Home » Eclipse Projects » e(fx)clipse » Accessing the controller instance when using FXMLLoaderFactory(What's the best way to get access to the controller instance after loading an FXML file using FXMLLoaderFactory)
Accessing the controller instance when using FXMLLoaderFactory [message #1131108] Thu, 10 October 2013 03:44 Go to next message
in a follow-up to this discussion in the old forum, I would like to know if using the Eclipse context is still the only (or best) way to access a controller instance after loading an FXML file using the FXMLLoaderFactory class.
The example code was:
@PostConstruct
void init(BorderPane parent, @FXMLLoader FXMLLoaderFactory factory, IEclipseContext ctx) {
   Parent topElement = (Parent) factory.loadRequestorRelative("Test.fxml").load();
   my.package.Controller c = ctx.get("my.package.Controller");
According to this Eclipsepedia page, "it is not intended for the developer to use the IEclipseContext directly". So is there a better alternative?
The FXMLLoader class has a getController() method. Could we have a similar solution for the FXMLLoaderFactory or FXMLBuilder class?
Uwe
Re: Accessing the controller instance when using FXMLLoaderFactory [message #1131124 is a reply to message #1131108] Thu, 10 October 2013 04:01 Go to previous messageGo to next message
Sure file a feature request, I agree the IEclipseContext should be
referenced only as a last resort in code.
I've been working on a related topic lately which allows you to publish
informations without the IEclipseContext but it is not yet checked into
the repo.
Tom
On 10.10.13 09:44, Uwe San wrote:
> in a follow-up to
> https://groups.google.com/forum/#!searchin/efxclipse/fxmlloaderfactory/efxclipse/BAkd68xlsNo
> @PostConstruct
> According to this http://wiki.eclipse.org/E4/Contexts#Summary, "it is
> Uwe
Re: Accessing the controller instance when using FXMLLoaderFactory [message #1131247 is a reply to message #1131124] Thu, 10 October 2013 06:43 Go to previous message
.... just wanted to say patches are welcome ;-)
Tom
> the repo.
> Tom
>> Hi,
>> in a follow-up to
>> @PostConstruct
>> Thanks,
>> Uwe
Previous Topic:How to programmatically Center a MWindow and Access his Rendering Tag.
Next Topic:RCP e4 SWT/JavaFX application with Kepler
Current Time: Wed Jul 23 02:41:09 EDT 2025
Powered by FUDForum. Page generated in 0.09349 seconds
