Home » Modeling » Graphiti » How to avoid linking of diagram to the model object to be part of the command stack(How to avoid linking of diagram to the model object to be part of the command stack)
How to avoid linking of diagram to the model object to be part of the command stack [message #1130109] Wed, 09 October 2013 04:33 Go to next message
Hi All
I am working on a scenario where in there are many tree objects, on selection of tree objects am removing elements from diagram and adding new elements(clearing and re-painting new diagram).
So on selection of tree am linking the diagram with selected tree object.
But the linking can happen only using command stack.
public void linkSelectedNodeToDiagram(final AbstractDiagramTypeProvider diagramTypeProvider, final Object selectedObject) {
TransactionalEditingDomain editingDomain = diagramTypeProvider.getDiagramBehavior().getEditingDomain();
CommandStack cStack = editingDomain.getCommandStack();
cStack.execute(new RecordingCommand(editingDomain, "Link Diagram to EObject", false) { //$NON-NLS-1$
protected void commandExecute() {
diagramTypeProvider.getFeatureProvider().link(diagramTypeProvider.getDiagram(), (EObject) selectedObject);
public void refreshUI() {
So i want a way to do this without command stack, because this is adding to undo and even if i set undo false, it is creating issues on each selection.
So can any one suggest a best way of linking without command stack.
Palani
Re: How to avoid linking of diagram to the model object to be part of the command stack [message #1130132 is a reply to message #1130109] Wed, 09 October 2013 04:49 Go to previous messageGo to next message
Palani,
I'm afraid that is not possible, at least not from inside an editor.
Graphiti uses EMF Transactions so every change to the model must be done in
a transaction which is recorded and ends on the command stack. Chaging the
model from inside an editor omitting the transaction will cause an
exception.
You may of course do that outside if the editor using your own means to
load, modify and save the EMF model.
Michael
Re: How to avoid linking of diagram to the model object to be part of the command stack [message #1130143 is a reply to message #1130132] Wed, 09 October 2013 04:58 Go to previous messageGo to next message
Michael,
Can i use custom feature to achieve the same?Linking of diagram to selected tree object.I tried using custom feature but i dont know how to get the object inside custom feature.
Palani
Re: How to avoid linking of diagram to the model object to be part of the command stack [message #1132774 is a reply to message #1130143] Fri, 11 October 2013 07:34 Go to previous message
Palani,
yes, this can also be done inside a custom feature. Retrieving the objects
might be tricky depending on your object hierarchy. You will have to
browse/navigate through it (possibly starting from the object the custom
feature is registered for or the diagram/your root object).
Michael
Previous Topic:Update diagram after business object has been deleted
Next Topic:Reusing EMF.Edit property sheet
Current Time: Sun Jul 27 11:28:17 EDT 2025
Powered by FUDForum. Page generated in 0.03330 seconds
