| AGR Playback Problem [message #112326] |
Thu, 13 September 2007 06:24  |
I used AGR to record the creation of a Dynamic Web Project. When I run the
script in standard mode, the New Dynamic Web Project Wizard is probably
closed before it has completed its operation. The message 'There is an
active operation going on. It should be cancelled before closing the
wizard.' appears. I tried introducing some wait time, but this doesn't
seem to help.
Could you please tell me how to keep the wizard open till it has completed
creating the project?
Thanks in advance.
Sumina
| Re: AGR Playback Problem [message #113632 is a reply to message #112425] |
Mon, 01 October 2007 07:14  |
Hi Sumina,
There is no way to solve this issue in quick mode since the timeout
threshold is not configurable. Quick mode is intended to emulate standard
mode, so please open a defect to provide this configurability.
Paul
"Sumina" <sumina.kapoor@sungard.de> wrote in message
news:958fb989c59ac0c9bf974049f46312a4$1@www.eclipse.org...
> If the test is run in standard mode, the problem can be resolved by
> increasing timeout threshold. But the problem persists in quick mode.
> Could you please give some suggestions to prevent timeout in quick mode as
> well?
> Best regards,
> Sumina
FUDForum. Page generated in 0.03381 seconds
