Home » Archived » Jubula » Jubula takes longer to save the changes
Jubula takes longer to save the changes [message #1105807] Tue, 10 September 2013 05:46 Go to next message
I have few hundred testcases in my test suite(s)
From last couple of days the Jubula takes quite longer (on an aerage 2mints) to save the changes made at suite/testcase level and every time it displays a progress bar "Checking for project completeness ..."
I have verified with the database admin that there is no issue with the database, which must be causing the delay
I have also tried to,
- Delete the workspace and start a fresh
- Increase memory in jubula.ini
- Delete the older test results
Is there any other way to figure out the root cause ?
Any help/suggestion is much appreciated.
Following stats may be helpful
"TESTRESULT"                       54.85 MB   20871 rows
"PARAMETER_DETAILS"                2.202 MB   37376 rows
"NODE"                             1.035 MB    6588 rows
"TESTRESULT_SUMMARY"               1.158 MB    2552 rows
"LOCALE_TO_TD"                     764.0 KB   20526 rows
"TD_MANAGER_PARAM_ID"              442.6 KB   10594 rows
"COMP_NAME_PAIRS"                  307.3 KB    2571 rows
"PARAM_DESC"                       303.4 KB    4318 rows
"HIERARCHY_NAMES"                  260.5 KB    5310 rows
"COMPONENT_NAMES"                  157.4 KB    1328 rows
"PARAM_INTERFACE"                  175.0 KB    6398 rows
"PARAM_NAMES"                      143.9 KB    2377 rows
"TEST_DATA"                        177.8 KB    8505 rows
"NEIGHBOURS"                       119.7 KB    2611 rows
"NODE_LIST"                        105.7 KB    6092 rows
"COMP_ID"                          63.29 KB     529 rows
"LOGICAL_NAME"                     54.42 KB    1126 rows
"TD_MANAGER"                       87.50 KB    6398 rows
"TD_MANAGER_TEST_DATA_LIST"        52.37 KB    2989 rows
"TEST_DATA_LIST"                   43.74 KB    2989 rows
"APPLICATION"                      5.929 KB       2 rows
"AUT"                              8.937 KB       4 rows
"AUT_AUT_CONF"                     5.570 KB       4 rows
"AUT_CONF"                         6.539 KB       4 rows
"AUT_CONF_ATTR"                    7.062 KB      33 rows
"AUT_CONT"                         6.070 KB       8 rows
"AUT_LANGUAGES"                    5.523 KB       4 rows
"CHECKCONFPO_ATTR"                 6.429 KB      24 rows
"CHECKCONFPO_CONTEXTS"             10.06 KB     148 rows
"CHECK_CONF"                       7.875 KB      76 rows
"CHECK_CONF_CONT"                  6.539 KB       8 rows
"CHECK_CONF_CONT_MAP"              11.58 KB      76 rows
"DB_GUARD"                         5.054 KB       1 rows
"DB_VERSION"                       6.414 KB       1 rows
"DEF_EVENTH"                       9.242 KB      92 rows
"EVENT_HANDLERS"                   22.12 KB     414 rows
"EXEC_CONT"                        6.070 KB       8 rows
"EXEC_CONT_NODE"                   6.335 KB      23 rows
"LOCKED_OBJECTS"                   5.968 KB       1 rows
"OBJ_MAP"                          8.382 KB       4 rows
"OM_ASSOC"                         23.67 KB     550 rows
"OM_CATEGORY"                      7.203 KB      12 rows
"OM_PROFILE"                       7.382 KB       4 rows
"PROJECT_NAMES"                    6.789 KB       8 rows
"PROJECT_PROPERTIES"               9.625 KB       8 rows
"PROJ_LANGUAGES"                   6.140 KB      48 rows
"REUSED_PROJECTS"                  8.484 KB      13 rows
"SEQUENCE"                         5.523 KB       3 rows
"SPEC_CONT"                        6.070 KB       8 rows
"SPEC_CONT_NODE"                   6.640 KB      44 rows
"TEST_DATA_CAT"                    6.929 KB       8 rows
"USED_TOOLKITS"                    7.703 KB       7 rows
"AUT_IDS"                              0 KB       0 rows
"DB_LOCKS"                             0 KB       0 rows
"MONITORING_REPORT"                    0 KB       0 rows
"MONITORING_VALUE"                     0 KB       0 rows
Bhupendra
  • Attachment: project.JPG
    (Size: 10.40KB, Downloaded 193 times)
[Updated on: Tue, 10 September 2013 06:16] by Moderator
Re: Jubula takes longer to save the changes [message #1107211 is a reply to message #1105807] Thu, 12 September 2013 01:06 Go to previous messageGo to next message
Can anyone please comment why every time jubula checks for project completeness ?
Are there any settings to turn it off ?
Bhupendra
Re: Jubula takes longer to save the changes [message #1107300 is a reply to message #1105807] Thu, 12 September 2013 04:06 Go to previous messageGo to next message
This has been resolved now.
The issue was due to event handler configurations, where one event handler 1 was calling 2 and 2 was calling 3 ... the depth was till 5
Removing them, helped jubula to restore workable env.
Bhupendra
Re: Jubula takes longer to save the changes [message #1110797 is a reply to message #1107300] Tue, 17 September 2013 06:34 Go to previous messageGo to next message
Thanks for the update Bhupendra.
Re: Jubula takes longer to save the changes [message #1130384 is a reply to message #1110797] Wed, 09 October 2013 09:59 Go to previous messageGo to next message
I am just wondering if it is expected for Jubula to have performance hits when embedding event handlers?
Due to the lack branching and cycling capabilities it is the only way to organize such constructions for proper test case flow.
Alex
Re: Jubula takes longer to save the changes [message #1130426 is a reply to message #1130384] Wed, 09 October 2013 10:49 Go to previous message
Hi Alex,
This would be the first I'd heard of it. I think that Bhupendra's problem was multiple embedded Event Handlers, which I've not often required (I think the most I've needed up until now was 3 levels). That's not to say that there aren't valid use cases that require it, but it may explain why, if there is a problem, it's not been noticed. If you do notice anything linked to this structure, please file a ticket.
Thanks!
Alex
Previous Topic:Use of check text and not equal to operator
Next Topic:Problems with extensions and rebuilding some jars.
Current Time: Sun Jul 20 20:18:20 EDT 2025
Powered by FUDForum. Page generated in 0.04933 seconds
