Home » Modeling » EMF » [CDO] Enable security manager in embedded server
[CDO] Enable security manager in embedded server [message #1131072] Thu, 10 October 2013 02:53 Go to next message
We need to enable security manager for an embedded CDO server (4.2). We are starting the server using code similar to embedded CDO server.
How do we enable security manager in the code snippet above.
Re: [CDO] Enable security manager in embedded server [message #1133995 is a reply to message #1131072] Sat, 12 October 2013 02:41 Go to previous messageGo to next message
Am 10.10.2013 08:53, schrieb Ashish Shinde:
> http://wiki.eclipse.org/CDO/Embedded.
There's an example in org.eclipse.emf.cdo.server.internal.security.SecurityExtension.configureRepository(Element):
String description = securityManagerElement.getAttribute("description");
if (description == null || description.length() == 0)
description = securityManagerElement.getAttribute("realmPath");
description = DEFAULT_REALM_PATH;
InternalSecurityManager securityManager = (InternalSecurityManager)container.getElement(
SecurityManagerFactory.PRODUCT_GROUP, "default", description);
securityManager.setRepository(repository);
It's best do do that before the repository gets activated, but I it's also possible thereafter.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Enable security manager in embedded server [message #1138626 is a reply to message #1133995] Tue, 15 October 2013 03:57 Go to previous message
Thanks Eike. That worked albeit with a problem. Had to make a call to SecurityManagerUtil.prepareContainer(). However from the looks of it SecurityManager code internally using IPLuginContainer.INSTANCE as the container. Therefore this works only if the container is IPLuginContainer.INSTANCE. I get factory not found exceptions if I use a custom container(even after calling SecurityManagerUtil.prepareContainer()).
For now I could use IPLuginContainer.INSTANCE for tests cases. However if and when tests run in parallel I will be affected I guess.
Eike Stepper wrote on Sat, 12 October 2013 02:41
Cheers
/Eike
Previous Topic:[CDO] In-transaction unique ID generator?
Next Topic:[CDO] AbstractCDOIDLong
Current Time: Sat Jul 26 07:57:57 EDT 2025
Powered by FUDForum. Page generated in 0.08060 seconds
