
Only thing I notice is that VE 1.1.0.1 is targeted against Eclipse 3.1
and not Eclispe 3.1.1. Could you please try it with Eclipse 3.1.
Sri.
> Hello Sri,
> directory.
> once again:
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> 57c_78
> -data
> -clean
> -refresh
> -vm
> -Xmx256M
> -jar
> eof=eof
> file.encoding=MS949
> file.separator=\
> line.separator=
se
nte
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.clean=true
> osgi.nl=ko_KR
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> user.country=KR
> user.language=ko
> user.name=sang
> user.variant=
> *** Features:
> Resources"
> [Resolved]
> [Resolved]
> [Resolved]
> Support" [Resolved]
> [Resolved]
> Editor" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> Support" [Active]
> [Resolved]
> [Active]
> [Resolved]
> Support" [Resolved]
> Guide" [Resolved]
> Runtime" [Active]
> Guide" [Resolved]
> [Resolved]
> [Resolved]
> Windows" [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> [Active]
> [Resolved]
> [Active]
> [Active]
> [Resolved]
> Configured sites:
> platform:/base/
> Error Log:
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> public test() {
> super();
> initialize();
> * @return void
>> also how about just downloading all the plugins again and extracting
>> them to a brand new eclipse/ folder and trying it.
>> Regards,
>> Sri.
>>> Sri Gunturi wrote:
>>>> Hello,
>>> Hello Sri,
>>> Regards,
>>> Sang Uk Seong
>>>> Regards,
>>>> Sri.
>>>>> Hello,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> win32
>>>>> -ws
>>>>> win32
>>>>> -arch
>>>>> x86
>>>>> -launcher
>>>>> -name
>>>>> Eclipse
>>>>> -showsplash
>>>>> 600
>>>>> -exitdata
>>>>> 2a8_78
>>>>> -data
>>>>> -clean
>>>>> -refresh
>>>>> -vm
>>>>> -Xmx256M
>>>>> -jar
>>>>> eof=eof
>>>>> file.encoding=MS949
>>>>> file.separator=\
>>>>> line.separator=
> p
>> a
>>> r
>>>> se
n
> g
>> C
>>> o
>>>> nte
>>>>> os.arch=x86
>>>>> os.name=Windows XP
>>>>> os.version=5.1
>>>>> osgi.arch=x86
>>>>> osgi.clean=true
>>>>> osgi.nl=ko_KR
>>>>> osgi.os=win32
>>>>> osgi.ws=win32
>>>>> path.separator=;
>>>>> user.country=KR
>>>>> user.language=ko
>>>>> user.name=sang
>>>>> user.variant=
>>>>> *** Features:
Re: VE 1.1.0.1 Parse Error with NullPointerException [message #611671 is a reply to message #113677] Mon, 19 December 2005 12:55 Go to previous message
Sri.
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> 2a8_78
> -data
> -clean
> -refresh
> -vm
> -Xmx256M
> -jar
> eof=eof
> file.encoding=MS949
> file.separator=\
> line.separator=
se
nte
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.clean=true
> osgi.nl=ko_KR
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> user.country=KR
> user.language=ko
> user.name=sang
> user.variant=
> *** Features:
> Resources"
> [Resolved]
> [Resolved]
> [Resolved]
> Support" [Resolved]
> [Resolved]
> Editor" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Editor" [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> Support" [Active]
> [Resolved]
> [Active]
> [Resolved]
> Support" [Resolved]
> Guide" [Resolved]
> Runtime" [Active]
> Guide" [Resolved]
> [Resolved]
> [Resolved]
> Windows" [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> [Active]
> [Resolved]
> [Active]
> [Active]
> [Resolved]
> [Resolved]
> Configured sites:
> platform:/base/
> error log
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> public Test() {
> super();
> initialize();
> * @return void
> Regards,
> Sang Uk Seong
Re: VE 1.1.0.1 Parse Error with NullPointerException [message #611672 is a reply to message #113721] Mon, 19 December 2005 14:12 Go to previous message
Sri Gunturi wrote:
> Hello,
Hello Sri,
Sang Uk Seong
> Regards,
> Sri.
>> Hello,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> win32
>> -ws
>> win32
>> -arch
>> x86
>> -launcher
>> -name
>> Eclipse
>> -showsplash
>> 600
>> -exitdata
>> 2a8_78
>> -data
>> -clean
>> -refresh
>> -vm
>> -Xmx256M
>> -jar
>> eof=eof
>> file.encoding=MS949
>> file.separator=\
>> line.separator=
r
> se
o
> nte
>> os.arch=x86
>> os.name=Windows XP
>> os.version=5.1
>> osgi.arch=x86
>> osgi.clean=true
>> osgi.nl=ko_KR
>> osgi.os=win32
>> osgi.ws=win32
>> path.separator=;
>> user.country=KR
>> user.language=ko
>> user.name=sang
>> user.variant=
>> *** Features:
>> [Resolved]
>> UI" [Resolved]
>> [Resolved]
>> Support" [Resolved]
>> [Resolved]
>> [Resolved]
>> [Resolved]
>> [Resolved]
>> [Resolved]
>> [Resolved]
>> Editor" [Resolved]
>> [Resolved]
>> [Resolved]
>> [Active]
>> Support" [Active]
>> [Resolved]
>> [Active]
>> [Resolved]
>> Support" [Resolved]
>> Guide" [Resolved]
>> Runtime" [Active]
>> [Resolved]
>> Windows" [Resolved]
>> [Resolved]
>> [Active]
>> [Active]
>> Windows" [Resolved]
>> [Active]
>> Classes" [Active]
>> [Active]
>> Toolkit" [Resolved]
>> [Resolved]
>> Location:
>> Configured sites:
>> platform:/base/
>> error log
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> public Test() {
>> super();
>> initialize();
>> * @return void
>> Regards,
>> Sang Uk Seong
Re: VE 1.1.0.1 Parse Error with NullPointerException [message #611674 is a reply to message #113738] Mon, 19 December 2005 16:18 Go to previous message
Sri.
> Sri Gunturi wrote:
>> Hello,
> Hello Sri,
> Regards,
> Sang Uk Seong
>> Regards,
>> Sri.
>>> Hello,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> win32
>>> -ws
>>> win32
>>> -arch
>>> x86
>>> -launcher
>>> -name
>>> Eclipse
>>> -showsplash
>>> 600
>>> -exitdata
>>> 2a8_78
>>> -data
>>> -clean
>>> -refresh
>>> -vm
>>> -Xmx256M
>>> -jar
>>> eof=eof
>>> file.encoding=MS949
>>> file.separator=\
>>> line.separator=
a
> r
>> se
C
> o
>> nte
>>> os.arch=x86
>>> os.name=Windows XP
>>> os.version=5.1
>>> osgi.arch=x86
>>> osgi.clean=true
>>> osgi.nl=ko_KR
>>> osgi.os=win32
>>> osgi.ws=win32
>>> path.separator=;
>>> user.country=KR
>>> user.language=ko
>>> user.name=sang
>>> user.variant=
>>> *** Features:
>>> [Resolved]
>>> UI" [Resolved]
>>> [Resolved]
>>> Support" [Resolved]
>>> [Resolved]
>>> [Resolved]
>>> [Resolved]
>>> [Resolved]
>>> UI" [Resolved]
>>> [Resolved]
>>> [Resolved]
>>> Guide" [Resolved]
>>> [Active]
>>> Support" [Active]
>>> [Resolved]
>>> Support" [Active]
>>> [Resolved]
>>> Support" [Resolved]
>>> Guide" [Resolved]
>>> [Resolved]
>>> Runtime" [Active]
>>> [Resolved]
>>> Windows" [Resolved]
>>> [Resolved]
>>> [Active]
>>> [Active]
>>> Windows" [Resolved]
>>> [Active]
>>> [Resolved]
>>> Classes" [Active]
>>> [Active]
>>> Toolkit" [Resolved]
>>> [Resolved]
>>> Location:
>>> Configured sites:
>>> platform:/base/
>>> error log
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> public Test() {
>>> super();
>>> initialize();
>>> * @return void
>>> Regards,
>>> Sang Uk Seong
Re: VE 1.1.0.1 Parse Error with NullPointerException [message #611675 is a reply to message #113768] Mon, 19 December 2005 17:18 Go to previous message
Hello Sri,
directory.
once again:
win32
-ws
win32
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
57c_78
-data
-clean
-refresh
-vm
-Xmx256M
-jar
eof=eof
file.encoding=MS949
file.separator=\
line.separator=
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.clean=true
osgi.nl=ko_KR
osgi.os=win32
osgi.ws=win32
path.separator=;
user.country=KR
user.language=ko
user.name=sang
user.variant=
*** Features:
Resources"
[Resolved]
[Resolved]
Support" [Resolved]
[Resolved]
Editor" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Active]
Support" [Active]
[Resolved]
[Active]
Support" [Resolved]
Guide" [Resolved]
Runtime" [Active]
Guide" [Resolved]
[Resolved]
[Resolved]
Windows" [Resolved]
[Resolved]
[Resolved]
[Active]
[Resolved]
[Active]
[Active]
[Resolved]
Configured sites:
platform:/base/
Error Log:
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
public test() {
super();
initialize();
* @return void
> Regards,
> Sri.
>> Sri Gunturi wrote:
>>> Hello,
>> Hello Sri,
>> Regards,
>> Sang Uk Seong
>>> Regards,
>>> Sri.
>>>> Hello,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> win32
>>>> -ws
>>>> win32
>>>> -arch
>>>> x86
>>>> -launcher
>>>> -name
>>>> Eclipse
>>>> -showsplash
>>>> 600
>>>> -exitdata
>>>> 2a8_78
>>>> -data
>>>> -clean
>>>> -refresh
>>>> -vm
>>>> -Xmx256M
>>>> -jar
>>>> eof=eof
>>>> file.encoding=MS949
>>>> file.separator=\
>>>> line.separator=
p
> a
>> r
>>> se
g
> C
>> o
>>> nte
>>>> os.arch=x86
>>>> os.name=Windows XP
>>>> os.version=5.1
>>>> osgi.arch=x86
>>>> osgi.clean=true
>>>> osgi.nl=ko_KR
>>>> osgi.os=win32
>>>> osgi.ws=win32
>>>> path.separator=;
>>>> user.country=KR
>>>> user.language=ko
>>>> user.name=sang
>>>> user.variant=
>>>> *** Features:
>>>> Resources"
>>>> [Resolved]
>>>> [Resolved]
>>>> UI" [Resolved]
>>>> [Resolved]
>>>> Support" [Resolved]
>>>> [Resolved]
>>>> [Resolved]
>>>> [Resolved]
>>>> [Resolved]
>>>> UI"
Re: VE 1.1.0.1 Parse Error with NullPointerException [message #611676 is a reply to message #113792] Mon, 19 December 2005 17:42 Go to previous message
Sri.
> Hello Sri,
> directory.
> once again:
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> 57c_78
> -data
> -clean
> -refresh
> -vm
> -Xmx256M
> -jar
> eof=eof
> file.encoding=MS949
> file.separator=\
> line.separator=
se
nte
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.clean=true
> osgi.nl=ko_KR
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> user.country=KR
> user.language=ko
> user.name=sang
> user.variant=
> *** Features:
> Resources"
> [Resolved]
> [Resolved]
> [Resolved]
> Support" [Resolved]
> [Resolved]
> Editor" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> Support" [Active]
> [Resolved]
> [Active]
> [Resolved]
> Support" [Resolved]
> Guide" [Resolved]
> Runtime" [Active]
> Guide" [Resolved]
> [Resolved]
> [Resolved]
> Windows" [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> [Active]
> [Resolved]
> [Active]
> [Active]
> [Resolved]
> Configured sites:
> platform:/base/
> Error Log:
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> public test() {
> super();
> initialize();
> * @return void
>> Regards,
>> Sri.
>>> Sri Gunturi wrote:
>>>> Hello,
>>> Hello Sri,
>>> Regards,
>>> Sang Uk Seong
>>>> Regards,
>>>> Sri.
>>>>> Hello,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> win32
>>>>> -ws
>>>>> win32
>>>>> -arch
>>>>> x86
>>>>> -launcher
>>>>> -name
>>>>> Eclipse
>>>>> -showsplash
>>>>> 600
>>>>> -exitdata
>>>>> 2a8_78
>>>>> -data
>>>>> -clean
>>>>> -refresh
>>>>> -vm
>>>>> -Xmx256M
>>>>> -jar
>>>>> eof=eof
>>>>> file.encoding=MS949
>>>>> file.separator=\
>>>>> line.separator=
> p
>> a
>>> r
>>>> se
n
> g
>> C
>>> o
>>>> nte
>>>>> os.arch=x86
>>>>> os.name=Windows XP
>>>>> os.version=5.1
>>>>> osgi.arch=x86
>>>>> osgi.clean=true
>>>>> osgi.nl=ko_KR
>>>>> osgi.os=win32
>>>>> osgi.ws=win32
>>>>> path.separator=;
>>>>> user.country=KR
>>>>> user.language=ko
>>>>> user.name=sang
>>>>> user.variant=
>>>>> *** Features:
Previous Topic:Source code for libswt-gtk-print?
Next Topic:extending ve - documentation ???
Current Time: Wed Nov 05 23:19:55 EST 2025
Powered by FUDForum. Page generated in 0.08697 seconds
