Home » Newcomers » Newcomers » Eclipse Suddenly Won't Start Up(No issues for weeks and then...)
Eclipse Suddenly Won't Start Up [message #1131516] |
Thu, 10 October 2013 11:57  |
I've been using Eclipse Kepler on my MacBook almost daily for a couple of weeks, but it will not open today. The log is below. Any ideas?
!SESSION 2013-10-04 05:20:26.090 -----------------------------------------------
eclipse.buildId=4.3.0.M20130911-1000
java.version=1.7.0_07
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.standard.product -product org.eclipse.epp.package.standard.product -keyring /Users/michaelmcguire/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.standard.product -data /Users/michaelmcguire/Dropbox/Java Class -product org.eclipse.epp.package.standard.product -keyring /Users/michaelmcguire/.eclipse_keyring -showlocation
!ENTRY org.eclipse.core.net 1 0 2013-10-04 05:20:29.466
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!SESSION 2013-10-04 14:08:49.419 -----------------------------------------------
Framework arguments: -product org.eclipse.epp.package.standard.product -keyring /Users/michaelmcguire/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.standard.product -keyring /Users/michaelmcguire/.eclipse_keyring -showlocation
!ENTRY org.eclipse.core.net 1 0 2013-10-04 14:08:54.487
!ENTRY org.eclipse.egit.ui 2 0 2013-10-04 14:11:25.747
!MESSAGE Warning: EGit couldn't detect the installation path "gitPrefix" of native Git. Hence EGit can't respect system level
Git settings which might be configured in ${gitPrefix}/etc/gitconfig under the native Git installation directory.
The most important of these settings is core.autocrlf. Git for Windows by default sets this parameter to true in
this system level configuration. The Git installation location can be configured on the
Team > Git > Configuration preference page's 'System Settings' tab.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!SESSION 2013-10-04 14:26:16.970 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2013-10-04 14:26:20.652
!ENTRY org.eclipse.egit.ui 2 0 2013-10-04 14:26:34.237
!SESSION 2013-10-05 06:33:33.709 -----------------------------------------------
java.version=1.7.0_40
Framework arguments: -product org.eclipse.epp.package.standard.product -keyring /Users/User/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.standard.product -keyring /Users/User/.eclipse_keyring -showlocation
!ENTRY org.eclipse.core.resources 2 10035 2013-10-05 06:33:55.465
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.core.net 1 0 2013-10-05 06:33:57.214
!ENTRY org.eclipse.egit.ui 2 0 2013-10-05 06:34:12.575
!SESSION 2013-10-05 16:33:04.004 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2013-10-05 16:33:07.164
!ENTRY org.eclipse.egit.ui 2 0 2013-10-05 16:33:21.556
!SESSION 2013-10-05 17:15:39.988 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2013-10-05 17:15:43.132
!ENTRY org.eclipse.egit.ui 2 0 2013-10-05 17:15:56.877
!ENTRY org.eclipse.jdt.core 4 4 2013-10-05 17:17:07.332
!MESSAGE Background Indexer Crash Recovery
!STACK 0
java.lang.OutOfMemoryError: Requested array size exceeds VM limit
at org.eclipse.jdt.internal.compiler.util.HashtableOfObject.<init>(HashtableOfObject.java:38)
at org.eclipse.jdt.internal.core.index.DiskIndex.readCategoryTable(DiskIndex.java:642)
at org.eclipse.jdt.internal.core.index.DiskIndex.mergeCategory(DiskIndex.java:463)
at org.eclipse.jdt.internal.core.index.DiskIndex.mergeCategories(DiskIndex.java:455)
at org.eclipse.jdt.internal.core.index.DiskIndex.mergeWith(DiskIndex.java:549)
at org.eclipse.jdt.internal.core.index.Index.save(Index.java:197)
at org.eclipse.jdt.internal.core.search.indexing.IndexManager.saveIndex(IndexManager.java:859)
at org.eclipse.jdt.internal.core.search.indexing.IndexManager.saveIndexes(IndexManager.java:901)
at org.eclipse.jdt.internal.core.search.indexing.IndexManager.notifyIdle(IndexManager.java:618)
at org.eclipse.jdt.internal.core.search.processing.JobManager.run(JobManager.java:388)
at java.lang.Thread.run(Thread.java:722)
!SESSION 2013-10-05 17:17:26.085 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2013-10-05 17:17:31.264
!ENTRY org.eclipse.egit.ui 2 0 2013-10-05 17:17:48.467
!SESSION 2013-10-05 17:36:46.574 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2013-10-05 17:36:49.731
!ENTRY org.eclipse.egit.ui 2 0 2013-10-05 17:37:03.616
!ENTRY org.eclipse.core.jobs 4 2 2013-10-06 05:38:18.538
!MESSAGE An internal error occurred during: "Periodic workspace save.".
!STACK 0
java.lang.IllegalArgumentException: Cannot set lower sequence number for root (previous: 6, new: 3). Location: /Users/michaelmcguire/Dropbox/Java Class/.metadata/.plugins/org.eclipse.core.resources/.safetable/org.eclipse.core.resources
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
at org.eclipse.core.internal.resources.SaveManager.validateMasterTableBeforeSave(SaveManager.java:1564)
at org.eclipse.core.internal.resources.SaveManager.saveMasterTable(SaveManager.java:1228)
at org.eclipse.core.internal.resources.SaveManager.saveMasterTable(SaveManager.java:1220)
at org.eclipse.core.internal.resources.SaveManager.save(SaveManager.java:1197)
at org.eclipse.core.internal.resources.SaveManager.save(SaveManager.java:1109)
at org.eclipse.core.internal.resources.DelayedSnapshotJob.run(DelayedSnapshotJob.java:51)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
!ENTRY org.eclipse.ui 4 4 2013-10-06 05:52:53.804
!MESSAGE Unable to create part
!ENTRY org.eclipse.core.resources 4 368 2013-10-06 05:52:53.805
!MESSAGE Resource '/TotalBeginner/My Scrapbook.jpage' does not exist.
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource '/TotalBeginner/My Scrapbook.jpage' does not exist.
at org.eclipse.core.internal.resources.Resource.checkExists(Resource.java:341)
at org.eclipse.core.internal.resources.Resource.checkAccessible(Resource.java:215)
at org.eclipse.core.internal.resources.Resource.checkAccessibleAndLocal(Resource.java:221)
at org.eclipse.core.internal.resources.Resource.getPersistentProperty(Resource.java:1204)
at org.eclipse.jdt.internal.debug.ui.snippeteditor.JavaSnippetEditor.doSetInput(JavaSnippetEditor.java:297)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(AbstractTextEditor.java:3217)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.ui.internal.WorkbenchWindow$13.run(WorkbenchWindow.java:1818)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:1815)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3235)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3262)
at org.eclipse.jdt.internal.debug.ui.snippeteditor.JavaSnippetEditor.init(JavaSnippetEditor.java:306)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:359)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:306)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:90)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4650)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:576)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:543)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:610)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:322)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1034)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3112)
at org.eclipse.ui.internal.WorkbenchPage.access$21(WorkbenchPage.java:3034)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:3016)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3012)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2976)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2967)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:534)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:493)
at org.eclipse.jdt.internal.debug.ui.snippeteditor.NewSnippetFileWizardPage.finish(NewSnippetFileWizardPage.java:75)
at org.eclipse.jdt.internal.debug.ui.snippeteditor.NewSnippetFileCreationWizard.performFinish(NewSnippetFileCreationWizard.java:61)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:628)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4166)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1489)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1474)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1279)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4012)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3651)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:826)
at org.eclipse.jface.window.Window.open(Window.java:802)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:259)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:279)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:420)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
!SUBENTRY 1 org.eclipse.core.resources 4 368 2013-10-06 05:52:53.806
!ENTRY org.eclipse.core.jobs 4 2 2013-10-06 05:58:27.102
!STACK 0
!SESSION 2013-10-06 06:09:18.943 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2013-10-06 06:09:21.650
!ENTRY org.eclipse.core.net 1 0 2013-10-06 06:09:26.921
!ENTRY org.eclipse.egit.ui 2 0 2013-10-06 06:09:43.012
!ENTRY org.eclipse.core.jobs 4 2 2013-10-06 07:17:43.845
!STACK 0
!ENTRY org.eclipse.core.jobs 4 2 2013-10-06 07:23:21.833
!STACK 0
!SESSION 2013-10-06 08:32:48.224 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2013-10-06 08:32:52.536
!ENTRY org.eclipse.egit.ui 2 0 2013-10-06 08:33:07.239
!ENTRY org.eclipse.jdt.core 4 4 2013-10-06 13:02:36.192
!STACK 0
java.lang.StringIndexOutOfBoundsException: String index out of range: 0
at java.lang.String.charAt(String.java:658)
at org.eclipse.jdt.internal.core.index.DiskIndex.writeAllDocumentNames(DiskIndex.java:1032)
at org.eclipse.jdt.internal.core.index.DiskIndex.mergeWith(DiskIndex.java:531)
at java.lang.Thread.run(Thread.java:724)
!SESSION 2013-10-06 13:04:23.333 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2013-10-06 13:04:32.516
!ENTRY org.eclipse.egit.ui 2 0 2013-10-06 13:04:49.541
!ENTRY org.eclipse.core.jobs 4 2 2013-10-06 13:09:13.131
!STACK 0
java.lang.IllegalArgumentException: Cannot set lower sequence number for root (previous: 7, new: 5). Location: /Users/michaelmcguire/Dropbox/Java Class/.metadata/.plugins/org.eclipse.core.resources/.safetable/org.eclipse.core.resources
!SESSION 2013-10-06 13:12:50.306 -----------------------------------------------
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.standard.product
!ENTRY org.eclipse.core.resources 2 10035 2013-10-06 13:13:29.836
!ENTRY org.eclipse.jdt.launching 1 0 2013-10-06 13:13:31.646
!MESSAGE Installed JRE 'Java SE 6 [1.6.0_51-b11-457]' removed due to missing VM type extension.
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-10-06 13:13:32.551
!MESSAGE Unable to load class 'org.eclipse.e4.ui.workbench.renderers.swt.cocoa.ArrangeWindowHandler' from bundle '70'
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.e4.ui.workbench.renderers.swt.cocoa.ArrangeWindowHandler cannot be found by org.eclipse.e4.ui.workbench.renderers.swt_0.11.1.v20130812-1345
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:100)
at org.eclipse.e4.ui.internal.workbench.addons.HandlerProcessingAddon.processActiveHandler(HandlerProcessingAddon.java:158)
at org.eclipse.e4.ui.internal.workbench.addons.HandlerProcessingAddon.postConstruct(HandlerProcessingAddon.java:59)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:267)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:186)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:49)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:276)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:581)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-10-06 13:13:32.566
!MESSAGE Unable to load class 'org.eclipse.e4.ui.workbench.renderers.swt.cocoa.MinimizeWindowHandler' from bundle '70'
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.e4.ui.workbench.renderers.swt.cocoa.MinimizeWindowHandler cannot be found by org.eclipse.e4.ui.workbench.renderers.swt_0.11.1.v20130812-1345
!MESSAGE Unable to load class 'org.eclipse.e4.ui.workbench.renderers.swt.cocoa.FullscreenWindowHandler' from bundle '70'
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.e4.ui.workbench.renderers.swt.cocoa.FullscreenWindowHandler cannot be found by org.eclipse.e4.ui.workbench.renderers.swt_0.11.1.v20130812-1345
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-10-06 13:13:32.582
!MESSAGE Unable to load class 'org.eclipse.e4.ui.workbench.renderers.swt.cocoa.ZoomWindowHandler' from bundle '70'
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.e4.ui.workbench.renderers.swt.cocoa.ZoomWindowHandler cannot be found by org.eclipse.e4.ui.workbench.renderers.swt_0.11.1.v20130812-1345
!MESSAGE Unable to load class 'org.eclipse.e4.ui.workbench.renderers.swt.cocoa.CloseDialogHandler' from bundle '70'
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.e4.ui.workbench.renderers.swt.cocoa.CloseDialogHandler cannot be found by org.eclipse.e4.ui.workbench.renderers.swt_0.11.1.v20130812-1345
!MESSAGE Unable to load class 'org.eclipse.e4.ui.workbench.renderers.swt.cocoa.CocoaUIHandler' from bundle '70'
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.e4.ui.workbench.renderers.swt.cocoa.CocoaUIHandler cannot be found by org.eclipse.e4.ui.workbench.renderers.swt_0.11.1.v20130812-1345
!ENTRY org.eclipse.egit.ui 2 0 2013-10-06 13:13:56.333
Re: Eclipse Suddenly Won't Start Up [message #1131574 is a reply to message #1131516] |
Thu, 10 October 2013 12:49   |
> [snip]
I see you're trying to share your workspace by keeping it in Dropbox. If
you're opening it using Eclipse from different hosts, this may now be
your problem. Likely, you'll need to rebuild your workspace, start from
scratch.
Projects are portable; keep these in Dropbox, import them into your
host-resident workspace leaving their contents in Dropbox (i.e.: don't
click the box saying to import their source into the workspace). This
way, you can share them.
If you haven't touched your workspace from another computer, then
someone else more in tune with the actual cause (sequence number) may
come along (but maybe not).
The EGit messages are only warnings...
If you're not using Git, given you're using Dropbox I'm guessing that
you are not, then you might just "turn it off" so that Eclipse doesn't
worry about it. This thread discusses that though I do use Git so I've
not turned it off and don't know about the efficaciousness of the
recommendations.
http://www.eclipse.org/forums/index.php/t/394636/
I think you'll have to fix the crash before tackling the Git warnings.
Best of luck.
Re: Eclipse Suddenly Won't Start Up [message #1131618 is a reply to message #1131574] |
Thu, 10 October 2013 13:34  |
Very helpful - thanks. I re-installed and moved my workspace out of Dropbox. I'll try that system you mentioned about keeping the projects in Dropbox but not importing their contents onto my desktop workspace.
Current Time: Wed Jul 23 09:30:43 EDT 2025
Powered by FUDForum. Page generated in 0.15499 seconds
