Home » Eclipse Projects » Remote Application Platform (RAP) » changing fontsize during lifecycle
changing fontsize during lifecycle [message #112899] Thu, 20 November 2008 05:15 Go to next message
is it possible to change the fontsize of all buttons and labels during
the lifecycle.
In the moment i changed it per css, like this:
font: normal 12px Verdana;
But I want that user can change it.
Roland
Re: changing fontsize during lifecycle [message #112995 is a reply to message #112899] Fri, 21 November 2008 01:34 Go to previous messageGo to next message
Hi Roland,
this can be done using a PhaseListener.
You can hook into After-Render-Phase and update your widgets. One
possibility is to store the old font heights via setData with the
widgets to determine if the font size has to been modified or not. See
TextSizeDeterminationHandler for an example on how to iterate and update
over the complete widget tree.
Another possibility would be to create multiple themens with different
font sizes and switch between them during runtime. However, I don't
know, if that's supported yet. Ralf?
Stefan.
Roland Siebert schrieb:
> the lifecycle.
> Roland
Re: changing fontsize during lifecycle [message #113017 is a reply to message #112995] Fri, 21 November 2008 03:31 Go to previous messageGo to next message
Originally posted by: ifurnadjiev.innoopract.com
switching the widget variant at runtime is possible. You can take a look
at the variant tab of the Control Demo.
Best,
Ivan
Stefan Roeck wrote:
> Hi Roland,
> update over the complete widget tree.
> Regards,
> Stefan.
>> Hi,
>> during the lifecycle.
>> Roland
Re: changing fontsize during lifecycle [message #113029 is a reply to message #113017] Fri, 21 November 2008 04:23 Go to previous message
Originally posted by: rsternberg.innoopract.com
switching themes at runtime is currently not supported. If only the font
differs between the multiple themes, this would also involve a lot of
redundancy, I guess.
It's right, widget variants can be switched at runtime. But if you want
to go that way to change the font of every widget, you also have to
apply these variants to every widget. As a widget can only have a single
variant, this approach would prevent you from using variants for any
other purpose. To actually change fonts, you would have to change the
variant for all widgets, so you would save nothing compared to the
approach Stefan already outlined.
Don't forget to re-layout after switching fonts.
Best regards, Ralf
Ivan Furnadjiev wrote:
> Best,
> Ivan
> Stefan Roeck wrote:
>> Hi Roland,
>> Regards,
>> Stefan.
>>> Hi,
>>> Roland
Previous Topic:[Decorator] Icons not refreshed
Next Topic:change color of the table item completely
Current Time: Fri Jul 25 10:26:49 EDT 2025
Powered by FUDForum. Page generated in 0.23708 seconds
