Home » Eclipse Projects » Remote Application Platform (RAP) » WebSphere deployment
WebSphere deployment [message #113294] Mon, 24 November 2008 13:45 Go to next message
Hello
I have a problem with WebSphere. I can made a war-file as described in
http://rapblog.innoopract.com/2007/12/rap-deployment-part-2- deploying-your.html
but I also have to debug (not only deploy) my application on WebSphere
6.1. I tried to do this with RAD 7.5. But I had a problem.
I made this:
1) I made a web-project.
Two projects: web-project and ear-project with description for my
web-project were created by wizard.
2) I copied the same WEB-INF folder that I used in my war-file to my
web-project
3) I tried to debug.
I have an Error 404: ProxyServlet at this point
4) After that I deleted servletbridge.jar folder from lib folder and
copied it's sources to src folder of my web-project.
5) I tried to debug again.
I saw that no osgi budles loaded.
6) I also tried to specify commandline argument in my web.xml:
<init-param>
<param-name>commandline</param-name>
<param-value>-console</param-value>
</init-param>
But I can see "osgi>" in my console only once.
What can I do?
Thank you, Igor
Re: WebSphere deployment [message #113344 is a reply to message #113294] Mon, 24 November 2008 14:32 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Igor,
to debug your application I would recommend to launch it from within
Eclipse (with RAP Tooling installed).
HTH
Rüdiger
Igor Pavlenko wrote:
> Hello
> I made this:
> web-project
> <init-param>
> </init-param>
> What can I do?
> Thank you, Igor
Re: WebSphere deployment [message #113379 is a reply to message #113344] Tue, 25 November 2008 00:30 Go to previous messageGo to next message
Yes. It is right. But I also have to fix one bug that is reproduceable
only on WebSphere. So I have to debug my application on it. We have to
support WebApplication as a platform and it is not my decision.
Igor
Re: WebSphere deployment [message #113493 is a reply to message #113379] Wed, 26 November 2008 03:12 Go to previous messageGo to next message
sorry Igor, I can't help a lot with this. I have no idea about
WebSphere.
Did you ensure that that war runs at all? E.g. did you try to deploy
it on Tomcat?
> Igor
Re: WebSphere deployment [message #113835 is a reply to message #113493] Thu, 27 November 2008 08:38 Go to previous messageGo to next message
Yes, the war file can be deployed and runned on my external WebSphere 6.1
installation. But I cannot run this war file on the WebSphere 6.1 runtime
that is provided with RAD7.5. But I still think that problem is in my
configuration.
Re: WebSphere deployment [message #114898 is a reply to message #113493] Tue, 09 December 2008 04:21 Go to previous messageGo to next message
Hi, Rüdiger!
I've deployed my application to WebSphere without problems, but I see
another problem - I can't stop application after using application url
in browser, so I think that problem appear when workbench is initialized.
Do you have any ideas how to fix it?
Thanks.
> sorry Igor, I can't help a lot with this. I have no idea about WebSphere.
> Did you ensure that that war runs at all? E.g. did you try to deploy it
> on Tomcat?
>> Igor
Re: WebSphere deployment [message #114973 is a reply to message #114898] Tue, 09 December 2008 06:43 Go to previous messageGo to next message
Boris Stepanov wrote:
> Hi, Rüdiger!
first thing I would do is to make sure that the code uses
UICallback#activate() in pair with #deactivate()
> Thanks.
>> it on Tomcat?
>>> reproduceable only on WebSphere. So I have to debug my application on
>>> it. We have to support WebApplication as a platform and it is not my
>>> decision.
>>> Igor
Re: WebSphere deployment [message #115189 is a reply to message #114973] Wed, 10 December 2008 03:31 Go to previous messageGo to next message
Hi Rüdiger,
Thanks for advice, I did it as you described in one of your posts using
SessionStoreListener and problem is fixed now. I use
UICallback.activate() in WorkbenchWindowAdvisor.preWindowOpen()
(SessionStoreListener is added there) and UICallback.deactivate() in
WorkbenchWindowAdvisor.postWindowClose(). I'm not sure that use correct
places for that, I need callback ability in full application, where is
the best place for this task?
Thanks.
>> Hi, Rüdiger!
Re: WebSphere deployment [message #115198 is a reply to message #115189] Wed, 10 December 2008 03:56 Go to previous message
Boris,
note that if you are using the Jobs API it shouldn't be necessary to
explicitly call activate()/deactivate(). The RAP adaption of the
Jobs infrastructure does this for you.
HTH
Rüdiger
> Hi Rüdiger,
> Thanks.
>>> Hi, Rüdiger!
>>> url in browser, so I think that problem appear when workbench is
>>> initialized.
Previous Topic:ImageDescriptor createImage throws a NullPointerException
Next Topic:Dynamic JFree Charts in Rap
Current Time: Sat Jul 26 09:38:30 EDT 2025
Powered by FUDForum. Page generated in 0.26786 seconds
