Home » Modeling » TMF (Xtext) » [Xbase] getting the result type of an expression during inferring
[Xbase] getting the result type of an expression during inferring [message #1130093] Wed, 09 October 2013 04:19 Go to next message
Hello!
I am writing a GUI-Description-Language and I am using Xbase. I need to find the result type of an xbase expression during inferring.
Excerpt from the Grammar:
   WidgetProperty:
      propertyDefinition=[tkdef::WidgetPropertyDefinition]
      ( '=' '{' (expressionValue = XExpression)? '}' )?
      ( 'renderWith' renderWith = [Widget|QualifiedName] )?
      ( '{' (nestedProperties += WidgetProperty ','?)* '}' )?
A complex usage example for this.
   widget Table ResultTable {
      Content = {Partners} {
         Column { Title = {"Name"}    Value = { Name } }
         Column { Title = {"Vorname"} Value = { if (it instanceof NatPerson) "irgendwas" else "anderes" } }
Data-Model:
   public class RootModel {
      public List<Partner> getPartners () { ... }
   public class Partner {
      public String getName () { ... }
The nested properties should get a more specific data context from the parent properties if they define a data-binding expression (like "Partners" in this case). The result type of that expression is supposed to be the data-context for the nested properties.
Simplified Inferrer:
   def dispatch void infer (GuiDescription element, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase)
      acceptor.accept (element.toClass (name))
      .initializeLater[
         element.eAllContents.filter (WidgetProperty).forEach [widgetProperty, counter|
            val returnType = ...
            members += element.toMethod ('''eval_XbaseExpression_«counter»''', returnType) [
               parameters += element.toParameter ("it", widgetProperty.parameterType)
               body = widgetProperty.expressionValue
   def JvmTypeReference getParameterType (WidgetProperty property)
      if (property.eContainer instanceof WidgetProperty) {
         val parentProp = property.eContainer as WidgetProperty
         if (parentProp.expressionValue != null) {
            return parentProp.expressionValue.inferredType
         } else {
            return parentProp.parameterType
      return property.widget.dataModel.newTypeRef
The problem is now that expressionValue.inferredType does not work (and the docu says: don't use it). But what else to use? Is it at all possible to get the resulting type of the expression?
The exception that raises if used:
Caused by: java.lang.UnsupportedOperationException: TODO: import a functional handle on the type resolution that delegates to the best available (current, but evolving) result
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:141)
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultBatchTypeResolver$1.reentrantResolve(DefaultBatchTypeResolver.java:122)
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$LazyResolvedTypes.delegate(CachingBatchTypeResolver.java:114)
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:61)
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:1)
	at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:36)
	at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:127)
	... 91 more
Nicolas Cabanis
Re: [Xbase] getting the result type of an expression during inferring [message #1132598 is a reply to message #1130093] Fri, 11 October 2013 04:56 Go to previous messageGo to next message
   var typeRef = expression.inferredType
   expression.eResource.contents.add (typeRef)
   typeRef.type  // resolve
It works if the XComputedTypeReference (typeRef) is added to the Resource of the XExpression. Probably I am not supposed to do that.
Is there no clean way of resolving the result type of an expression during inferring?
[Updated on: Fri, 11 October 2013 04:57] by Moderator
Re: [Xbase] getting the result type of an expression during inferring [message #1132609 is a reply to message #1132598] Fri, 11 October 2013 05:07 Go to previous messageGo to next message
did you have a look at the domain model example.
As far as I remember there the return type for methods is optional
(and thus inferrerd from the body expression)
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: [Xbase] getting the result type of an expression during inferring [message #1178440 is a reply to message #1132609] Sat, 09 November 2013 12:07 Go to previous messageGo to next message
Hi, I'm experiencing a similar issue.
I have a grammar for defining objects with it properties and messages (those are features), then it gets into java through the jvm model inferrer.
When the property type is declared explicitly everything seems right. When it should be inferred by the initialization value it breaks.
Grammar:
Feature:
 Property | Message;
Property:
  name=ValidID (':' type=JvmTypeReference)? ('startsWith' value=XExpression)?;
The Inferrer includes:
	def dispatch void infer(HoopeObject element, IJvmDeclaredTypeAcceptor acceptor, boolean isPrelinkingPhase) {
		acceptor.accept(jvmGenericType).initializeLater [
			documentation = element.documentation
			for (feature : element.features) {
				switch feature {
					Property: {
						val type = feature.type?: feature.value.inferredType
						members += feature.toField(feature.name, type) [
							initializer = feature.value
						members += feature.toGetter(feature.name, type)
						members += feature.toSetter(feature.name, type)
This works perfectly...
val pepita = object {
	energia : double startsWith 2.0
but when I try to let the inferrer infer the type of Property initial value:
	energia startsWith 2.0
Bang!
WrappedException: java.lang.UnsupportedOperationException: TODO:
to the best available (current, but evolving) result (see logs
for details)
This gets to console:
!STACK 0
	at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.getDelegate(CompoundReentrantTypeResolver.java:79)
	at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.getDelegate(CompoundReentrantTypeResolver.java:114)
	at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.getActualType(CompoundReentrantTypeResolver.java:106)
	at org.eclipse.xtext.xbase.typesystem.internal.ForwardingResolvedTypes.getActualType(ForwardingResolvedTypes.java:39)
	at org.eclipse.xtext.xbase.typesystem.InferredTypeIndicator.getTypeReference(InferredTypeIndicator.java:78)
	at org.eclipse.xtext.xtype.impl.XComputedTypeReferenceImplCustom.getEquivalent(XComputedTypeReferenceImplCustom.java:46)
	at org.eclipse.xtext.common.types.impl.JvmSpecializedTypeReferenceImplCustom.getType(JvmSpecializedTypeReferenceImplCustom.java:23)
	at org.eclipse.xtext.xbase.scoping.batch.BucketedEObjectDescription.computeShadowingKey(BucketedEObjectDescription.java:79)
	at org.eclipse.xtext.xbase.scoping.batch.BucketedEObjectDescription.getShadowingKey(BucketedEObjectDescription.java:62)
	at org.eclipse.xtext.xbase.scoping.batch.AbstractSessionBasedScope.getShadowingKey(AbstractSessionBasedScope.java:169)
	at org.eclipse.xtext.xbase.scoping.batch.AbstractSessionBasedScope.isShadowed(AbstractSessionBasedScope.java:179)
	at org.eclipse.xtext.scoping.impl.AbstractScope$ParentIterable.apply(AbstractScope.java:67)
	at org.eclipse.xtext.scoping.impl.AbstractScope$ParentIterable.apply(AbstractScope.java:1)
	at com.google.common.collect.Iterators$7.computeNext(Iterators.java:645)
	at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:141)
	at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:136)
	at com.google.common.collect.Iterators$5.hasNext(Iterators.java:539)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.getLinkingCandidates(AbstractTypeComputationState.java:346)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:848)
	at org.uqbar.HoopeTypeComputer.computeTypes(HoopeTypeComputer.java:70)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.doComputeTypes(AbstractTypeComputationState.java:119)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.computeTypes(AbstractTypeComputationState.java:108)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:292)
	at org.uqbar.HoopeTypeComputer.computeTypes(HoopeTypeComputer.java:88)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractRootTypeComputationState.computeTypes(AbstractRootTypeComputationState.java:36)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:512)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:422)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeMemberTypes(LogicalContainerAwareReentrantTypeResolver.java:583)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:572)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:416)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:411)
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:160)
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:147)
	at org.eclipse.xtext.xbase.compiler.ErrorSafeExtensions.serializeSafely(ErrorSafeExtensions.java:210)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateParameter(JvmModelGenerator.java:1066)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateParameters(JvmModelGenerator.java:1038)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateMember(JvmModelGenerator.java:857)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateMember(JvmModelGenerator.java:1880)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:288)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:1)
	at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)
	at org.eclipse.xtext.xbase.compiler.LoopExtensions$1.apply(LoopExtensions.java:39)
	at org.eclipse.xtext.xbase.lib.IterableExtensions.forEach(IterableExtensions.java:399)
	at org.eclipse.xtext.xbase.compiler.LoopExtensions.forEach(LoopExtensions.java:42)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateBody(JvmModelGenerator.java:292)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateBody(JvmModelGenerator.java:1852)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateType(JvmModelGenerator.java:211)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._internalDoGenerate(JvmModelGenerator.java:202)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.internalDoGenerate(JvmModelGenerator.java:1835)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.doGenerate(JvmModelGenerator.java:183)
	at org.eclipse.xtext.builder.BuilderParticipant.handleChangedContents(BuilderParticipant.java:299)
	at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:229)
	at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
	at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:186)
	at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:162)
	at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:95)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
	at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
	at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
It's running on Eclipse 4.3 and Xtext 2.4.2.
Any clue? Sinc domain model examples using jvminferrer have mandatory type declaration, perhaps this feature is not available.
Thanks in advance and best regards!
Miguel
Re: [Xbase] getting the result type of an expression during inferring [message #1178499 is a reply to message #1178440] Sat, 09 November 2013 13:02 Go to previous messageGo to next message
you are not actually doing that is done in the domain model example.
there is simply called org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.inferredType()
Re: [Xbase] getting the result type of an expression during inferring [message #1178517 is a reply to message #1178499] Sat, 09 November 2013 13:20 Go to previous messageGo to next message
I understand I'm not doing the samething, yet is it possible to what I'm trying?
I've upgraded xtext to 2.4.3.
Miguel
Re: [Xbase] getting the result type of an expression during inferring [message #1178552 is a reply to message #1178517] Sat, 09 November 2013 13:47 Go to previous messageGo to next message
can you simply try it?
Re: [Xbase] getting the result type of an expression during inferring [message #1178558 is a reply to message #1178552] Sat, 09 November 2013 13:55 Go to previous messageGo to next message
I've tried this:
					Property: {
						val type = feature.type?: inferredType
						members += feature.toObservedSetter(feature.name, type)
And get the following Exception:
org.eclipse.emf.common.util.WrappedException: java.lang.IllegalStateException: equivalent could not be computed
	at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:129)
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver.resolveTypes(CachingBatchTypeResolver.java:58)
	at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:45)
	at org.eclipse.xtext.xbase.resource.BatchLinkableResource.resolveLazyCrossReferences(BatchLinkableResource.java:142)
	at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:511)
	at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:155)
	at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:68)
	at org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.addMarkers(DefaultResourceUIValidatorExtension.java:60)
	at org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.updateValidationMarkers(DefaultResourceUIValidatorExtension.java:45)
	at org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.processDelta(MarkerUpdaterImpl.java:74)
	at org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.updateMarkers(MarkerUpdaterImpl.java:59)
	at org.eclipse.xtext.builder.builderState.AbstractBuilderState.updateMarkers(AbstractBuilderState.java:80)
	at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:266)
	at org.eclipse.xtext.builder.builderState.AbstractBuilderState.update(AbstractBuilderState.java:111)
	at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:184)
	at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:210)
	at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:89)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:733)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:299)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:302)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:358)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:381)
Caused by: java.lang.IllegalStateException: equivalent could not be computed
	at org.eclipse.xtext.xbase.typesystem.InferredTypeIndicator.getTypeReference(InferredTypeIndicator.java:84)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:859)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:293)
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:210)
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:197)
	at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.reentrantResolve(CompoundReentrantTypeResolver.java:65)
	... 28 more
Re: [Xbase] getting the result type of an expression during inferring [message #1178610 is a reply to message #1178558] Sat, 09 November 2013 14:43 Go to previous messageGo to next message
strange. sounds like a bug to me
Re: [Xbase] getting the result type of an expression during inferring [message #1181454 is a reply to message #1178610] Mon, 11 November 2013 11:10 Go to previous message
I also suffer from this.
It seems to happen when you create a field (with inferredType) together with getter and/or setter.
I think this is an incarnation of https://bugs.eclipse.org/bugs/show_bug.cgi?id=408323.
Any known workaround?
Previous Topic:Conflict between xtend and xtext language, model inferrer and dependencies?
Next Topic:Create an Eclipse product
Current Time: Fri Jul 25 21:42:15 EDT 2025
Powered by FUDForum. Page generated in 0.04312 seconds
